Question about Sony RDR-GX355
Trying to record off DVR
I have just purchased the Sony RDR-GX355 DVD RECORDER connected to a Phillips model:47PFL5432D/37 TV by a HDMI cable and also connected to Direct TV DVR by component cable. Last night I wanted to record a movie off the DVR so I got the movie going and hit record but nothing happened. What am I doing Wrong?
This recorder has a top box controll feature, on set up you have a few DirecTV codes that I have tried all 15 codes and that is not working either.
Your advice will be helpful.
Thanks,
Don
I feel sorry for anyone who bought this piece of junk.
Nothing but problems. Flashes in recordings when constrast and scenes change. Black and white picture when it goes nuts and very often distorted or NO sound forcing you to stop and resume. Subtitles start automatically on every disc you put in, very annoying. Sony DVD remotes don't work at all on this box, which is also frustrating if you have kids and the original remote is often missing.
I am embarrassed to own this. I misread the box thinking it had component inputs for recoding. Not HD I thought...but component is definitely acceptable. To my horror there was only composite (Yellow Red White inputs)!. It's purposely designed this way so you can't get good quality recordings. In other words whatever you connect to the YRW is going to come out VHS lousy quality on your nice set.
This is like buying a cassette player to record your CD collection. I copied a couple shows for the kids and the poor quality and strobing backgrounds were too much to stomach on my Sony HDTV. The HDMI upscaling did NOTHING to improve the picture quality. I try them both separately and then together and toggled between both inputs and while there were some color shifts there was no difference in detail. I have many years in Photoshop so I knew what I was looking for.
The upscaled image actually looked worse than the original.
The only GOOD thing about this recorder is that it has a decent laser. It plays scratched discs that I know hung up the old player and goes through the rough spots without a single skip.
It also plays DVDR's that only played on the computer before.
The Jpeg slide feature is not impressive and the times I've tried to show I was reluctant to make anyone wait around while I fumbled around with the clumsy controls.
There are some overseas Sony models that have built in digital tuner, hard drive AND dvd burner with HDMI input so you can record right off the cable or digital channel and store it and later burn to a DVD and not loose any quality.
By the time US models have any decent capability we will have moved on to some other format.
It's the same for DVD burners. The 8.5 GB disks are still +$3/ea. even though the burners have been out five years or more!
Buy yourself an HD recorder and standard DVD player.
Make sure you read the box a couple times since "near HD quality" is often touted since it's most likely Component In instead of HDMI In. Check outside of the US for the best boxes. Also keep in mind how much storage HQ you can hold. The early models only hold 30 Hrs.
Posted on Mar 31, 2008
Sony rdr-hxd860 hdmi output is intermitant
Hi . I don't know this model but I have a Sony DVD recorder .and I have the 970 connected with a scart lead . Try that .
Apr 09, 2015 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
DVD hooked up to sony bravia tv: have dvd power on, but can not get any set up menus (or anything) from dvd to show on tv screen.Unable to set up remote as menu does not appear on tv screen.
Hook up the player with RGB (Red-Green-Blue or component) cables and try the picture. If everything works OK, then go to the menu and turn on the HDMI output and set the resolution (if needed).
Not every HDMI unit works with every HDMI TV. You may also have a bad HDMI cable. On a DVD recorder, you may have your HDMI cable connected to HDMI IN. You must use HDMI out.
Mar 28, 2010 | Sony RDR-GX7 DVD Recorder
I have a Sony DCD Recorder (RDR-HX780) and Sony 40" 1080P LCD TV (KDL40S510) "tripple checked lines and HD cable connection." Problem (which occurs randomly and is anoying): When switching to DVR or...
Try this: got to www.sony.com mouse over "support" then click on "drivers/software" enter your model #(s) and then you can check for firmware updates, the symptoms that you list, unfortunently are somewhat common when connected via HDMI cables.
Check for updates on both product that you list.
Good luck !
Jan 31, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony connectivity
OK, here are info...
first unplug TV and dvd recorder from AC outlet and put hdmi cable as follows...
at rear side of TV, you have 2 hdmi inputs, hook hdmi cable in any one of them and other end of hdmi cable will be hooked in hdmi out of dvd recorder rear side.
Now, plug both units in AC outlet and power up, go to TV menu > hdmi setup > and perform device list update.
TV will recognize dvd recorder and you will see dvd recorder logo screen.
Let me know if you need further info / help.
Dec 23, 2008 | Televison & Video
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Dvd Recorder model RDR-GX355
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
May 04, 2008 | Sony RDR-GX355
Hard To Set Up
I don't really understand the question, but you can connect with any of the connections on the back. You can use a coax (cable type connection), the RCA jacks (yellow, red, white), s-video (black cable and red and white for sound), composite video (red, blue, green and red and white or digital for sound). The DVD will still record no matter how you hook it to the tv as long as it is connected to the SAT or cable correctly.
Dec 10, 2007 | Sony RDR-GX355
Sony RDR-GX355 Logo
230 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
