Question about ASUS M2N-MX Motherboard
Computer not recognizing all of my installed RAM
I have 4 GB of RAM installed in my computer. Asus A8N-SLI Premium Mobo with AMD (socket 939) 4000+ San Diego Processor. My computer is only recognizing 2.5 GB. Why is that? Can anyone help? Thanks!
  • Richard Tobol Sep 24, 2009
    Thanks for the help. My video card is an older ATI X1900XTX. This video card and windows XP don't get along?
  • Richard Tobol Sep 25, 2009
    thanks for the info, I appreciate it.
  • ASUS Master
  • 6,487 Answers
If you're only running a 32bit computer the max capacity of RAM that it can detect is only up to 3GIG so that can be the reason now why its only showing that RAM on your system....
Posted on Sep 25, 2009
  • 4,472 Answers
This has to do with windows and your video card. I assume your running windows xp. This is perfectly normal. If you upgraded to vista it would show the full 4gb. If you have any other questions let me know.
Thank you,
Lee
Posted on Sep 24, 2009
  • Lee A.
    Lee A. Sep 25, 2009
    No its not the video card at all. It just has to with the architecture of XP and the maximum memory it reads in windows. If you found my information helpful please take a moment to accept my solution.
    Thanks again,
    lee
Non-stop beep sound and won't display
A constant beep, usually indicates the post is detecting no memory installed. This is usually caused by the memory not being installed correctly or incompatible memory. double check you have the correct memory for this mother board. If you have 2 chips, install one and test. If this does not work swap the memory and try again. If both chips fail, you might try a different brand of memory.
Jan 27, 2012 | ASUS A8N-SLI Premium Socket 939 NVIDIA...
Hi I have lost my cd for my A8N-SLI Motherboard for all the drivers where can i download the contents of the cd. Im not very good with computers so installing all drivers seperate would be impossible for...
Go to this website: http://www.driverstock.com/ASUS-A8N-SLI-Premium-driver-download/6-9-10198/index.html
Near the bottom half of the site you should see a list of drivers, these are the drivers that the CD would have contained. I've included a few pictures, the drivers circled in red are the ones you need to download for Windows XP, if you are using Windows 7 then just reply to this solution saying so and I will get back to you about it.
Please rate me high if this answered your question.
Thanks.
Nov 01, 2010 | ASUS A8N-SLI Premium Socket 939 NVIDIA...
What amd cpus does this mobo support? are there any that I can get off newegg for this mobo? and which sli connector should i get from Asus? like what length?
939 pin Athlon 64 X2 / Athlon 64 FX / Athlon 64 are the supported CPU's.
For the SLI connector, it's a 2 1/2 inch connector. (63.5mm).
Oct 26, 2009 | ASUS A8N-SLI Deluxe Motherboard
Problem adding Additional Ram to my Asus A8N SLI DELUXE system
Just because BIOS is recognizing the RAM doesn't necessarily mean it is usable. Also, ASUS recommends that you have the same amount of RAM in each bank. Another point they make is that your motherboard does not support double-sided DIMM chips.
I would refer to the manual for their specific instructions on proper RAM configuration:
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI%20Premium/e2435_a8n-sli_premium.pdf
If you are concerned that the memory stick might be bad, swap it out with one of your older ones, and see if your system boots and performs as it should. If not, then you know it is bad. My guess is that if you populate the memory slots with 4 gb, the system will recognize and make all of it available to you.
Cheers
Nick
Jan 08, 2009 | ASUS A8N-SLI Deluxe Motherboard
A8n32 sli + xp service pack 3
MIGHT WANT TO FORMAT THE HARD DRIVE.(XP SP2)RICHARDM69
Nov 06, 2008 | ASUS A8N-SLI Premium Motherboard
4GB memory not being recognized
To recognize more than 3.5GB RAM you must use a 64 bit operating system
ordinary 32 bit O/S only recognize max of 3.25 to 3.5GB ram
Oct 31, 2008 | ASUS A8N-SLI Premium Motherboard
Type of ram
ASUS A8N-SLI Premium Specifications
CPU: Socket 939 for AMD Athlon 64FX / Athlon 64 /Sempron / Athlon 64 X2
Chipset: NVIDIA nForce4 SLI
Front Side Bus: 2000/1600 MT/s
Memory: 4 x DIMM, max. 4GB, DDR 400/333/266, ECC, non-ECC, un-buffered memory, Dual Channel Architecture.
Expansion Slots:
2 x PCI-E x16
- SLI mode: x8, x8
- Default (single VGA): x16, x1
1 * PCI-E x 1/ 1*PCI-E x 4(x2 mode)
3 x PCI
Storage/RAID: nForce4: 4 x SATA 3Gb/s
NVRAID: RAID0, RAID1, RAID0+1 and JOBD span cross SATA and PATA
2 x UltraDMA 133/100
Silicon Image 3114R RAID controller
4x SATA with RAID0, 1, 10, 5
Audio: Realtek ALC850, 8-ch High-Definition Audio CODEC
LAN: nForce4 built-in Gbit MAC with external Marvell PHY MARVELL PCI Gbit LAN controller
or see this site:
http://www.ngohq.com/home.php?page=articles&go=read&arc_id=34
Oct 30, 2008 | ASUS A8N-SLI Premium Motherboard
Asus A8n-sli premium with amd 64 3700+ proc
Usally blue screen errors are from ram. Do you have the right ram for that board?. Is the ram set to the right speed in bios?.
Feb 28, 2008 | ASUS A8N-SLI Premium Motherboard
Asus A8N sli Premium - sli problems
I went through your bios manual three times & did not come across a setting that gives you the option as you listed above.
What I did come across & triple checked your Manual Pg. 2-28 section 14. Asus EZ selector card connector (144-pin SLI_CON.
When using two PCIE SLI cards make sure the card is seated correctly & set for Dual Video Cards. (extreamly important).
Pg. 4-34, section 4.4.9 SLI mode Recommend kepping to Auto. Than the Bios detects the setting of theSLI selector card.
Refering to the sentance above the manual recommends all settings be set to Auto. Your Bios will do the rest. If for unknown reason you no longer have your manual you can download it from Asus. You'll need to fill in the 3 windows under, Please Select the Product.
Motherboard
Socket939
A8N-SLI Premium
Any more question Drucos, please feel free to post back here!
& please vote...
Feb 22, 2008 | ASUS A8N-SLI Premium Socket 939 NVIDIA...
ASUS M2N-MX Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
