Question about Microsoft Windows Vista Ultimate Edition
E,F,G,H drives missing
I,m using windows vista home premium.recently the above mentioned drives are not showing in MY COMPUTER.i tried to solve it by checking in PROPERTIES,but failed.what is the problem and how to solve it.i have a recovery cd with me
Hi There i had a similar probelm with my DVD drive.E: missing. it is linked to loading Itunes or certain type of mp3players software.The fix can be rectified by going into device manager and deleting the dvd drive from here open the drive + and deleting teh dvd name (dvd/drw h3606-etc). restart your machine and vista will see it missing and reload it.
If this does not work there is a file in the registery that is causing the probelm and a PC world engineer talked me through it and it solved my problem but I do not remember the file name sorry. hope this helps. George
Posted on Dec 19, 2007
  • 108 Answers
This problem may be caused by several factors, and as a result, there are many different ways to fix this. each drive letter you see can either be from a network drive, or a physical drive attatched to your computer.
1.) For physical drives (card readers, hard drives, flash drives, cd/dvd roms)- first go to control panel, open up Device Manager, and see if there is any entries for the missing drives there. hard drives and flash drives should be listed under "disk drives", cd/dvd roms should be listed under the corresponding header, and so forth. (note: if the following are hard drives, and show up as listed correctly, then it could be that the drive partitions are corrupt. to remove/add them, Administrative Tools in Control Panel should have a section called "Disk Management" that should allow you to reparititon them. I'd recommend you learn how to use it first by Googling it, if you're not already familiar with it before you try).
if all the devices you are looking for aren't there in Device Manager, it could be that there is a connection problem.
A) For Internal Devices (internal hard drives, cd/dvd roms), open up the computer, after turning it off. most standardized units have 3 screws per side in the back of the case, holding the lids in place. with desktops it's generally pretty easy to use. make sure all your devices are plugged in securely to their respectable positions the right way. if possible, for the affected drives, maybe unplug and plug them back in. check for any frayed cables/creases in the cables. when your finished, put the lid back on the unit. (NOTE: if you are uncomfortable with what you are doing, have a technician you trust do it for you. if you're using a laptop, almost DEFINATLY have a professional do it. there's very little room to move around, and you can fry circuit boards quite easily by touching them)
start the system again. if you see the drives in question, everything is fine and working. if you don't, you may have to consider the possibility to replace them.
b) for EXTERNAL physical devices ( card readers, portable flash drives) make sure the devices are plugged in, and that the USB ports they are plugged in to are working and fully functional. if they are, make sure the contacts on the usb plugs, and the ports, aren't dirty. use a rubber eraser to *gently* clean them if they aren't. also, make sure if you are using a powered hub, or if the devices use power cords, that they are all plugged in.
if they still don't work after this, you might want to consider replacing them.
hope this helps.
Posted on Dec 17, 2007
Vista home premium missing help files
Dont worry if you are missing help files...........just follow these steps...:-
1) get to someother computer which have windows vista premium running. try to find help files in c:/windows directory.
2) Once found copy it into usb and copy those files in your system at the same location from where you have copied them in other computer.
3) Restart system and its done.
Other way is to use vista recovery disk to copy system files ...
Hope it works well for you.........
Dec 24, 2010 | Microsoft Windows Vista Home Premium...
My Windows Vista computer keeps freezing up
Go to start click on Run type in the run dialogue "cmd"
In the black DOS box type CHKDSK C: /f
It will tell you that it is not able to perform this operation until next reboot. Then reboot this will check the disk to ensure you have no bad blocks or sectors and if you do it will fix them. If this does not work look below
2nd Recommendation:
Restore Windows with your CD provide by your OEM.
Warning you will loose data. If this does not resolve the issue you potentially could have a Hard Drive issue and you might need to replace it.
Sep 22, 2009 | Microsoft Windows Vista Home Premium with...
