Question about Refrigerators
I have a kenmore refrigerator with a freezer on the bottom the freezer is frosting in the back of it what should I do?
  • doylenrf Sep 25, 2009
    my frig is a frost free freezer at bottom I purchased it I believe in 2006 or 2007. Could I use a blow dryer to get rid of the snow?
  • Terry Moody May 11, 2010
    1st make sure it's a self defrosting freezer / refrig. is it clear solid ice or frost snowy ice? clear solid ice is usually an indication of a clogged drain and one of the most common causes of ice build up in a freezer. frost or snow is usually an indication of either a bad seal (moisture entering the freezer ) or can also be low on freon. let me know how the ice looks and i can suggest your next steps to repair
  • 4,066 Answers
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Sep 24, 2009
Kenmore elite frost free is frosting over
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer is cold but frost building up in the front right portion, also frost on top/ceilngi of freezer and back now too.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Frost buildup at back of bottom freezer department. Refrigerator should be frost free. Freezing impaired.
could be anumber of things happing, is the freezer fan spinning? if not ice will accumulate( also hamper cooling in the refrig section). perhaps a defrost issue, a bad heater or defrost thermostat could also cause, this/ may even just be the door being left open for extendedperiods of time( ie.. overnight, or hte gasket not sealing correctly) leading to a frost build up on rear panel
Jan 27, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Inside the refrigerator, the back of it ices up, the back of the top shelf and the coils behind the vegetable bins.
Make sure the vent from the freezer is set to a warmer temperature. You can also check the freezer to see if you see heavy frost. If no frost then try to adjust the vent
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Jun 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frost on back of bottom freezer of a 3 year old kenmore
how long did you leave it unplugged? it's possible all the frost didn't defrost .you need to leave it unplugged and the doors open for at least 12 hrs.
May 20, 2009 | Kenmore 76283 Bottom Freezer Refrigerator
Refrigerator not cold
first check your damper door from the freezer to the refrigerator compartment make sure its in the proper position. Then turn off the refrigerator for a few hours until the heavy frost melts away. turn on the refrigerator check the refrigeration cycle, is it working properly, is it going into defrost are the defrost heaters working.
Feb 21, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Trio 596.75509400
Generally speaking if the refrigerator does not cool and you have frost on the back wall of the freezer it suggests a defrost problem.
However since the refrigerator started working by itself it would point to an air circulation problem from the fan in the freezer compartment failing to operate. The frost on the back wall without the fan operating would cause frost buildup because the heat is still trying to get to the coil through the back wall. If your refrigerator freezer has a door fan light switch something holding the door partly open would cause the fan not to operate. Look for a button or toggle and manually push it in. You should hear the fan turn on and the light will go off.
Mar 12, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
