Question about Garden
Have a Poulan blower/vac used once bought new this Spring. Tried to start it twice recently and it absolutely will not hit a lick. Tried spraying starting fluid but nothing works
  • 62 Answers
NEW SPARK PLUG AND NEW FUEL MIX
Posted on Sep 24, 2009
New Poulan Pro blower/vac won't start
I would back the carb screw out 1/4 of a turn. And yes 15 pulls should start it.
Nov 12, 2013 | Poulan 25CC Gas BlowerVac
My poulan-pro leaf blower
Does it start if you spray starting fluid into the air cleaner? Try it and let me know.
Oct 30, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Had no spark so ordered a new coil - installed new coil and still will not start - this machine is not old and only used about 15 hours total - seems quite expensive to blow a few leaves if I have to...
Did you have a shop do a compression test on the cylinder before you bought the new ignition module. If the compression on the cylinder is not at least 100 psi, A new ignition module would not have helped. May be time to get some more money together and bought a better one. You get what you pay for.
Good Day.
Oct 27, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Sep 30, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan leaf blower won't start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Sep 26, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
The leaf blower won't start and I did change the spark plug and last time it run for like 30 sec. before it shut down again.
Main cause of small gasoline engine failure is carburetor clogged. Try spraying carburetor cleaner into carburetor and intake. Check if unit has air cleaner. If engine starts briefly with cleaner then carburetor needs manual cleaning. Carburetor removal and overhaul.
Jul 10, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
POULAN 200 mph blower. New spark plug last fall.
You will need to check the fuel lines for cracks/breaks.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
(NOTE: If the carburetor parts are more than four years old, and depending on the use, you will need a new carb. kit if the cleaning doesn't work.)
If you need further assistance, just let me know.
Jim
Jun 15, 2009 | Poulan Garden
Poulan pro leaf blower doesn't start
As long as it has fire, all you need to do is:
Check the fuel lines for cracks/breaks. If this is o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Make sure the small screen in carb. is free of debris.
If you still have trouble after this, then you will need to buy a carb. kit and replace all appropriate parts.
Jim
Jun 06, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I had spark and compression. It was definately a fuel delivery problem as the primer bulb was not filling with fuel. I tried taking off the carb spraying it with cleaner, blowing compressed air through the fuel lines and removing the fuel filter.
Finally I took the top of the carb off (the two screws holding the primer bulb on). I sprayed the ports with carb cleaner and used compressed air to blow through the fuel inlet and outlet.
When I put it back together, the bulb filled with fuel on the first prime, and the engine fired up on the first pull. The throttle response is also much snappier than it has ever been.
I'm not a mechanic, but it worked for me. Hopefully it will help someone else.
Oct 20, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
94 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
