Question about RCA HD61W66 61" Projection HDTV
Rca 61"hd busses for 2 secondsthen turns off.repair man said picture tube is gone out .,charged $100.00.And said tv wasn't worth fixing.tv is 2005
    Scholar:
  • 178 Answers
He is right to an extent however if you want it fixed it will cost you but the engineer should have been a little more polite about the matter
Posted on Sep 24, 2009
I have a 27" RCA TruFlat TV. Recently the picture
Something has definitely gone wrong. When picture fails, generally the audio will still play; but since the set is shutting down completely after a short time - it is going to more involved.
Firstly, anything can be fixed. The questions to ask are: 1) At what point do you stop spending money to repair a device that is XX years old? 2) How much would a replacement / upgrade cost?
Given that your set is an older SD (standard definition) with an old analog NTSC legacy tuner, it may be worth while to make the move to a digital HDTV. The picture quality will "blow away" any SD version of the same image / program that your old TV displayed. Unlike several years ago, the HDTV has come way down in price, too. A 32 inch, wide screen HDTV price starts at just $235 as results shown by a search in Google. In order to view HD signals, you'll need either 1) a plain UHF/VHF antenna (and local broadcasters in range), 2) HD cable TV service or, 3) HD satellite service. Cable and satellite providers offer SD service and for slightly more, HD service. Most people are not happy watching SD signals on an HD display - so you'll probably want to change the level of service if you're not using an antenna. Old DVD players only send SD signals, you might consider upgrading to a Blu-Ray player. Blu-Ray players provide SD and HD signals - depending on whether you insert an SD DVD or an HD Blu-Ray disk. The Blu-Ray players, like the HDTVs, have also dropped in price significantly.
See if you can find a place that provides free estimates. If not able to locate, find someone that will apply the cost of diagnostics (ask what the diagnostic fee is) to the total repair charge, and decide to either fix or replace.
I hope this helps and good luck! Please take a moment to rate my reply - thank you.
Feb 25, 2011 | RCA TruFlat 27F520T 27" TV
Tv-raster comes for 2 secondsthen gone.checkedpower supply-3caps bulged,changed no chnge.would it be in p/s?. patrick c.thank you
Check the components in thi mini board ( neck of tV picture tube ) resistors might have gone high in value.check with meter. replace. It is preferable if you open one leg and test. Keepin in circuit it may not give you correct values. Values are generally printed on the resistor body or follow the colour coding.
Aug 21, 2010 | Beko 324250WN 28" TV
The TV will bring to turn on but then it sounds like it loses power and makes a high pitch noise and powers off, no picture ever comes on the TV, the screen stays black the whole time. The TV is a RCA...
it could one of two things. The power supply is failing which is most common. Or the picture tube is gone. Both would most likely cost you more to fix than the TV is worth. Call around and get a few quotes. Good luck
Jun 02, 2010 | RCA F32650 32" TV
RCA Scenium will not turn off an has no picture
Unplug the TV for a minimum of 2 minutes to reset it then try again. If you get no picture there is a possibility the lamp is no good.
Mar 02, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Picture tube
Ur tv tube it still good.It ur deflection board have burn capacitors and transttors.The Fly back transformer is dead also,that where the noise came from.
Dec 07, 2009 | JVC HD-61Z575 61" Rear Projection...
Tood my D52W20 to Repair man and he said not worth fixing.
The repair man doesnt know RCA 's very well. The 3 x then out power led is the classic sign of the flyback and cp150 needing to be replaced. You need the flyback # 259296 and the CP150 you can get the flyback and cp150 at the following link with free step by step instructions with pictures on how to do the repair. Its very easy. Heres the link.
http://servicemanuals.vstore.ca/
Mar 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA SCENIUM MODEL # D52W136DBYX1
If it's normal television, with CRT picture tube . then it's Blue gun which went off normally its a solid state circuit which can malfunction. which is located at the back neck of picture tube blue gun out put circuit a transistor or a resistance of 470 K or 390 K Ohms can blow off. or the tube base can loose contact with the blue gun pin.
Feb 06, 2018 | RCA D52W136D 52 in. TV/DVD Combo
TV does not show picture
have you checked the bulb? they do break down. if the bulb is good condition, have it send to a repair man.
Oct 13, 2008 | JVC HD-61FN97 61" Television
Will not come on....
Hello 2154GREAT,
You have a shutdown circuit. The shutdown circuit is working as it should by not allowing the TV to come on if it has a HV (high voltage) problem. This could be caused by a shorted HV Transistor in the Horizontal section or a defective IHVT (Integrated High Voltage Transformer). In any case you will have to get a qualified TV repair person to troubleshoot and repair this problem. The problem is this is not just one of those problems that a person can say change this and the problem will be fixed. These kinds of problems require troubleshooting because other components may have gone bad too.
I hope this helps
Thank you,
Shuttle83
May 12, 2008 | RCA P61940 61" Rear Projection Television
Has sound, no picture, just color
usually if the tube has gone you will get no sound and all you will get is the telly on standby so the best thing to do is take it to repair shop and they should tell you for free what is wrong but usuall it costs more to repair than it does to buy another one sorry i couldnt be any more help
Oct 29, 2007 | RCA TruFlat 27F520T 27" TV
RCA HD61W66 61" Projection HDTV Logo
124 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
