Question about Karcher K2.26 Electric Power Washer
Switching on and off before turning on lance
I have a karcher 380.when turning on operating switch.the washer turns on and off continuously before pressing wand trigger.
  • 104 Answers
SOURCE: Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Posted on Jun 05, 2009
brado83
  • 106 Answers
SOURCE: The engine on my Karcher K2.26 turns on when you
yea mate ya bypass will be stuck(the little valve that turns the unit on or off) also if not that there is a little micro switch attached to the valve this may of dislodged for some reason... commonly happens if unit has sat for a period of time not used
regards
brad
Posted on Sep 16, 2009
brado83
  • 106 Answers
SOURCE: my karcher pressure washer is switching on and off
unfortunately these little units have this problem commonly, 9 times out of 10 it will be the plastic head on the unit will be cracked and leaking slightly... it builds up pressure then leaks out and tries to build up the pressure again and this just reoccurs over and over...
you can get this repaired but is normally about half the cost of a new unit, if the pressure is still okay i would probably recommend just keep using it until it proper dies...
If you do get this fixed, we have studied into this and believe the main cause of heads cracking is warm water say if your inlet hose is in the sun for a period of time this can cause the water to become quite hot or if the unit sits and water trapped inside the head assy freezes can also cause this.
Posted on Sep 17, 2009
seanpwright
  • 2030 Answers
SOURCE: My Karcher 1750 psi electric pressure washer is
thats normal, it is reducing the built up pressure that is not needed until the trigger is pulled.
Posted on Apr 01, 2010
  • 92 Answers
SOURCE: Turn water on then actuate wand trigger. Pressure
You gave a very close solution yourself for the problem. But other leakages can cause such symtoms.Forexample a leaking head or a leaking chemical inlet. These can be caused because the spill valve (pressure control valve) is stuck. When this valve stucks it will leave a micro switch ON. So the machine keeps working with the gun closed. This will in turn creat internal pressure and damages the head, valves and chemical non-return and even damage outlet hose. So besides fixing the leakages you must check and service the spill valve. I often replace the spill valve. One must also checks if the micro switch is faulty. Now very important that what you mentioned that the machine cycles at one minute intervals, with trigger closed...this is most probably always the spill valve fault. If you open machine you see a place where there is a wire..this belongs to the micro switch...under you find the spill valve. Intake and suction valves may now also have a fault. Also there are systems with non-return valves at the machine outlet. You have to tackle by elimination. Fix the leakage..then tackle spill valve and micro switch.
Fulltech.
Posted on Aug 04, 2010
My Karcher 530M runs ok until I release the trigger, then it will not start again unless I switch and allow the water to run through for about 15 secs before switching on again
Hi Cliff:
My experience is that the pump pressures prevent the engine from starting, so we hold the trigger while starting.
My brother has cut a wedge of wood that he uses to jam the trigger open to bypass the problem. It can get a bit wild if the wand is not secured when the unit is started..
Aug 10, 2016 | Karcher Garden
Karcher 5/11c motor runs but no pressure
Firstly make sure the pressure set valve is turned the right way, fully anticlockwise I think.(if it has one I could be thinking of the next model up) and that the lance nozzle is in the correct position not set to detergent or mid point between positions. If that is ok it is probably the switch at the bottom of the machine. If under warranty send it back karcher switches are not good.
Mar 12, 2014 | Toolbank Karcher Hd511cl Hd5/11C 110V...
Karcher 380 works fine until I turn it off. it will then not work for say half an hour
over pressure switch stuck, dismntle switch and clean or replace ( located between on/off switch and pump head
Feb 22, 2014 | Karcher Garden
Karcher Motor Pulese On and Off
hi mark, you do have a problem with the lance.
you need to disconnect the lance and straighten a paper clip and insert down the nozzle end.
use the machine to wash the dirt in the nozzle backward down the lance.
Dirt only in nozzle end.
if still no good, purchase some nozzle cleaners and file out nozzle very slightly.
Jun 29, 2009 | Garden
I have a Karcher 3.99 Pressure Washer. The motor appears to be working and water is passing through the machine when turned to the detergent application setting. However when the lance is tightened to turn...
Hi I have a karcher 3.99 the motor comes on and water comes out however thre is no pressure i have tested the lance on my brothers washer and this is ok what is wrong
Feb 21, 2009 | Karcher K 5.85 M Electric Pressure Washer
Karcher K2.89
Dear Pajodi,
I just came across your problem. I have just joined FIXYA, and solved various Karcher problems. First of all with all respect, the shop from where you bought the machine, must have told you all necessary instructions to operate your machine.
Now the soap always works on low pressure. So if you have a variable lance, turn it to low pressure. You can also remove the lance, and the soap will surely starts to work. With turbo lances, the soap system does not work. This concludes that the soap does not work when high pressure is used. Bigger machines do spray soap at high and low pressures. But these have regulating knobs, to swith off and on, the soap supply.
Regards,
MG.
Jul 21, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 520M Pressure washer won't operate at high pressure
I had the same problem - good water inlet pressure, no output pressure, even though the lance and handle seemed to be clear and working find.
I found that the electrical switch wasn't being operated correctly by the spill valve and wasn't turning the motor on/off correctly.
Inside the plastic electrical box there is a small white device that presses against the micro switch assembly. Carefully adjust the allen screw perhaps 1/4 turn out or 1/4 turn in to obtain correct operation of the microswitch - you will hear the micro switch clicking in and out when re-assembled. I'm sure they must have a rig to check correct positioning of this screw in the factory!
Hope it helps - mine is working find now and saved me buying another!
May 05, 2008 | Karcher 2500 PSI Pressure Washer
Karcher K2.26 Electric Power Washer Logo
344 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
