Question about Hoover HDC6 Electric Dryer
Just pumping out cold air
Dryer does not seem to be using hot air to dry anymore. went looking for a fuse for heater element, but couldn't find one. Any body out there know if there is a fuse or is this more serious?
  • Hoover Master
  • 7,482 Answers
There is no fuse...
Sounds like it could be your thermostats and or your heating element that needs replacement
Posted on Sep 25, 2009
Wont get hot and dry clothes
If the dryer runs the same as before except it will not get hot then check your heating element that is more than likely your problem.
Sep 04, 2012 | Maytag MDG6400 Atlantis Gas Dryer
My Bosch electric dryer wta3510uc heats but doesnt get hot like other dryers. why is that? it takes over an hour to dry or even more and it use to seem much hotter. clothes are still cool and damp after 40...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Jul 30, 2009 | Estate Dryers
My dryer is not blowing hot air anymore
most likely the thermal fuse 279769 or the heating element 279838 if this is a newer dryer...whirlpoolpartssurplus.com
Jun 23, 2009 | Whirlpool Dryers
Blowing cold air-no heat to dry clothing-how do i know it is the heating element that is bad?
you have to see if you see any broken wire on it,also there should be a fuse on the top left side of the heater box at might be bad,let me know what you find-mike
Apr 15, 2009 | Dryers
MY DRYER DOESN'T GET HOT
There are a few things to check out. 1. This may seem obvious, but make sure your temperature switch is not pointed to "fluff/air dry".
2.Is the motor running? It has to, to dry three. Make sure your door switch is engaging properly.
3. If you are so inclined, unplug the power cord and remove the back lower panel of the dryer.) Remove the vent pipe & allow the unit to run, if you now have the proper heat this means the vent is block, check the outside vent hood, the sometimes have a screen just inside that will block up not allowing for air flow.
Check all wire connections to make sure they are attached properly. If they are burned or worn, they need to be repaired or replaced. Any disruption of the circuit to the dryer element will stop its functioning.
4. Next, look for the thermostat.. which is usually a small circular metal device attached to the dryer element canister. Unscrew it and shake it slightly. You should hear a clicking noise. This should indicate that your thermostat is working (but not always!).
5. Remove the heater element canister cover and check to see that there is continuity of the element wires (no breaks). If there is a break, it needs to be repaired of replaced. You can take the heater element to a repair shop and be tested for current. If you think that you can repair any of this on your own, then go for it. Always think safety first before proceeding
Feb 21, 2009 | Kenmore Dryers
Dryer not drying clothes
If you remove the lid you will see the element on top of the drum.
There are a couple of thermal cutouts mounted on it which would be the first thing to check.
Also look for the obvious broken wires etc.
Also can you hear the fan running when machine is in operation?
Hope this helps & thankyou for using Fixya.
Feb 20, 2009 | Hotpoint Aquarius WD640 Front Load...
Conia CCD4501 cloths dryer not blowing hot air anymore
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Jan 13, 2009 | Conia DVD8500 DVD Player
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
Dryer not drying clothes.
examine all the ducts in the dryer, and the fan and fan housing for lint. Lint buildup stops the air exiting the dryer
cant get out
cant get in
no air
no dry
surprising how much lint you can get out of a dryer
UNPLUG
71fdf37.jpg8010907.jpg after clearing all the lint,
examine devices::
thermal fuses, thermostats and the heater element for conductivity.
remove 1 wire from each to isolate from the circuit, test with ohmmeter or battery and bulb, replace wire
when cold all devices in the heater circuit should conduct
when cold a small device in the motor circuit that looks the same as all the other devices, a cool down thermostat does NOT conduct
96b3438.jpg9a18db2.jpg devices: may all look alike,
to open dryer case read any of the 'changing dryer belt' questions or the good instruction manual posted by Joks
Oct 29, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Hoover HDC6 Electric Dryer Logo
193 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
