Question about Pentax Optio S40 Digital Camera
Purchased new 2 GB SD memory card for Pentax Optio S$). I have formatted on computer, attempted to format on camera - still get 'memory card error'. I'm not sure that camera is in fact formatting even though I have made the selection and pressed OK. Any help? Darryl
    Brigadier General:
  • 11,967 Answers
Is the slide switch on the side of the card in the locked position?
Posted on Sep 24, 2009
Memory card full
Did you format the card with your computer, or with your camera? Very often, if you use your computer, the format it uses will not work properly with the camera. Always use the camera to format the card. If that doesn't help the problem, make sure your card is large enough for the bitdepth you have selected. If you're taking RAW images at 14 Mp, it will use up a lot of space for each photo. Cameras with that high of a pixel count usually marry well with a 32 GB card. Anything smaller than a 16 GB card will frustrate you unless you switch the camera to a lower resolution and/or compression (JPEG/JPG files).
Mar 23, 2014 | Pentax Optio S1 14.0 Megapixel, 5x Optical...
Describe your can pentax s5z 4 gb Problem
Did you format the card in the camera before using it?
Feb 10, 2010 | Pentax Optio S5z Digital Camera
SD card problem
here is a list of compatable memory cards
http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch&model_id=42425
.. any SD or MMC card should work up to 4 gb ... so your 2gb should be ok .. i suspect that it may be damaged .. you can try formatting it in a USB card reader if you have one on your computer .. some laptops have the SD slot built in .. there was some compatability issues with memory cards for older cameras but there shouldnt be any with such a new machine .. make sure the contacts are clean and the "protect" switch (if any) is in the unprotected mode .. when you format the card it may take several minutes so give it time .. if you are going to take movies then its better to use a "high speed" SD card .. like the 133x mentioned in the above URL .. slow memory may cause missed frames or 15 fps instead of 30 fps record rates.. .
the specs on your camera do show SD and MMC compatability .but they dont show any brand preference .. .
Oct 06, 2009 | Pentax Optio 33LF Digital Camera
Pentax Optio MX4 won't read my new SDHC 4gb
Does the camera work with any other card? Was the card formatted in the camera? Some cards from some manufacturers just don't work in some cameras.
Sep 12, 2009 | Pentax Optio MX4 Digital Camera
Optio E10: memory card error
if the cards work ok on something else then there's a issue within camera it could be the actual sd connector within the camera ? doess the camera support that size ? Optio E10 supports upto 1GB SD Card http://www.pentaxcanada.ca/pdf/o_manuals/om_OPTIOE10_e.pdf it might not work with the high speed sd cards ? Regards
Jun 15, 2009 | Pentax Optio E10 Digital Camera
Memory Card Error on 4 Gb CF cards (80x) for Pentax Optio 430
The maximum supported memory for Pentax Optio 430 is 256mb and for Pentax Optio 430 RS is 512mb.
Check this site for more information.
Optio 430
http://www.upgradecomputermemory.com/ram.cfm//memory/P/Pentax/Pentax-Optio-430/
Optio 430 RS
http://www.upgradecomputermemory.com/ram.cfm/memory/P/Pentax/Pentax-Optio-430RS/
Jun 10, 2009 | Pentax Optio 430RS Digital Camera
Problem transferring pictures to PC
do you have the ability to attempt transfering the pictures onto another computer  maybe its just that computer  what type of card reader are you using  is it factory installed or aftermarket try installing a different card and see it you can transfer pictures from your camera to the computer then  maybe its a file type(format)problem  theres what i have good luck   let me know how it goes
Mar 28, 2009 | Pentax Optio A10 Digital Camera
SD memory prohibits functioning of Pentax E30
I know that usually, you should format the card for the camera that your going to use. Try formating it in the camera and see if that works. Let me know if I can do anything else for you,
Rob
Feb 22, 2009 | Pentax Optio E30 Digital Camera
Kodak 4 GB SD card (brand new) shows "card error" in Pentax optio
Hey,
The problem is your camera doesn't work with the 4gb card, its too big. Sorry!
Your stuck with 2gb cards. Id suggest to echange the card to two 2gb cards.
Let me know if you need anything else.
Thanks,
Ekse
Feb 17, 2009 | Pentax Optio 30 Digital Camera
Pentax Optio S40 Digital Camera Logo
236 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
