Question about Samsung Glyde SCH-u940 Cellular Phone
I stwiched my phone to nam2 and it says initial programming needed could any one tell me whats the code for the samsung messenger
Switched to NAM2 and do not know the lock code.
Dial *22899 and press SEND to program the phone.
after it has finished downloading the programming information, the phone will reset.
The Lock code will now be set to the last 4 digits of your phone number.
when you have finished, be sure to switch back to NAM1 and dial *22899 again to re-program it.
Sep 30, 2009 | Samsung SCH-u740 Cellular Phone
Stupid code
If you can switch to nam1, that is your active phone number. If its asking for the code first the code will be 000000 or 0000
Jul 31, 2009 | Samsung SCH-u740 Cellular Phone
I DON'T know what is initial programming is?
initial programming occurs when your phone needs a second roaming based and if you accidentally change the NAM settings of your phone to NAM2. the default NAM settings of your phone is NAM1.
Jul 01, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Can't unlock Samsung Hue?
samsung hue r500 and having problem when accidentally or curiously selected nam2.. after it powers off then on again by itself, it brings u to a little window (initial programming needed) and the enter code (password). as you will notice none of your 4 digit passwords will work, default wont work, u have to push the back or end call button to get away from the enter code window. enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to make sure.
hahah
May 08, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Initial programming needed
Dial *228 and press send. Listen for the prompt and press 1 to program your phone. Remain on the call while your phone is programmed (could take up to 2 minutes). Do not hang up until you hear, 'Your phone has been programmed successfully."
Apr 22, 2009 | Samsung Glyde SCH-u940 Cellular Phone
How to bypass phone 4 digits lock code or how to get the lock code if it wasn't the last 4 gigits of the phone number and I don't know what it is?
If you put your phone on nam2, like i did, you need to call samsung's hotline. customer service can provide you with the nam2 access code. Verizon would make you pay 59.99 to get a reflash to basically do the same thing. samsung's number is on the back of your phone
Dec 28, 2008 | Samsung SCH-U470 Juke Cellular Phone
I have a Samsung U520 and I accidentally activated NAM2. Now my phone does not work. When I try to deactivate NAM2 it asks for a password. Can you help? It needs a 4 digit code. It also states Initial...
hi sir have you done restore factory settings firstThe Nokia 2160 series hand portable CMT uses an EEPROM NAM that can be programmed directly from the standard user keypad. In order to access the
NAM, you must enter the special access code currently programmed into the
phone. Once the programming mode is accessed, NAM parameters are loaded
by entering them into the display and "storing" them to selected memory
locations. Be sure to obtain all parameters before proceeding.
EASY NAM PROGRAMMING
1. Turn on phone.
2. Enter the Easy NAM access code. Access code is: *#639#
3. Verify the display now reads "Cellular Number" and enter the 10 digit
MIN for the phone.
4. Press the softkey under the word "OK" in the display. If less than 10
digits are entered an error message will prompt you to reenter the
number.
5. Verify the display reads "Enter code" and enter the five digit SID
followed by four zeros. (Example 001750000 is a SID of 175 followed
by four zeros). An error message will display if an incorrect entry
is made. Do not add more than four zeros to the code.
Note: Change the Lock code by adding a pound sign and new lock code after
the code. (Example: 001750000#7788. Lock code = 7788).
Change the Language code by adding a pound sign (#) and new
language code after the code. (Example: 001750000#2. Language = 2)
Language Code: 0 (default) = English, 1 = French, 2 = Spanish,
3 = Portuguese
Change the Lock code and Language code by separating each set of
numbers by a pound sign. (Example: 001750000#7788#2). The SID =
00175, Lock code = 7788, Language = 2 (Spanish).
6. Press the softkey under the word "OK" in the display.
7. The display will tell you t
Sep 10, 2008 | Samsung Cell Phones
"initial programming needed" problem
I can not guarantee this Punksk8er but, i did the same thing with my phone by switching the battery with my mother's and I ended up with the initial programming needed sign. This is how i fixed it...
Go to...
>Menu
Select the option...
>Settings
Scroll down to...
>Phone Settings
Then Select the option...
>NAM selections
There you will see the options
>NAM1 &NAM2
Mine was on NAM2 and i switched it to NAM1.
The system restarted and the error "initial Programing needed" went away.
I am no phone expert or anything so I don't really understand how it works but i hope this helps you out dude.
Feb 01, 2008 | LG VX3300 Cellular Phone
Samsung Glyde SCH-u940 Cellular Phone Logo
342 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
