Question about Mackie 1604 Vlz3 16 Channel Mixer
Vlz 16 blowing fuses - Mackie 1604 Vlz3 16 Channel Mixer
  • Mackie Master
  • 5,603 Answers
This is a serious problem. If you spilled liquid into the unit, expect serious internal damage.
DO NOT keep replacing fuses as you may be creating further damage.
Best scenario is if the input to the power supply has shorted diodes or capacitors. Worst is that part of the circuit board has been burned.
Taking it to a shop or having electronic skills and opening the unit up to troubleshoot are the options.
Posted on Sep 24, 2009
Where I find power transformer of mackie 1604
You should be able to get this directly from Mackie service. Please see the link below for the contact information. Please note that the exact model number adn serial number will be required to insure that the correct transformer is obtained. There are a few variants of the 1604,
Dan
Link: http://www.mackie.com/support/service/index.html
Jul 19, 2011 | Mackie 1604 VLZ 3 16 channel Analog Mixer
Transformer appears dead no lights no output
Transformers are VERY reliable. Look for another problem... rectifier, filter caps, fuses, regulators. There is a main fuse and if it is blown, repair the unit before applying full power. To test the unit, put a 40 watt light bulb in series with the hot side of the power cord. The light will act as a resetable fuse and will light when there is a short within the mixer, thus absorbing most of the voltage. Enough current will flow to diagnose the problem.
Jun 16, 2011 | Mackie 1604 VLZ 3 16 channel Analog Mixer
Channel 16 to 24 the "solo" buttons do not
This is probably a loose or damaged cable within. These channels I believe are grouped in groups of eight, so two groups would be dead for this function.
Here is your schematic:
http://elektrotanya.com/mackie_1642-vlz-pro_full-sm.rar/download.html
Feb 01, 2011 | Mackie 1642-vlz3 (16-ch 4-bus Compact...
Do you sell or know how i can get a manual for a 1642 vlz just bought brand new. Cheers G
The manual can be downloaded from the link below.
Dan
Link: http://www.mackie.com/pdf/archive/cr1604_om.pdf
Jan 10, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Some of my channels have stopped working 4-5-6-13-14-15-16 mackie 1604 vlz pro
If you havent ground looped the chanels. Most of the time the chanels need to be cleaned.
Dec 01, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
I need a part. a fader for a SR24?4?2 VLZ PRO.
Removing all the knobs from a section of the board where the bad fader is can be a hassle.and sometimes some of the nuts from jack or screws from some connectors.
You are probably better to order the part from Mackie to get the exact part. Most are made by ALPS and I get ones for some equipment from DigiKey.com or Mouser.com. However, it does take a bot o knowledge to get the correct part and sometimes requires cutting the shaft of one that is too long.
One MUST match the mounting holes, resistance value, length of throw AND the "taper". Yours will probably be a standard "Audio taper" for the main output.
May 04, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie 1604 Vlz3 16 Channel Mixer Logo
183 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Mackie Music Expert? Answer questions, earn points and help others
