Question about Lionel Toys
My intermodal crane does not lift or drop down.
My intermodal crane does not lift up or drop down. The motor is running in both directions. How do I remove the plastic box from the top of the crane to see what is going on? I see that there are 4 screws on the underside, do these need to be removed to gain acess? Or is it just a matter of prying off the top. Where are the tabs located to release the cover? What should I be looking for inside once I get a look at the mechanism
SOURCE: Front panel removal instructions for
You have to remove the back bottom skirt from television in order to get to the screws for the front bottom panel. When the front bottom panel is removed there will be more screws visible, for front screen. After an afternoon of trying to get it apart, just to clean the mirror on ours, we finally got it.
Posted on Nov 23, 2007
SOURCE: Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Posted on Mar 26, 2008
  • 4 Answers
SOURCE: I have a Kenmore Wispertone
I just encountered the same problem on a Whispertone 116 last evening. If it is the construction same as mine, there are four flexible plastic retainers molded into the top cover in the gap between the pedal and the motor cover. These are on the hinged side of the pedal. All four retainers must be bent in toward the interior of the vacuum simultaneously to release the pedal. A screwdriver does not work very well for this. What worked for me were four metal bars about 3/8" wide X 1/8" thick X 1-1/2" long. The pieces I used were actually the snap-off ends of some hanging file rails I found in my basement. Insert the four bars at the four retainers. They should fit snugly as they must push the retainers past the hinged portion of the pedal. To remove the pedal, rotate the pedal up in the same direction as the spring is pushing and it should come free from the motor compartment cover at which point you can access the other two screws. I suspect Sears has a special tool with four tabs to perform this trick in the repair center. Good luck!
Posted on Mar 11, 2009
  • 156 Answers
SOURCE: Little tykes hummer how to remove gearbox
You have to take off the push nuts, but you will have to replace them.
The little tikes gearbox assembly can be purchased at this site http://www.shopjandl.com/
but if you just need the push nuts like I did you get them here http://www.shopjandl.com/0801-0226.html.
I had the same problem, so all I had to do has tighten up those screws and replace the push nuts.
Hope this helps
Posted on May 13, 2009
SOURCE: How to remove the nc6220 touchpad
hi...you lock the side please be careful you only go left and upward..good luck and hopefully help me have you..
Posted on Jul 20, 2009
I am looking for more information regarding cranes, can anyone help me?
Tasked with lifting and lowering loads of varying weights, cranes have a fundamental role in many industrial environments. Because they are able to lift weights which would otherwise be impossible to lift, they are extremely important and valuable mechanical objects. Anybody who works with cranes or has worked with them in the past knows how complicated they can be - servicing and maintenance, usage safety, and installation are just some of the responsibilities associated with the lifting medium. The team over at Cranes Direct have complied all their expert knowledge into one handy infographic, titled "Essential Tips for Working with Cranes". Whether you are new in the lifting and lowering industry, or if you have been involved with cranes for years, this infographic provides you with all the information you may need. If you're perhaps looking for something more specific regarding a certain aspect of the equipment, don't hesitate to ask me!
essential-tips-for-working-with-cranes-infographic---cranes-direct-(final1)-jqwhmdcm1eato0azc3c5i4vh-3-1.jpg
Sep 13, 2017 | Humidifiers
Changing motor mounts
Just support the motor with a engine crane, remove bolts remove old mount fit new one may have to lift engine slightly to fit new mounts .
Apr 20, 2014 | 1998 Mercedes-Benz E-Class
I have a 2003 f-250 with a curtis sno-pro 3000 hitch n run plow system. when i go to lift plow or go left or right it kills the truck. the light shut off and every thing else as soon as i hit any of the...
I think you have a problem with the plow motor grounding out. when you raise or turn plow in either direction you have to run the plow motor which is grounded out. ( as in hooking the ground and positive together directly ) the plow is on a gravity drop when you let it down by the weight itself and does not require the motor for the plow to operate. It's your plow motor or the positive feed to selonoids.
Feb 05, 2011 | 2003 Ford F250 Super Duty Crew Cab
Crane toilets don't flush properly, ball comes down too quickly
adjust the flappers-- either adjust the length of the lift line-from flapper to handle and or the flapper itself not properly mounted on tank seat
Mar 10, 2010 | Crane Plumbing Home
Oil pan removal?
Im not sure if you are talking about the motor pan or the tranny pan. But I have lifted the motor and tranny together on a vehicle to change the motor pan and mounts before. I remember having to loosen the fan shroud. Undo linkage on the tranny and make sure the shifter boots were loose. The key for me was going real slow with the crane and having extra eyes around. It was a pain but it worked out.
Feb 20, 2010 | Ford E-150 Cars & Trucks
I have a 1993 dyna harley davidson with a1340 ss motor. i will ride for a little and the motor will miss fire .pull over two the side and i can remove the coil wire to rear cyls no spark replaced coil...
ok buddy are you running the correct heat range plug as when wrong pluges get hot they foul and when the cool the come back to life so try that 1st also what colour are the plugs when you pull them out get back to me
Sep 15, 2009 | 2000 Harley Davidson FXDWG Dyna Wide Glide
My kid dropped a 4 inch length and i inch
use a snake if that doesnt work take the toilet off and look in the bottom you should see part of it
Jul 17, 2009 | Crane & Co Crane Plumbing 2430W Whirlpool...
Perfume bottle down the toilet
put a big hand ful of loo paper paper down and flush if it disappears the bend is clear. you can also lift the inspection cover outside while doing this and see what is happening there although i it is shaped like an egg it should just keep moving . some people leave more than an egg sized load behind and dont have a problem LOL . hope this helps joe
Nov 15, 2008 | Crane & Co Crane Plumbing 2430W Whirlpool...
Toys Logo
103 people viewed this question
Top Lionel Toys Experts
Traindoc
Level 1 Expert
Are you a Lionel Toy Expert? Answer questions, earn points and help others
