Question about Whirlpool LER4600 Electric Dryer
Dryer will run but does not heat up
Whirlpool electric dryer model LER 4600 will run but does not heat up
Either bad heating element or missing one leg of the 240V circuit. The motor runs on 120V.
Posted on Sep 24, 2009
DRYER WHIRLPOOL LER 6646 SERNO. MS23065579 IT RUNS BUT NO HEAT OUTPUT TO DRY CLOTHES
I would suggest replacing the heating element these are usually always the culprit and pretty much anybody can replace them.
Check here for parts for you model number, they also have good diagrams.
Hope this helps, thanks.
May 12, 2011 | Dryers
I have a whirpool dryer Model LER 4634 PQ0. The dryer turns but does not heat. What could the problem be?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer ler 7620 kq8 Dryer not heating I replaced the heating element and it is still not heating. what do you think it is?
heatman101
Sep 07, 2010 | Whirlpool LER7646E Dryer
LER 5620KQO won't start. Any ideas?
I would think that you either have a bad thermal fuse, Thermal cut off or bad door switch. Most likely a bad thermal cut off.
Nov 17, 2009 | Whirlpool LER5636P Electric Dryer
Electric dryer has not heat model # ler 4600
Normally caused by bad thermostats and or heating element
Sep 24, 2009 | Whirlpool Dryers
I have a Whirlpool Dryer (Model # LER 3624JQ0) that just stopped. I push the "Push & Start" Button and get absolutely nothing. Remind you, this dryer never did turn off, I had to manually stop it each time...
Check the thermal fuse on the exit chute, white plastic. You can tape the wires together to test. If the dryer runs, replace it. Part # 3392519. Thermo next to it is also bad, part # 694674. Replace it and your timer will run down. Both parts available at www.timerking.com. Hope this helps!
Jan 14, 2009 | Whirlpool LER3624JQ Electric Dryer
Dryer won't heat yp
You are going to need a heater element OR a limit kit. A simple continuity check is all that is needed to confirm the failed part. Remove one wire from each component you check so you do not get a backfeed (false reading). Remember to unplug the machine.
If it turns out the clixons are all good and the heater is fine then the timer will probably be the culprit.
Dec 14, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool LER4600 Electric Dryer Logo
248 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
