Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Not printing envelopes and printer locks up
Suddenly we are unable to print envelopes from our multi-use tray on our Canon 6550. The envelopes do not feed, the printer beeps (as if out of paper) and then the printer freezes up and must be unplugged and replugged to print anything (other than the envelopes which never print). Regular letter-size paper feeds through the tray and prints correctly.
    New Friend:
  • 28 Answers
You may have a jam or run out of ink, check both? Download instruction manual on your computer and read it!
Posted on Feb 26, 2012
  • 78 Answers
Use a small flash light and check for any debris blocking the roller from the tray...
Posted on Sep 24, 2009
How do I print on A4 envelope with Canon ir 4080i photocopy/printer machine?
in printer just put your envelope portrait position, then set your paper setting into envelope size in your laptop or PC and just print it
in photocopy machine just adjust the input tray into envelope size than put envelope printed face up, and just print it
Feb 18, 2015 | Canon Office Equipment & Supplies
Canon printer MX310 works fine, but I have never used before to print envelopes. Once i set it for a particular envelope, where do I insert the blank envelope. Have tried every conceivable...
canon.gifPrinting an Envelope
For details about how to load an envelope into the printer, see the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. When loading the envelope in the rear tray, orient the envelope so that the flap is on the left and the folded surface is facing down.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the Main tab.
4. Click the Page Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape for Orientation.
6. Click OK.
When you execute print, the information is printed on the envelope.
Jul 21, 2011 | Canon PIXMA MX310 All-In-One Printer
I cannot print from the Stack bypass tray. I have tried many adjustments. This leaves me unable to print envelopes and using letter head. What could be wrong?
First of all select the paper select button for the bypass tray on the control panel after putting envelopes in the tray. It will then say select paper size. Press the RIGHT arrow until COM 10 or executive comes up and the select OK. Then print what you want . You have to look at the printing properties on the driver to make sure you have auto or the bypass tray selected
May 10, 2011 | Canon imageRUNNER 1023iF Black and White...
Printing #10 Envelopes in a Minolta CF 2002
You can print #10 envelopes in ANY printer. Use the bypass (or multi purpose tray).
May 04, 2009 | Minolta CF2001 Copier
Canon imageclass d761 printer
im gonna guess your using word under tools then printer you have to select the tray the env is in
Nov 25, 2008 | Canon imageCLASS D761 Copier
Address envelopes correctly
I'm running Vista and I thought there MUST be a way to print envelopes! So, this is how I figured out how to print envelopes perfectly! No doubt, this would be how the manual would instruct, but it's apparent that none of us are able to locate our printed copies, right? Guilty as charged!
Slide paper tray out; remove paper you have loaded in your tray. Set envelope in tray (face down, with top of envelope flush left) and adjust both side bars (designated as "1" in paper tray diagram - visible when all paper is removed from paper tray) so that they are flush against envelope. Slide back bar (designated as "2" in paper tray diagram - visible when all paper is removed from paper tray) so that it is flush with edge of envelope. Click print.
Believe defaults are set to #10 envelope. Envelope options - check / click on the following: face up, clockwise rotation and "Feed from" Auto Select. Click on / highlight the 5th envelope depicted in the top row of envelope examples.
Jun 16, 2008 | Brother Multi-Function Center MFC-240C...
Canon Imageclass MF 6550 - Can't print labels... help!
I have called canon with this problem more than once and they keep telling me that I am using a "paper" that is not supported. I finally gave up and ended up telling them that I am now going to use my cheap HP printer because it can do what it's suppose to.
May 05, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Envelope Feeder is not accepting the command
> Home > Support & Drivers > Knowledge Base
Solution --> Phaser 4400 Printer: Printing envelopes
Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
Guidelines for envelope printing
  • Use only paper envelopes.
  • Do not print on the back of the envelope.
  • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
  • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
  • Envelopes may wrinkle depending on weight and stiffness of the envelope.
Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
  • Select faceup.
  • Clear Clockwise Rotation.
  • Select the feed method with the image centered and the stamp on the envelope to the upper left.
caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
  1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
    • Place the side to be printed faceup.
    • The top of the envelopes should be toward the left of the printer.
Feb 19, 2008 | Xerox Phaser 4400B Laser Printer
Envelope back is dusted on front of envelope
All I can think of is to Check paper type on bypass is set correctly on printers operations panel.
Dec 07, 2007 | OKI C5100n Laser Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
102 people viewed this question
old marine
old marine
