Question about Samsung SGH-D900 Cellular Phone
Cant seem to be able to put the ringing tone on just the vibrate or silent mode?
How to removed or turn off the vibration on the phone?
What phone you have would be useful to know but for
Android : How to Turn off Sound and Vibration in Androids Keyboard
Iphone: If you set the iPhone to vibrate in silent mode, it still makes an audible buzzing sound that may bother or disrupt others. If you need your iPhone to stay completely quiet, temporarily disable vibration. You can turn off vibration when silent mode is on, off or both. Tap the button next to "Vibrate on Ring."
Blackberry:
Turning vibration on my mobile phone on or off
  1. Find "Notifications" Slide your finger down the display starting from the top edge of your mobile phone. ...
  2. Turn vibration on or off. Tap the indicator next to Vibrate to turn the function on or off.
  3. Exit.
Nov 09, 2015 | Cell Phones
Got a telstra easy touch dicovery 3. Cant turn silent mode off
Hi Shannon,
TELSTRA EASYTOUCH
DISCOVERY 3
SYMPTOM = No incoming ring or alarm tone
RESOLUTION:
- Check the ring tone and ring volume settings under
Profiles
- Check the handset is not muted (Long press the #
key
Apr 30, 2014 | Cell Phones
Not able to put the Nokia E5 phone in Vibration Mode
When you get to your phone's setting, select profiles. Amongst the list of profiles, determine which of them you want to use to activate your vibrate mode.
When you have done that, scroll to that profile, select 'options', then select 'personalise'.
In the personalise sub-menu, you are allowed to set the features of that mode to your desire.
In the ringing tone, select no tone, in the ringing volume, reduce the volume to zero. When you are asked if you want to set the ringing volume to the maximum, select yes/ok.
In the vibrate option, select yes/vibrate.
In the message tone, select no tone.
For other sounds and tones, select no tone.
When you are done, REMEMBER TO SAVE IT.
Then go back and activate that profile.
It is advisable that the profile you use for this though, is your 'silent' profile.
Hope that was helpful?
Have a wonderful day.
Jun 20, 2011 | Nokia E5 Cell Phone
My Sony Ericsson W890i, I cant set the alarm with a vibrate tone?
You go to:
main menu->settings->sounds & alerts (or something like that)-> vibrating alert
Open this and you will find 3 choises (on,on if silent, off). Choose "ON".
Then vibrating alert will be always turned ON,even if You putt it on "silent".
Sep 05, 2009 | Sony Ericsson W890i Cellular Phone
Is there any way to mute the ring tone or put the ringtone on vibrate? While in meetings, etc. I want to leave my phone on but the ring silent. I can't seem to find how to do that on the lg xenon.
on the left side of the lg xenon you will see two buttons with two arrows pointing up and down press that and keep pressing it down or it will appear and you can touch and put it on silent
Aug 09, 2009 | Xenon XEN 1510T 15.1" Flat Panel LCD...
How can i set message ring tone.
Go to menu>my stuff> tools >utilities. Scroll down > my voice.
Then press record .
To set it as your ringtone:
Go to menu, settings, then profiles. Then it takes you to flight mode, silent, vibrate, ring, and etc. On the side it says options. Select it. Scroll down to customize. Then just change the ringtone or scroll down to message tone.
Jul 25, 2009 | Pantech Matrix Cell Phone
I have a LG VX8360 and I can not figure out how to put the phone on silent or vibrate. I need it this way at work please help
If you open up the phone and hold the * down for 3-4 secs it will go into a slient/vibrate mode. do the same to get back to normal mode
May 30, 2009 | LG VX8300 Cellular Phone
How to exi silent mode
Press the # key and hold. This activates and deactivates the silent mode.
Sep 29, 2008 | Samsung SGH-U600
How do i yurn my fone off silent
go to tone setting-alert function-select ring only.
Jun 10, 2008 | Samsung SGH-D600 Cellular Phone
Silent Turn-On
Hi:
Before turning your phone off each time, reduce your phone's volume to 'Silent'. Each time you turn your phone on, the tone will not sound. Once you turn your phone on again, raise the volume again to hear the ring tone. You can also leave the volume in the 'Vibrate' mode, and it will vibrate each time you turn it off or on.
Tgillen4
Apr 22, 2008 | Motorola Mobility TracFone C139-4 Cellular...
Samsung SGH-D900 Cellular Phone Logo
51 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
