Question about Fire Magic FireMagic Grill
Where can I download a manual for an e790 firemagic slide in grill
  • 388 Answers
Http://www.homeclick.com/web/catalog/product_detail.aspx?pid=90873&sid=IXqddHZnH5xjpS0lz2EI6Nd4b%2brWnQXoDnsHnT2s1yGuq7bUTO2z%2fg%3d%3d
You can try the above link or you can try www.FireMagicStore.com
you should be able to get a manual from either of these places
Posted on Sep 24, 2009
Your Question Preview Fire Magic A790i Logo Problem with A790i Firemagic a790i flames pop and knobs get hot Posted by Author imageGuest on 3/24/2013 Details not getting good pressure to all 3 b
It sounds as if the burners may not be properly seated on the valves. Instead of all of the gas flowing into the burners, some of the gas is escaping behind the front panel and creating a fire behind the front panel which would heat the valve shafts and melt the knob inserts. This call also be caused by partially blocked burner venturi and valve orifices.
Check to make sure the end of each valve is completely inside of each burner.
Mar 24, 2013 | Fire Magic A790i
My digital thermometer on my brand new echelon 660 has an erradic display of the actual temp for all 3 zones even after calibration. The temp probes are not in contact with anything to short it out. I...
Steve, these thermometers have been plagued with problems and short of a total replacement of the thermometer module, there is not quick fix. Since yours is new and and still under warranty, contact the R H Peterson Company, the manufacturer of Fire Magic Grills (800) 332-3973 and ask for Technical Service. As they are the ones who make the determination on a total replacement of the module or not. Be sure to have the grill's Model Number and Serial Number handy, when you call.
Thanks for choosing FixYa.
Aug 03, 2011 | Fire Magic FireMagic Grill
I have a firemagic 6 burner grill with 3 ignitors- 2 of my ignitor wires came loose somehow - wondering how do i reconnect them? Tried to push them into the back of the ignitor but wont just plug back in.
What you're trying to do is correct. It's the only way the ignition wires attach to the Ignitor Module. Are the push-on female connectors on the end of the wires still intact? If not, that's the problem.
Hope this helps you.
May 08, 2011 | Fire Magic Regal II Gourmet (NG)...
Firemagic ECHELON E660i - flames shoot out around the orfice heat stressing the front panel, making controll knobs too hot to touch and allowing flames to shoot up onto the lid, grill is 20 months old. ...
Has this been happening since new or did it just start?
Either way, you need to check the burners for proper placement over the burner orifices. Are they fitted snugly? Are they running perfectly parallel to each other and resting properly on the back inner cabinet of the grill, in the burner holders.. Also, make sure that the orifices are screwed in tight and are not clogged. Check the burners for clogs and if found clean out the burners, by gently tapping them on a firm surface.After doing that, turn the up so the orfiice end is down and see what falls out of the burner(s). If the burners or orifices were clogged or the orifices not tight, it may be backfiring into the control panel. This can also indicate a gas pressure problem.
If you can remove the front control panel (remove the burner knobs, first) you can access the gas fittings to each burner's control knob and it's gas fittings. Without lighting the grill, turn each burner ON and check for leaks with soapy water at all the connections. Then turn it off and check for leaks again.
If you found any leaks, check each fitting to make sure it's not cross threaded and re-tighten.
If none of the above solves the problem, contact the Fire Magic Dealer you purchased it from or the R H Peterson Company (they make the Firemagic Grills), as it may be a manufacturer's defect. They have an excellent warranty program. For a warranty claim, you will need your Proof of Purchase.
Hope this helps to get you back grillng>
Feb 21, 2011 | Fire Magic FireMagic Grill
E790 FIRE MAGIC NOT GETTING HOT ENOUGH
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 01, 2010 | Fire Magic Echelon E790I-2A1N Stainless...
How to shield wood cabinet from heat
You should not have flammable materials near the grill to begin with, but if you do. You will have to have a metal insert made for the grill to sit in.
Jul 05, 2010 | Fire Magic FireMagic Grill
NEED THE INSTALLATION ROUGH FRAMING DIMENSIONS FOR THE FIREMAGIC, CHARCOAL, BUILT IN GRILL.
Here is thier web page for the deminosns you need to frame in the grill.
http://www.bbqparts.com/FireMagic.htm If this does not help let me know.
Sep 29, 2009 | Fire Magic FireMagic Grill
13 year old firemagic -- rusted burners and grid. can i get replacements?
yes you can look up Atlanta Grill Services on the internet call them they can get the parts for you.
Jul 14, 2009 | Fire Magic FireMagic (LP) 14-S000C-0 Grill
How to install charcoal filter in ge microwave md# jvm1870 sk04
From the owner's manual, page 37:
To remove the charcoal filter, disconnect power at the main fuse or circuit breaker panel or pull
the plug.
Remove the top grille by removing the screws on top of the grille that hold it in place and sliding the
grille to the left (opening the door makes grille removal easier). Slide the filter towards the front of the oven and remove it.
You can download GE owner's manuals and installation instructions here.
You can order new filters by entering your full model number here.
Sep 19, 2008 | Microwave Ovens
Fire Magic FireMagic Grill Logo
131 people viewed this question
Top Fire Magic Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
john h
Are you a Fire Magic Grilling Expert? Answer questions, earn points and help others
