Question about Poulan Garden
My chainsaw starts right up but wont stay running.
Clean carb and filter, get new gas
Posted on Sep 25, 2009
Wont stay running
You should only use choke until you get a turn over. After that, turn off choke and it should start right up.
Apr 30, 2016 | Garden
Timing chain broke installed new one starts but wont stay running at idle speed
You've asked this question in the 'chainsaws category' Chainsaws don't have timing chains.!
Apr 19, 2016 | Garden
Cant stay running
What to do if your chainsaw won't stay running?
arborist101.com/what-to-do-if-your-chainsaw-wont-stay-running/
Idle ports may be plugged or blocked - This is the small ports in the carburetor where the fuel passes through when in idle. ... Vent in the Fuel Cap is plugged - If the vents in the fuel caps are clogged the fuel becomes vacuum locked. ... Starting with the High Speed screw, turn it ...
Craftsman 16" Chainsaw Fix - Won't Run - Fixed! - YouTube
? 1:32
https://www.youtube.com/watch?v=aIUVQziXBPY
Jul 7, 2011 - Uploaded by BriggsRepair
Is this Craftsman 16" chainsaw broken? Hardly. Watch this carburetor fix and how it runs brand new!
Chainsaw won't stay running - DoItYourself.com Community Forums
www.doityourself.com/.../360759-chainsaw-wont-stay-running.html
Sep 20, 2008 - Chainsaw won't stay running. Craftsman 16" chainsaw, fuel/oil ratio 40:1. Saw is 10 years old, used once or twice a season. Last used in spring ... chainsaw wont stay running
Aug 1, 2015
Craftsman chainsaw won't stay running
Oct 30, 2010
Chain saw won't stay running
Oct 2, 2006
Poulan Chainsaw - starts but won't run
Apr 28, 2006
More results from www.doityourself.com
Why won't my chainsaw stay running? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 31, 2016 | Garden
Chainsaw wont stay running
if it starts (maybe idles) but then dies when giving it gas it sure looks like its a carb problem , most likely dirt in the high speed jet , but could be a dirty fuel filter as well and that's inside the fuel tank
Apr 16, 2015 | Stihl Garden
I have Husqvarna 142 chainsaw it starts but wont stay running
all chain saw fuel filters are in the tank. find something to fish it out so you can grab and change fuel pick up
Oct 02, 2014 | Garden
It wont stay running after i get it started
That means that it is not getting enough fuel to the carb. Check your tank for fuel and the hose and filter inside. Make sure all the hoses are attached right and are not broken or leaking.
Also close the adjustment carb screws all the way in. Then open them one turn back to start . Try to start the saw. Then make adjustments to the low adjustment screw. If any of these don't work try a known working carburetor. See if that makes a difference.
Mar 19, 2014 | Solo 654 Chainsaw Vintage Collectable Saw...
I have a 394 chainsaw wont stay running
The plastic sleeves are anti tamper devices, if you screw a small self taping screw into the centre of it, it will strike the screw under neath and drag the plastic sleeve out far enough to insert a 2mm screw driver through the hole in the centre and adjust the screw beneath.
Jun 06, 2012 | Husqvarna Garden
My 455 Rancher Husqvarna 20 inch chainsaw wont stay running while idling. its a brand new saw. don't know if it needed to be adjusted or if its pre adjusted already. Starts and runs fine but just won't...
Carb adjustmwnt requires a special tool and a tacho, the saw is set from the factory for the best emmisions, however it may need a small adjustment, this should be done by a qualified dealer, incorrect adjustments can damage the engine.
Jan 02, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
My Stihl chainsaw starts up but then it won't stay running. Changed spark plugs and tried new gas, but didn't fix the problem.
Jets in chainsaw may have build-up. A good build-up remover is called SeaFoam. Add this by direction to the gas. When using the SeaFoam you need to run full throttle with intermittently full choke until motor runs smooth with no choke.
Double check 2-cycle mixture. Too lean mixture in the chainsaw wont stay running.
Sep 05, 2009 | Garden
Wont stay running
Try pumping the primer till it's full of fuel, then start the saw
Apr 03, 2009 | Garden
Garden Logo
117 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
