Question about AOpen AX4B-533 Motherboard
Case connections unplug
Wiring diagram
    Problem Solver:
  • 18 Answers
All you have to do is go to the manufacturer site of your motherboard and try to find the manual that your motherbaord model has.
Im sure ASUS has its own website for supports.
Posted on Dec 17, 2007
Color code for the wires that come off of my transfer case and connect to my transfer case motor for a 2000 ford explorer 4.0 liter v-6
Search Results
    images for 2000 ford explorer 4.0 liter v-6 wiring image
    Wiring diagram ford explorer limited 2000 - Ford Explorer and ...
    www.explorerforum.com > ... > Stock 1995 - 2001 Explorers
    Sep 5, 2012 - 8 posts - ‎6 authors
    Wiring diagram ford explorer limited 2000 Stock 1995 - 2001 Explorers. ... 2001 Explorer XLT 4.0L SOHC V6 auto 2WD (RIP 5/13)
Dec 30, 2015 | Ford Cars & Trucks
Transfer case wiring
If you go to autozones website and make a free account, you can logon to that account and put in the year, make and model of your car and look for the free repair diagrams. They have the wiring diagrams. Then change the make and model year to the donor car and look for those diagrams.
Feb 19, 2014 | 2001 Dodge Durango
Need instructions for replacing and wiring Motherboard
Luckily that is pretty easy with modern motherboards.
1. Remove power and unplug all devices hooked to computer.
2. Open case.
3. Write down the location and orientation of all wires connecting to old motherboard.
4. Disconnect all wires from the case that are plugged into old motherboard.
5. Uncrew the screws holding the motherboard in the case.
6. Carefully remove old motherboard.
7. Install new motherboard and secure it to the case (probably using the same screws as the old MB)
8. Refer to diagram you made earlier to plug in all the wires to the proper places in the new motherboard.
9. Check and make sure the new motherboard works before closing the case.
10. If everything is working correctly, close up the case and you are done.
Nov 10, 2013 | Computers & Internet
Acer aspire 1201 f-panel wiring diagram
you'll need the motherboard make and model to find the wiring diagram...should be in big letters on the board
Jul 20, 2012 | Acer Computers & Internet
How to connect a new era alternator voltage regulator wiring diagram.Or a schematic diagram of the charging system.
knowing the color codes can be a great help..usually in 12v reg system,from the regulator there are 6 white wire having a stripe codes,blue means neutral,green means field,black means ground to body,white means hot wired to +12v,yellow means to bat charging indicator going to instrument panel and finally red means to ignition....and always secure the regulators case to ground.
Jul 19, 2011 | Isuzu i-Series Cars & Trucks
I NEED THE WIRING DIAGRAM TO HOOK-UP AN INGERSOLL-RAND TYPE 30, MODEL V 234 N4, SER. # 30T 37128 I UNDERSTAND THAT IT CAN BE WIRED FOR 110 VOLT OR 220 VOLT POWER.
The wiring diagram is on the outside of the
motor case, on most motors,on the label
Also on the inside of the wiring connection
cover
May 25, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
Wiring
The user guide for the motherboard should have a full diagram for all the wiring you have. Here is the link: http://www.manualnguide.com/dl/8959/
Sep 10, 2008 | ASUS Computers & Internet
AOpen AX4B-533 Motherboard Logo
158 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
