Question about Refrigerators
Freezer moisture overflowing into refrigerator
Freezer moisture is filling up tray at back of freezer, freezing and then overflowing into the refrigerator compartment and spoiling food. Have to break out ice once a week or so to keep water out of refrigerator. ??? Also not sure how to keep refrigerator cold without freezing my vegetables in the crisper drawers. User error?...not sure how to use humidity slider tabs. Thanks!
Audrey
  • 999 Answers
You need to completely clear the defrost drain and get all the excess ice out of the freezer area.
Eric
Posted on Sep 25, 2009
Your drain is clogged, defrost the freezer and locate the drain either on the back or in the bottom of the fridge and clean it out. the water is coming from when the fridge goes into defrost
Posted on Sep 24, 2009
Why is my ice maker causing blocks of ice at the bottom of ice bucket ,also on freezer baskets ?
Sounds like there is a leak in the water fill line to the ice maker or the timer in the ice maker is defective causing the fill cycle to overflow the cube tray and then freeze into blocks in the freezer.
Oct 08, 2014 | Kenmore Refrigerators
Auger freezes up
Check that ice maker unit is not overflowing down back of freezer, this can be done by opening door, holding light switch in the closed position and observing the tray filling. Regards Advisor
Aug 29, 2007 | GE Monogram ZISS480DRSS Stainless Steel
The freezer fills with water and overflows about once a week.The food is partially frozen and the ice is clear and wet. The fridge is cold and no problems but the freezer doesn't fully freeze and water...
your evaporator coil in the rear area behind the freezer back panel is frozen over with ice and the coil can no longer deliver cold air due to ice blocking the air flow from the evaporator fan,remove this rear panel,defrost it with a hair dryer,check the defrost heating coil for continuity,they go bad regularly,if not the heater coil under the evaporator coil,it may be the defrost timer in the refrigerator section of the unit that powers the defrost coil that needs replacement
Jul 25, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
I am not sure this is the right refrig. I have a model 253.78259800 top freezer with a model JD-21 ice maker. The ice bucket keeps filling up with a solid piece of ice. It makes and drops cubes, then water...
there s a adjustment but it only controls /like 1 to 2 oz of water . its prbably the ice mker unit or the water valve . .. ice mker tell water how long to let water in and if valve is bak it might not shop off causing water fill . change water valve first . then ice maker if needed .. icemker might have a bad tray and some cubes do not drop / if so next fill will over fill causing problem . mm
Dec 07, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Water in the vegetable tray
depending alot on your model
this is usually 1 of two things
1 moisture that has condensed in side the fridge or freezer, suggesting that you may a door seal leak
or overflow from a defrost problem
checks: 1 inspect your deasl seal and that all of them are free of obstrcuttion and actually seal the door
2. look at the back wall of your freezer is their
an odd amount of frost
Oct 11, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Ice freezing up on bottom of freezer and water puddles in front
Two possibilities, ice maker leaking or the defrost drain is blocked with ice or another object. Unplug the freezer and remove the rear panel in back of freezer. At bottom of the evaporator coil is a tray that catches the defrost condensate and sends it to the pan beneath your refrigerator to be be heated by the compressor and fan heat produced from the condenser. The moisture is then returned to the air inside your home. If the drain is blocked with ice or anything between the freezer and the pan below, the condensate tray will overflow will end up inside your freezer or fresh food compartment. Questions? I will be here to help you, Let me know, Sea Breeze
Jun 23, 2009 | Maytag MSD2758G Side by Side Refrigerator
Water leaking to bottom of freezer
ok you have a blocked freezer drain. The best thing to use to clear this is 'curtain wire (the plastic coated wire you use to hold up net curtains). Ok you need to find the drain hole in the "small tray on the back wall inside that fills and freezes and then the water is overflowing at this point to the bottom of freezer" you want to gentley feed the curtain wire down the hole untill the water drains down there. If you can't get the wire down you may need to turn the unit off to defrost as it could be frozen solid with ice. cheers
May 31, 2009 | GE Refrigerators
Moisture/Ice build-up in Refrigerator
ok first of all. the refrige is in the basement. do you know what the relative humidity in the basement is?
you can check this with a humidity gauge.
May 26, 2009 | Maytag Admiral Top-Freezer Refrigerator
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Whirpool Imperial Series UltraEase II side by side refrigerator is leaking from underneath the left side.
hi. thanks for the question .pull fridge away from the wall. remove back panel, clean all coils. look for leak. the tray is suppose to evaporate, from the heat from coils ,and compressor .so it has to evaporate .thanks the appliance doc
Aug 17, 2008 | Whirlpool GD2SHGX Refrigerator
Refrigerators Logo
194 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
