Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
Kitchenaid dish washer
Can you send me touch pad clearing code?
  • 868 Answers
If you feel it can be cleared by a code you need to think about replacing the electronic control board.
Posted on May 20, 2008
Error Code F9.Q (Touch Communication).
KitchenAid Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Kitchen-Aid-Appliance-Fault-Codes.aspx
Fault codes for a number of KitchenAid appliances, including two and four digit codesfor ... F9 - Oven Door Lock Failure - Check door lock switches and wiring.
Jul 27, 2015 | KitchenAid KHMS2050SSS Microwave Oven
Kitchenaid dishwasher fills with hot water but doesn't wash
remove sump cover clean sump and change the chopper
Feb 21, 2014 | KitchenAid Dishwashers
F2 e1 error code kitchenaid
Touch pads are notorious for going bad. You can pull the ribbon cable off and gently clean the contacts with a pencil eraser. If this soesn't fix the problem then the touch pad is more than likely the culprit.
Oct 24, 2013 | Ovens
The pots and pans and the normal light blinks but nothing happens
most likely you have a bad touch pad,you can first try this,shut the power down to the dish washer,open it up and unplug the ribbon from the touch pad that goes to the control board,unplug it off of the board for 5 minutes and then reconnect it the same way it came off and then run it and see if it repaired it,if not you'll need a new touch pad.hope this helps,one more thing,on the back of the kickplate or bottom panel has a tech sheet on the back of the panel,you can check it with the diagnostics to see what part is bad but most likely it will be the touch pad.good luck with your dish washer.
Oct 21, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Error code F2
The error code "F2" that appears on your KitchenAid microwave refers to a keyboard failure/short on the front button panel or loose keypad connector
Attempt the following to clear error:
Check keypad connector for firm connection.
Press "Cancel" after the error code is noted, if error code returns after 60 seconds, replace keypad ( also called touch pad or membrane switch ).
Best of Luck with the microwave.
Jan 26, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My KitchenAid Superba oven is not heating. Code F2- E5. thank you
Hello and sorry to hear about your problem. The code you have given, will have this problem. I suggest you contact a service person.
F2-E5 - Cancel Key Line Open - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
I have tried to help you. Please help me by Vote/Rate the response. Thanks and good luck
Dec 20, 2010 | KitchenAid KEBC107 Electric Single Oven
My kitchenaid keri203 is showing E0 in orange and F2 in blue on my oven display
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!@@
Aug 30, 2010 | KitchenAid KERI203PBS Electric Kitchen...
Codes F-21 And F-33 are showing up
this error occurs if the touch-pad/led assembly is not able to transmit/receive data to/from the central control unit (CCU) 1 check the touch -pad/led assembly by selecting different cycles and changing the modifiers and options available to confrim the touch-pad/led is responding. 2 unplug washer or disconnect power. 3 check wire harness connections to the touch-pad/led assembly and central control unit (CCU) now to the f-33 code system leak if after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. OR if the control has turned the water valves on and after 8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. press PAUSE/CANCEL twice to clear the display. possible causes/procedure 1 check for crack or holes in the washer tub and pressure switch hose. 2 replace components if necessary good luck
Feb 16, 2010 | Maytag EPICz 3.7 cu. ft. Washer
MDB 8750 Dish Washer Doesn't start the Wash Cycle.
Yes this can be a touch pad failure that may need to be replace again , because with this type of device usually the touch pad is easy to get bad...
Good luck........
Aug 19, 2008 | Maytag Dishwashers
Kitchenaid Oven won't work E0 F2 on the control pad
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Jul 24, 2008 | KitchenAid KESC307 Electric Kitchen Range
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
44 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
