Question about Fisher Price Emerald Baby Crib
I need all the bolts for model # 04830-615 - Fisher Price Emerald Baby Crib
F77 2.8 diesel non turbo.1989 model.require head bolt tensions,stages and sequence please
Search Results
    F77 2.8 diesel non turbo.1989 model.require head bolt - Fixya
    www.fixya.com/cars/t25792470-f77_2_8_diesel_non_turbo_1989
    Jul 22, 2015 - f77 2.8 diesel non turbo.1989 model.require head bolt tensions,stages and sequence please - Daihatsu Rocky question. ... Torque to yeild bolts need to be replaced whenever the head comes off.....Long bolts are 46 ft lbs. and ...
Jul 22, 2015 | Daihatsu Rocky Cars & Trucks
How do I change the bar bolts?
Depends on Model. Some you will have to remove muffler, other models are actually inside of oil tank. Once you locate the Square head of the bolts, you can than tap them out gently from the other side using a hammer. Afterwards, tap new bar bolt in its place. NOTE: if bolt head is inside of oil tank you will need to drain oil first.
Jul 14, 2014 | Husqvarna 142 Chainsaw For Parts
I need a spring bolt stop
There is a spring on the bolt stop but it can't be lost unless somebody took it out. Remington has them. Bolt stop return spring.
Mar 24, 2014 | Remington Model 700 Special Purpose Bolt...
I just bought a marlin model xt-17 .17 hmr and the bolt action gets really tight when you go to push it down to insert a bullet in the chamber. its almost like the bolt doesnt have enough room to move up...
If you cleaned you bolt carriage you might need to lube the bolt to make sure it will function properly. Cold weather will also cause some light wt lube to freeze making it hard to function. Try a heavier lube if out in the cold.
Oct 27, 2013 | Marlin Model XT-17R Rifle 70701, 17 HMR,...
Torque settings for mitsubishi 4D34 engine bolts
get the service and repair manual from the given and get the solution easily http://toolsnyou.com/
Nov 03, 2012 | Mitsubishi Cars & Trucks
I need the torque for all the head bolts on my 1983 datsun 280zx
Check this information for 1983 Datsun 280ZX 2.8L (click over image for zoom)...
Fig. 7: Cylinder head bolt removal sequence
Fig. 13: Head bolt torquing sequence-1970-83 models
After repair job, temporarily install and tighten the two center (right and left) cylinder head bolts to 14 ft. lbs. (18 Nm).
Install the camshaft sprocket together with the timing chain onto the camshaft. Make sure that the marks made earlier, line up. If the chain will not stretch over the sprocket, the problem lies in the tensioner. Refer to the Timing Chain removal and installation procedure for the timing procedure, if necessary.
Install the cylinder head bolts. Note that two lengths are used. Tighten the bolts in sequence.
1970-71 models:
Tighten the bolts to 33 ft. lbs. (43 Nm)
Tighten the bolts to 47 ft. lbs. (61 Nm)
1972 models:
Tighten the bolts to 55 ft. lbs. (71 Nm)
1973-83 models:
Tighten the bolts to 30 ft. lbs. (39 Nm)
Tighten the bolts to 44 ft. lbs. (57 Nm)
Tighten the bolts to 54-61 ft. lbs. (70-79 Nm)
To complete the installation, reverse the removal procedures. Adjust the valves to a preliminary COLD clearance of 0.2mm for the intake and 0.25mm for the exhaust. Operate the engine until it is at normal operating temperature, retighten the head bolts (loosen them slightly and retighten to the final torque figure) and adjust the valves to the HOT clearance specifications.
Hope this helps; remember to rating this answer and leave some testimonial comment about this.
Oct 13, 2011 | 1983 Nissan 280ZX
Need manual to see what size bolt is that holds on
Hi and welcome to FixYa. I am Kelly,
It appears your model number is 74370 There are 3 bolts one for each blade and the part number is 26-0671 or 260671 for the blade mount.
Part look up:
http://www.jackssmallengines.com
then enter part number 260671 $6.31 ea.
You can not use just any bolt for this. They are hardened bolts with an NF thread. If you use a non hardened bolt the blade will fly off when the bolt shears.
This bolt is available at most all Lawn Mower Parts Supply sources. Toro uses the same bolt on most all of their mowers.
If you do not have a Lawnmower Parts Supply near by, you might be able to go to an Autoparts supply source with yet one of the other blade bolts in hand and have them match the markings on the bolt head with yours so that you have the exact replacement bolt.
Any other parts for your mower can be found here:
http://www.jackssmallengines.com/help.cfm
Use the Search model window. each line below is a drop down window
Toro
Riding
74370 <- there are numerous models up to 74704
enter your model number if different.
Thanks for using FixYa.
Kelly
Apr 27, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Brake job torque spec
Caliper bolt 25 ft lbs/ caliper bracket bolt 79.6 ft lbs
Nov 13, 2009 | 2005 Honda Civic
Need new stabilizer clip/bolts for ASKO washer model W6461
Don't need those bolts except for shipping the washer. They were supposed to have been removed a long time ago.
Sep 18, 2009 | Asko W6461 Front Load Washer
Fisher Price Emerald Baby Crib Logo
173 people viewed this question
Top Fisher Price Baby Gear Experts
romney2012
Lyle Siemens
Lyle Siemens
Josh Whitehead
Josh Whitehead
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
