Question about Garmin Nuvi 660 GPS Receiver
Unit comes "on" for approx. 30 sec, then turns "off". battery indicates approx. 25%
  • Garmin Master
  • 2,130 Answers
If the unit has been on the charger for several hours and you still only get a reading of 25%, the battery must be replaced. Please see this link:
http://www.sharc.net/gps_battery_repair.htm
- Jim
Posted on Sep 25, 2009
I have a McCulloch Model FR 2.3 18 in. chainsaw that will fire up and run for approx 30 secs. and then shut off. If I pump the primer bulb twice, it will fire up again for approx 30 secs. I'm ve
This is oviously fuel starvation, the first thing to do before speding too much time on it is to replace the fuel filter in the fuel tank, hook the hose out with a piece of bent wire, pull the filter off and replace, as a quick test pull the filter off, let the fuel hose go back into the tank, make sure the tank is full, now try. Do not leave like this you must fit a new filter.
Mar 30, 2013 | Garden
Acer aspire 5336 black screen...when i turn on the paltop the acer logo comes on and it boots up , while it is booting up the screen goes black, i can barley see the icons on screen underneath..if i...
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 26, 2012 | Acer Aspire One PC Notebook
LAPTOP FROZE ONLINE. HAD TO SHUT DOWN MANUALLY AND NOW WILL NOT TURN BACK ON. BLUE POWER LED COMES ON THEN SHUTS OFF. THERE IS A SOUND AT THE DVD DRIVE AS IF IT IS TRYING TO LOAD A DISC BUT THERE IS NO...
ok first remove ac adapter , remove battery ,, and press and hold the power button for 25-30 secs..plug in the ac adapetr after that (not battery) and power on..if it does not power on then it could be the system board faulty, replace system board.
Apr 13, 2011 | Gateway NV7915u PC Notebook
Help please. My Philips coolskin works fine but has various lights come on and go off. When switched on the amber light above the charging point comes on and stays on. The shaver head light flashes red for...
When the shaver head light flashes, this indicates that the heads should be changed. You will need the specific model number written on the shaver to select the correct type heads
Jun 09, 2017 | Philips Philishave Cool Skin HQ6760/HQ...
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
My acer aspire turns on for a second then powers down. I have taken the battery out and just used the power adapter but same problem. The hard drive indicator light and the power light both come on for...
Bad battery damages the power suplly and the plug. Check to see if the pin in the power socket (in the computer is loose) Common problem in laptops. The socket may need replacing.
Jan 24, 2010 | Acer Computers & Internet
Turn power on, approx. 30 sec later it the power
It varies as to what is actually making the TV shut down. Shorting the connectors on the A.C. plug have nothing to do with it turning back on. Its just the fact you are unpugging it for a few moments.
Nov 11, 2009 | Zenith Z19A11S TV
Panasonic Microwave only works for 37 secs no matter what time setting
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Jan 04, 2009 | Microwave Ovens
Garmin Nuvi 660 GPS Receiver Logo
49 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
