Question about Estate TEDX640JQ Electric Dryer
How does is belt tensioner installed on estate dryer
  • 5,911 Answers
Replacing the dryer belt and installing the tensioner on this model dryer involves the following steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch conector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. If the belt is broken, this may cause the idler pulley to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws. NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them.
If you still have questions, please let me know. I hope this helps you.
Posted on Sep 24, 2009
Dryer will run and heat but will not turn
It sounds like your drive belt might be broken you can get a new one if you go to www.repairclinic.com enter in your model number and it should cost around 9$ the other possibility is the tension pulley or if it doesn't sound like your motor is running but most likely the drive belt .
Nov 24, 2012 | Estate by Whirlpool EED4400WQ Estate 29in...
Tip
Estate Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
For models with non-removable back panels use this diagram:
Style: Flat with ribs
Installation Tips: Ribs against drum
For models with removable back panels use this diagram:
on Mar 06, 2010 | Dryers
My Whirlpool Gas Dryer Estate Model # TGDS680BW1 will not tumble when I turn it on but the motor still runs. How can I fix it?
The problem is likely the dryer belt . Here is a video on replacing a dryer belt. It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Sep 17, 2010 | Estate Dryers
Estate dryer tensioner loose while installing belt
Go to www.appliancehelponline.com/servicemanual.html there is a video that will show you how to replace it. It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Apr 28, 2010 | Estate TEDX640JQ Electric Dryer
Dryer tub not spinning
unplug the dryer if you haven't already, take off thent tube in the back taout the screws holding the back panel on take the back off the idler pulley [belt tensioner is rihgt by the motor take out and replace there.
Dec 28, 2009 | Estate TEDS740JQ Electric Dryer
How do I instal the tension pulley and belt
If the model number you have this listed under is correct, replacing the dryer belt and installing the tensioner involves the following steps:
You should now have complete access to the dryer interior. If the belt is broken, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt and re-install the pulley, follow these steps:
Oct 20, 2009 | Estate TEDX640JQ Electric Dryer
Motor is running but not turning drum to dry the clothes. We removed the back of dryer to see if maybe belt slipped or broke but can not see any belts and do not want to start removing a lot of screws...
Look from the rear, near the bottom. The belt wraps around the drum, and near the bottom is a tensioner that keeps tension on the belt. If it is broken, you'll see it laying on the floor of the dryer.
Jul 03, 2009 | Estate EED4300TQ Electric Dryer
Replacing dryer belt
  • Just like this but imagine the roller as being a semicircle.
put pressure on the tensioner with the belt and loop the belt under the tensioner to the motor.
  • this is a diagram for a whirlpool/kenmore/roper/estate dryer, i don't know the brand of dryer you have.
look here is more diagrams of different brands. http://www.repairclinic.com/0079.asp
let me know if you need more help Mike
Jul 04, 2008 | Dryers
My whirlpool estate dryer tub will not rotate
which pulley came off the one on the motor, or the Idler wheel that keeps tension on the belt. You probably will need a belt
May 26, 2008 | Estate TGDS840JQ Gas Dryer
Estate TEDX640JQ Electric Dryer Logo
105 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
