Question about LG KC910 Renoir Cell Phone
How can i down load pic on my pc with out my disk
How do I email pics using gimp?
The GIMP is an image manipulation program, not a mailer.
After doing whatever you're doing to the image file, save it to disk. Then open up your usual email program and attach the file.
Sep 30, 2012 | Computers & Internet
When I down load videos to my Go Gear Vibe, they down load but when I go to videos, it shows NO VIDEOS FOUND.And it says it will hold 900 songs, 1600 pics, and 8 hours of videos, but the disk shows full...
To answer part of your question, the reason the disk shows full is probably because it can hold 900 songs OR 1600 pictures OR 8 hours of video. It depends on the size of the disk itself.
Hope this helps.
May 25, 2011 | Computers & Internet
Hello there - a Christmas problem i do have. I just opened up the Aluratek 10.5 frame last night and got pictures redy to load. I cannot load from PC or from removable drive. It did take 5 pictures once,...
when you deleted those files from it ..you probably deleted the root folder..and now you will have to reinstall the firmware for it ...this will be either on the disk that came with it ..or on the support site of the manufacturer..
To be sure that it is a firmware issue ..check the frame in another computer ..and see if it works...
Look in its menu and format it first if it has a format feature available...you might have contacted a virus or so..
Dec 24, 2010 | Computers & Internet
My PC does not recognize the camera and can't download the pics
Normally you need the Canon software to get the machine to recognize the camera, some other software will sometimes recognize it such as Adobe Photo, but it is best to load the drivers and software meant for your camera. If you have the disk that came with the camera, try reloading the software. It may tell you to first uninstall whats on there. if you do not have the disk, then go to:
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd600#DriversAndSoftware
and down load the drivers and software meant for your operating system.
Dec 19, 2010 | Canon PowerShot SD600 Digital Camera
Can't load more pics to internal memory,past about 100 photos
Your jpg files(pics) may be too large.
reduce them (i use 800x600.)
Irfanview is a good resize pgm(free)
fred
Dec 11, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
I want t copy photo from camera to laptop how
1. Load the software which came with the camera.
2. Run the software.
3. Plug in the camera to either the USB port or other inputs recommended by the camera maker.
4. After connecting the camera to the laptop- leave the camera power on.
5. Restart your Laptop.
6. Your laptop will identify that there is a NEW DRIVE ( which is actually the camera)
7. Open up the new drive ( Letter D or E or F) and explore.
8. Open up each picture file from the camera and save them to your hard disk.
9. Later you can switch off the camera and play around with your pics which are now in the hard disk of your laptop. You can edit and crop your pics now. You can even delete unwanted pics.
10. You may want to delte the files on your camera to enable more pics to be taken. To do that you can either delete pics from the camera itself or load up the cam. to your laptop and delete from your pc.
Bye
Nov 19, 2009 | Kodak EasyShare C160 Digital Camera
Dont have the software disk to load pics
copy your canon video to computer, and then edit.
Oct 13, 2009 | Canon Cameras
How do i down load pic on computer
Almost any computer store (even drugstores these days!) sell inexpensive memory card readers that have a connector that you plug into a USB port on your computer. Most have slots to read several different types and sizes of cards. Just be sure that the reader you buy takes CompactFlash (CF) cards that the Nikon 5700 uses. Your computer treats the card and reader as one more disk drive.
Aug 08, 2008 | Nikon Coolpix 5700 Digital Camera
Kodak easy share SV 811
I had the same problem. I use kodak easyshare software and load my pics on to that. Then put all the pics you want in the picture tray. Have your frame plugged into the computer with your usb cord. Then go up to File menu and drop down to "copy to". On my computer it is Folder "E" which is the drive the frame is connected to. Then pick from the Resize drop down menu " best for picture frame', then click copy. You will see the program loading all the pics to E drive. When done, unplug usb cord and you will see it loading on your pic frame. As easy as this is to do, I found it frustrating as well, but when it works, it is easy. Hope this helps
Aug 04, 2008 | Kodak EasyShare SV811 (8858946) Digital...
LUMMIX DMC-YZ3 LOST DISK
You don't need camera's software to download pics. Just plug it into your PC and it will recognize it and pop up a windows base window ask you what you want to do with camera pics.
If it doesn't, goto MyComputer on your desktop and click on this. Your camera will be showing up here, along with your other computer hardware drive/devices, with a drive letter assigned to your cameras memory(flashdrive) and named USB Drive or Storage or Camera.
Click on this to find a folder named DCIM, Digital Computer IMages. Click on this and find another folder named 100_PANA or similar. Click on this and these are you pics. Drag and Drop or Copy and Paste individual pics, or whole PANA folder to where ever you want them on your computer.
A better long term solution to your problem for this and every other future camera you may buy is to buy a mini cardreader that is not much bigger than a USB Thumbdrive and costs about $15. I suggest SanDisk's MobileMate SD+, available at RadioShack, Staples, or most anywhere Mem cards are sold.
Advantages: No bulky and unique USB cable to lug around. Doesn't use cameras battery power while viewing/downloading pics cause it is USB port powered. And it is small enough to fit in most camera cases along with the camera..
Apr 27, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
LG KC910 Renoir Cell Phone Logo
23 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