Windows.old folder
thanks for mail me. for this u can go to my computer and then find out tools which is status bar in ur computer. then click tools> folder option> unchecked from hide files and forder/ show file extension/ and last is show operation system file.when asked yes/ no then click yes and apply. at this time u will get any file from ur pc. thnaks
Aug 08, 2009 | Microsoft Windows Vista Home Premium...
Aspire 5610z card reader doesnt show up. Vista home premium
Did you ever solved your problem? I noticed the above response is just a spam ad.
I have same problem with Aspire 3680. I recently replaced the HDD and reinstalled Vista Home, all drivers from Acer has been loaded. I even updated the BIOS, updated Vista service packs and all patches.
Sent email to Acer, but of course they want $60 per 1/2 hour. And from the past experience it will take about 2 hours on the phone. Also they have no support forum, and support sucks.
So I'm still stumped. This SD problem with Acer is the only one I couldn't resolve of all brands I've worked on.
Jul 19, 2009 | Acer Aspire 5100 Notebook
Missing boot manager
go to system bios (using F10 key on the start "Commanly") then press F9 for restore defaults, and insert the Bootable Vista DVD into the drive, it will solve your prob.. otherwise in bios mode make sure that all the drives (HDD & CD/DVD Rom) are properly installed.
good luck
Jun 19, 2009 | Tablets & eReaders
Drive not recognized under Vista Home Premium 64-bit
I have seen drives not recognized for a few reasons. Bad drives, drives not jumpered correctly or full-disk encryption was used on them. Here are my thoughts:
Try making sure that the drive is jumpered to Master. Should be a jumper on the back of the drive.
Make sure you did not encrypt the hard drive using full disk encryption.
I use an USB IDE drive enclosure when recovering customer's data using a Vista computer and have not had any issues other than the ones mentioned above.
Let us know if this helps or what you find out.
Mar 31, 2009 | HP Computers & Internet
Some USB-connected devices don't show up as drives
Hey Kunal,
This is not unusual windows will only recognize the standard memory cards not any custom ones or inbuilt ones. For example if your device is using a SD memory stick it will show up in explorer however if you are using a device that has a copyright or custom it wont. I am surprised the digital camera is doing the same thing as thy use mmc cards which are standard and should show up.
With these devices when you connect it to a pc you would get an option on the lcd on the device that would need you to confirm connection. may be thats what you were looking for. If you have a memory card reader you can try using that as well.
Please rate if this fixed it or was helpful.
If i missed something let me know.
Feb 11, 2009 | Microsoft Windows Vista Home Premium with...
Hp dv7-1132nr Quickplay touch button doesn't launch quickplay.
Hallow Dear,
Please use this link to download Drivers for your PC (20M)
XP/Vista -
Operating Systems
Microsoft Windows 2000
Microsoft Windows XP Home Edition
Microsoft Windows XP Media Center Edition
Microsoft Windows XP Professional
Microsoft Windows XP Tablet PC Edition
Microsoft Windows Vista Enterprise 32 Edition
Microsoft Windows Vista Home Basic 32 Edition
Microsoft Windows Vista Home Premium 32 Edition
Microsoft Windows Vista Business 32 Edition
Microsoft Windows Vista Starter 32 Edition
Microsoft Windows Vista Ultimate 32 Edition
Microsoft Windows Vista Enterprise 64 Edition
Microsoft Windows Vista Home Basic 64 Edition
Microsoft Windows Vista Home Premium 64 Edition
Microsoft Windows Vista Business 64 Edition
Microsoft Windows Vista Ultimate 64 Edition
This Will Completely Solve your Prob; if there is no any internal Hardware Problems with Quick Lunch Buttons
(I feel there is no any coz u mention about Ding Sound. That mean your system is recognizing your key input & all you need is Just program those keys – above setup will do that)
** If you didn’t solve your prob; my advice is take your lap to a good technician with component level Repair skills.
Thank you & Best Regards
Dec 20, 2008 | HP Pavilion dv4000 Notebook
Audio compression format
I think you may miss one of the codecs.
Try to install
Aug 04, 2008 | Microsoft Windows Vista Home Premium with...
Microsoft Windows Vista Ultimate Edition Logo
175 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
