Question about Toro Garden
Have a toro mower model # 16401 and the front left tire fell off, appears as if there is a spring pin thats broken, I'm looking for directions on how to replace the pin. thank you
  • 69 Answers
You should be able to look up the mower and parts at the Toro website.
Posted on Oct 22, 2009
  • jacob kennedy Aug 09, 2011
    hey trmoody give me a call if you want to sell your model 16401 mower
Mower deck rides up on left front tire
there should be a rod across the front and one pin in each rear corner sounds like one of them fell out look at sears parts online
Apr 02, 2012 | Husqvarna Garden
Hourglass appeared on on my toro lawn mower and my blades no longer work.
Check for broken springs ontop of the mower deck these tensioner springs break after a while sometime you can use pliers to uncoil the spring a little and re-attach and use it untill you can get a replacement spring.
Sep 22, 2011 | Toro LX423 20HP Lawn Tractor 13AX90RS848
Toro zreo turn lawn mower... mower runs but won't go when engaged. found a large spring broken?
This spring is the tensioner for the drive belt. visit www.arcolawn.com to look up your model and get the parts shipped to you.
I recommend a hook or rope to install it.
Joe
Feb 12, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Where is the model number on the frame of a toro recycler lawn mower?
Toro model plates are white stickers with black lettering. On rear bagging models it is usually under the rear bag flap to the left of the discharge area. On side bag and commercial type units it is frequently on the underside of the plate that is just below where you hold the handle while mowing. On older recycler mowers it was on top of the left rear portion of the deck and usually fell off before the mower was very old.
Aug 25, 2010 | Toro Garden
Drive system stopped working on our toro personal pace mower.i looked over most components but could find no obvious fault
check the belt by the engine make sure it did't ride up over the pulley. check to make sure your springs not broken. may wont to pull your tires off to check thew drive pin's. let me know good luck
Oct 17, 2009 | Toro Garden
Flat front tire on toro riding lawn mower
you need to take your pliers and straighten the curved end to remove the pin and then pull the wheel off. Be sure that your bend the pin back to the way it was after you re-install the wheel. hope this helps you
Oct 05, 2009 | Toro Lawn Mower With Toro Power Tools
LEFT BACK WHEEL ON TORO MOWER FELL OFF. SELF PROPELLED . CAN I REPLACE IT
go to toro.com and enter the model number and find the replacement part.
Jul 03, 2009 | Toro Lawn Mower With Toro Power Tools
How to remove plastic front wheel drive cover on Toro Recycler
On my Toro recycler, I also had the front drive stop working -- and fixed it after reading the solutions here.
First, the plastic cover on the top deck that goes over the front drive mechanism must be loosened enough to pull it up. Before you can do that, on the underside there is one screw to take out.
Once that's done, all you have to do is pry the plastic cover up enough to see the belt and pulley that make up the front drive assembly. On mine, the belt had simply come off the pulley. Putting the belt back on, then tightening things back up is all it took to put the Toro back in sel-propelled happiness. Good luck!
Mar 07, 2009 | Toro Garden
Garden Logo
215 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
