Question about Moen Accessories 90522 Chrome Tub Drain Half Kit with Lift-N-Drain Ass
I live in a modular home. My tub drain isn't a
I live in a modular home. My tub drain isn't a pop up or anything with a closure, we only use a stopper. We are tring to replace the drain with the proper tools but it refuses to unscrew all the way out. Is there a nut under the tub that needs to be held stationary or what?? We're at a stand still.
  • 54 Answers
There is no nut but the drain piece is threaded. Carefully cut out strainer with a jab hack saw.
Posted on Sep 26, 2009
How do I take the drain plug off so I can clean it out?
If the drain is one like this
https://www.plumbingsupply.com/images/foot-actuated-tub-closure.jpg
You can remove it by unscrewing the cap anticlockwise. You may need vise-grips. Pad the jaws with masking tape.
If it is one like this
http://www.mustknowhow.com/wp-content/uploads/2010/04/drain.jpg
You must remove the center screw and strainer. In extreme cases you may need to remove and replace the drain flange with a special wrench
http://images.meredith.com/diy/images/2009/02/p_SCP_167_08.jpg
In some locations there is no center screw to the strainer, which is all one piece with the flange. These cannot usually be removed without access to the big nut on the underside of the tub
More info here
http://www.familyhandyman.com/plumbing/drain-repair/unclog-a-bathtub-drain-without-chemicals/view-all
May 08, 2015 | Home
I just had a Maax Living tub installed but did not receive a manual. I searched the Maax website but could not find the answer I need: if I accidently push the drain, the water starts draining but I cannot...
The drain may have been installed incorrectly. It should not be that easy to "pop" open. In normal operation, you push it down until it latches in the closed position. Afterwards, you push it down to unlatch it and start draining.
Feb 08, 2015 | Maax Plumbing
The microwave works at times and then does not work. What is wrong? a Switch?
Full closure of a microwave door is a serious safety item. Check the door for full closure. Is there anything in or on the hinges that might resist full closure. Check the latch mechanism for foreign objects even food on the latch. Also check around the sealing point around the entire door and mating seal. Closure should be a distinct snap.
Feb 20, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
My ac leaks in side my modular home only when its on
Check the drain tube's not blocked and the drain pump isn't clogged. Check the filter's clean
May 04, 2012 | Heating & Cooling
I replaced the door latch on my whirlpool dryer and when I turn it on and it runs for a couple of minutes the dryer pops open
Hi Don,
This could be as simple as an alignment of the latch. It just may be that it isn't catching properly. See if you can loosen the screws/bolts and settle the latch a little closer to the closure. That should solve you trouble
Joe
Sep 07, 2011 | Whirlpool Dryers
Dishwasher will not drain
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 11, 2009 | Dishwashers
Will not drain water out of tub
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 26, 2009 | Kenmore Dishwashers
Aqua glass whirlpool tub leaks. looking for closure caps to close off the jets for good.
To my knowledge there are no closure caps for your tub; you can however purchase new jets with new seals if the tub is leaking through the jets.
Aug 29, 2009 | Home
We have an American Standard lifetime whirlpool tub with the pop up drain (white). However, the pop up drain plug has always been tempermental but now it no longer wants to stay down.
Chances are that the drain assembly was not part of the tub but a 'generic' plumbing part. Is this pop up drain the type that you push down and it clicks closed and push down and then it pops up? It unscrews from the drain fitting and you can get a replacement at a big box store. A better pop up replacement is one called a Rapid-fit. It drains faster.
May 12, 2009 | American Standard Evolution 1599.205.020...
Washer will only fill halfway
hello, 1 possable problem a pretty common problem and the solution is blindingly simple. It’s caused by the drain hose siphoning water out of the washer tub. There are two common causes for siphoning and I’ll explain both of them below.
drain-min.jpgOne cause for siphoning is simply that the drain hose discharge is below the fill level of the washer tub. This picture shows the minimum drain height needed to avoid siphoning.
Another common cause for siphoning is not having an air break between the drain hose and the drain stand pipe. Usually, this isn’t a problem since the drain hose diameter is usually much smaller than the diameter of the drain stand pipe. But sometimes folks will inadvertently remove the air break by duct taping the drain hose to the stand pipe. They might do this because the drain hose keeps popping out of the stand pipe when the washer pumps out the tub. Other times, the drain hose might fit into the stand pipe with a tight interference fit.also check your water inlet valve filter/screen make sure its not clogged.
Apr 09, 2009 | Kenmore Washing Machines
Moen Accessories 90522 Chrome Tub Drain Half Kit with Lift-N-Drain Ass Logo
101 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
