Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Our Keurig B30 abruptly stopped working abo...
Our Keurig B30 abruptly stopped working about a month ago and decalcification and flushing it have not done anything to improve the issue. It does not work AT ALL! Any suggestions?
Comments:
Sep 24, 2009
- The power button will come on, but the brewer will not actually work and none of the other buttons will activate. It will not brew at all, and sometimes the "drain" function that you should be able to use by pressing down on the "brew" button won't even work!
Best Solution
posted on Sep 24, 2009
Rank: Wiz
Expert
Rating: 85%, 1093 votes
At all? Are you saying it isn't getting electricity to the heating ubit because of an internal fuse might be blown right near the switch?
Comments:
Sep 24, 2009
- Are there a few screws you can remove to get at the back of the button panel? If so, take a run to an auto parts store and pick up a can of CRC electrical spray cleaner.. Take the panel out so you can fully see it and take it outside.. Look down the wires, There is possibly a wiring harness plug. They use them for fast assembly. If you can get the button bar out, Again, outdoors, liberally rinse every thing behind the buttons where the contacts are. Take care not to spray any plastics that are aesthetics or finishes. was the switches over some you can see any pieces or dirt you may rinse out. The CRCdries quickly so not to worry, Work the switches as you wash the mechanisms. Spray off the connector plug also. Good Luck and I hope all works fine in you new electrical small appliance repair business. :)
Ned
Was this helpful?1 person thought this was helpful
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
how to I add water to the machine?
how do I add water to the Lavazza M11121 coffee machine?
Pump does not bleed easily, after bleeding does not build up pressure to force the water past the...
(More)
Pump does not bleed easily, after bleeding does not build up pressure to force the water past the non return valve in the coffee head. (new pump required)
