Question about Nokia 6600
No ring tone to outgoing caller but the caller can hear me and I can't hear the caller
2 Suggested Answers
iPhoneTechKS
  • 30 Answers
SOURCE: For incoming calls the phone
Sounds like you reciever speaker is out. It might be cheaper to get a new phone than fix this one. Check with out a local cell repair store to see what they charge then make an informed decision.
Posted on Sep 30, 2010
How do i change the ringtone callers hear when they contact my htc wildfire
Thanks for visiting FixYa!
In most cases, the ring tone callers hear (incoming ring tone) is controlled by your cellular service provider.
Try this first: (On the Internet) Sign-in to your cellular account. On your account page, look for a link that directs you to your incoming ring tones (or similar). There, you can change your incoming ring tone.
If you're unable to do that, contact your cellular provider's Customer Support. They can assist you in changing your incoming ring tone.
May 30, 2011 | HTC Wildfire Cell Phone
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
For incoming calls the phone rings but I cannot hear the caller. The volume is set to the maximum. For outgoing call I cannot hear the ring tone nor the person receiving the call.
Sep 30, 2010 | Nokia 6131 Cellular Phone
How to set mp3 song from memory card as your caller tune
I think that there have been some mistake.....Caller Tune means the ring-tone which is hearing by someone who is calling you.So you cannot set the caller tune yourself, it is provided by the Sim service provider.Here However, Ring-Tone means the tone which you are hearing when someone is calling you.We can easily set this tone by using....Menu......>Profile...........>Ringing tone setting....Set the tone what you wish............................
Aug 10, 2010 | Nokia N73 Cellular Phone
How do I increase the rings before message answers?
Setting the Number of Rings (Excerpt from the Uniden Dect 1580 Phone manual
The ring time setting allows you to set the number of rings the caller hears before your answering system plays the outgoing message. You can set the ring time to answer after two, four, or six rings. If you enable the Toll Saver (TS) setting, the answering system picks up after two rings if you have new messages, and after four rings if there are
none. This way, if you make a long distance call to check your messages, you can hang up after the third ring to avoid long distance billing charges.
  1. Press Menu/Select.
  2. Select the Ans. Setup menu, and then the Ring Time submenu.
  3. Move the cursor to select a ring time (Toll Saver, 2 Times, 4 Times, or 6 Times).
  4. Press Menu/Select. You will hear a confirmation tone.
thanks
Jul 01, 2010 | GE 28112EE2 Cordless Phone
Would like to increase number of rings before answering machine comes on.
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
No sound at all - no incoming or outgoing ringtones - phone working though
why don't you try to send your moobile to a service center and let them open the unit to see what is the main and real problem of your mbile.
because some are experiencing that problem and the reason is some parts are needed to repair or replace.
thanks,
May 05, 2009 | Samsung E700 Cell Phone
Caller tones
it's in the profiler/contact of the caller
Apr 29, 2008 | Nokia 6233 Cellular Phone
How to change Flash timing
The only reference to flash timing I can find in the manual is shown below for you, also here is link to manual :
I hope it helps !
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
If you have Call Waiting service and a call waiting
tone sounds while you are on a call, press talk/flash
on the handset or flash/find hs on the base to accept
the waiting call. There is a short pause, and then you
will hear the new caller. To return to the original
caller, press talk/flash on the handset or flash/find
hs
on the base again.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select a Ring Time (Toll
3) Press the OK soft key. You will hear a confirmation tone.
Setting the Record Time
Record Time sets the duration for recording the incoming messages. You have three
record time options. The options "1 minute" or "4 minutes" set the duration for
recording the incoming messages. "Announce only" answers the call but prevents
the caller from leaving a message.
1) Enter the Answ. Setup menu, and then the Record
Time submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select Record Time
(1 Minute, 4 Minutes, or Announce Only).
May 03, 2007 | Uniden TRU8885-2 Cordless Phone
Nokia 6600 Logo
53 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
