Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Frigidaire refrigerator. freezer part gets cold but refrigerator part does not get cold.
Check your seal around the door, also check the air vents between the freezer and the fresh food section. The appliance has to be able to transfer air between the 2 compartments in order for the fridge to be cooled.
Posted on Sep 24, 2009
Bgillespie
  • 89 Answers
SOURCE: Refrigerator not cold
It sounds to me like you have a defrost problem. Look on the back wall in the freezer about 3/4 of the way down. Do you have any frost build up? If so, for me to be able to help you futher I will need the model number of the refrigerator located on the inside of the refrigerator...
Posted on Dec 15, 2007
Master_Tech
  • 770 Answers
SOURCE: The refrigerator side is warm
is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
Posted on Feb 17, 2008
  • 1122 Answers
SOURCE: my frigidaire refrigerator does not
ONE OF FOUR THINGS IS HAPPENING,YOUR FAN IN FREEZER HAS STOPPED,YOUR DEFROST THERMOSTAT IS BAD,YOUR DEFROST HEATER IS BAD,OR THE DEFROST TIMER IS BAD,REMOVE THE FREEZER BACK PANEL AND YOU CAN CHECK ALL BUT THE DEFROST TIMER DEPENDING ON MODEL MOST ARE IN THE FRIG.,LET ME KNOW-MIKE
Posted on Jul 07, 2008
ryeisenman
  • 9 Answers
SOURCE: cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Posted on Dec 13, 2008
  • 531 Answers
SOURCE: frigidaire side by side freezer not freezing but
you may have defrost problem check see if you have frost build up in the freezer back wall
Posted on Apr 07, 2009
How cold should my freezer get on my plhs269zcb2 side by side?
Good Morning Friend,
I understand you want to know how cold the freezer should get on your Frigidaire refrigerator, model# PLHS269ZCB2. The freezer compartment should be kept at 0 degrees Fahrenheit or lower. Hope this is helpful.
-Best Regards-
WP
Jul 09, 2014 | Frigidaire Refrigerators
Frigidaire top freezer refrigerator will not get cold
Contact a professional. There is a restriction from the freezer section to the refrig section that helps make it cool.
Aug 04, 2012 | Frigidaire 20.6 cu. ft. Top Freezer...
Freezer overworks keeps everything very cold but the refrigerator below underperforms barely cold.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 30, 2011 | Frigidaire FFHT1826L Top Freezer...
Have frigidaire my freezer is working but bottom of refridge is not getting cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Frigidaire 18.3 cu. ft. Top Freezer...
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Dec 22, 2008 | Frigidaire FRT18FS6C Top Freezer...
Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
122 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
