Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Plumber thought faucet was bad; no water came out of moen
Contractor installed shower, tested the fixture and no water came out even though there was water to the mixer. He didn't have the cold line installed yet. I read the manual and it said both lines had to be ON before unit would work. Will see how it goes tonight after I tell him.
    President:
  • 3,433 Answers
Water came out because valve wasn't center. that is the reason they said both lines needed to work properly. It sound like a pressure differential mechanism.
Posted on Sep 24, 2009
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    We just installed a moen shower faucet. Water pressure is almost nil. It's a brand new house so debris and other things should not be a factor. When the faucet is removed the water pressure is back...
    There's a clog in the shut off, line to faucet, or in the faucet cartridge ... hook it up to a supply tube on another faucet, it connect to a garden hose to check if faucet is problem.
    Water pressure problems on following link:
    http://waterheatertimer.org/Low-water-pressure.html
    Nov 08, 2017 | Moen 3175 Legend One Handle Shower Faucet...
    Single head scald resistant shower fixture. Needs new cartridge. Took screw out plumber cannot get handle off. Called moen it is a 2001 model. But they said cannot help me. Need to cut off and get new...
    There are several products that can be used to loosen the corrosion holding the handle in place. The Works is one product along with CLR. The easiest fix is to wrap a washcloth soaked in distilled white vinegar around the handle. Let it soak for 20 minutes at a time. It could take a half dozen times or more, but eventually it will work. Rinse the faucet after each application to remove the acid. You may also need to use this process to remove the Moen faucet cartridge.
    Oct 01, 2010 | Moen 3175 Legend One Handle Shower Faucet...
    Leaking shower head
    Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
    Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
    Water keeps going cold in shower melnoll@msn.com
    If water gets cold at all fixtures Its most likly the dip tube in the water heater they make replacement dip tubes but the water heater usally dosnt last but a yr or so after the tube gos bad. If the problem is only in the shower its probibly the shower valve.It could be a fixture capped off wrong, or water lines crossed som where in the shower end of the biulding.
    Dec 02, 2009 | Moen TL3450/3600/3371 Kingsley Handle Tub...
    Moen kitchen faucet. I changed the cartridge but
    Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
    Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
    New house . tub wont turn off. water has a steady
    The plumber soldered in the faucet without removing the cartridge, the o-rings are melted. Have the builder replace the o-rings.
    Mar 15, 2009 | Moen 3175 Legend One Handle Shower Faucet...
    Shower head leaks water when water is turned on
    take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
    look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
    Jan 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
    Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
    155 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
