Carrier fa4anf024 blower is not working. Pipes are getting frosty so the compressor must be ok. I hear 'gurgling' from the air handler, but no fan
    Sergeant:
    Champion:
  • 232 Answers
You can remove the top panel by removing the 5/16 screws his will gain access to motor turn the power off to the unit and check if the motor is hot. if it is let it cool and retest if the motor makes a loud humming noise and does not turn try to manually spin it if it starts up you have a bad capacitor if it wont turn it is seized and the motor will need to be replaced . If it cold and makes no noise you may have a bad blower relay, you will need a volt meter to test. that motor is 240voltmotor
Posted on Sep 24, 2009
Carrier electric furnace (air handler) stopped running
The 5 amp fuse may be bad, they go quite often, and they are exactly the same as the car ones. Check the fuse with a meter. If its OK turn the unit on and check for voltage going to the blower fan. You should get a reading between at least one pair of wires. The unit should have a schematic on it somewhere, check it to see which wire pairs are used for the variable speeds of the fan.
Nov 08, 2014 | Heating & Cooling
Carrier electric furnace/air handler stopped running
Check fuses first! If yours is the model with a fuse box you will see a flap that pulls down to reveal a block of fuses, the blade fuse you described is part of it too! Are all fuses ok?
What causes my AC to sometimes stop cooling & can hear a buzzing from the motor?
The blower motor probably needs very badly to be cleaned, lubricated, or replaced, Michael.
Aug 06, 2014 | Heating & Cooling
Air handler blower/fan wont come on.
open it up and vacuum and blow out the fan and other areas
Feb 28, 2014 | Amana ASPF183016 Multi-Position, Air...
Compressor stopped working. Air handler works okay. Checked wiring in thermostat-that is fine. Air handler is not frozen up. Breaker shows fine on meter.
Check for power out of the contactor...is the condenser fan running?? If so then the compressor should have power...could be the compressor capacitor...or a bad compressor.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
May 14, 2011 | Carrier Air Tools & Compressors
Very hot outside. blower comes on but outside fan
Check the voltage source for the fan and compressor
Check the start capacitor for the compressor.If its over heating :bad compressor
Jul 05, 2009 | Carrier 38BRC036 Air Conditioner
Outside compressor off while handler on inside, no cooling
CHECK WIRING MAKING SURE NOTHING FELL OFF BUT IF NOT REPLACE THE MOTOR BEFORE YOU BLOW YOUR COMPRESSOR
Jun 20, 2009 | Heating & Cooling
Why is my air handler fan motor tripping the 20
sounds like fan motor is going bad - replace
Jun 15, 2009 | Heating & Cooling
Air handler fan not working
Check the fan relay switch in the air handler.
Check the fan motor capacitor.
Check the fan blower wheel for binding.
May 25, 2009 | Heating & Cooling
Problem faced by comperssor
guru, what I think you are asking is how do you know whether the compressor is good. First, you will want to get access to the back of the unit. Once you do, the compressor is the big black thing with the pipes coming out of it. Unplug your fridge for about half an hour. Clean the condenser coil of all dust and dirt. Now, look at the largest pipe coming out of the compressor. If it isn't clean, clean it off. Restart the unit. You should hear a mechanical hum. Be aware that there may be an exposed fan back there. The large pipe should be frosty. After about 5 minutes, the frost should be replaced by ice, water or be drying out. If still frosty, you are low on gas.
Nov 13, 2007 | Kenmore 50522 / 50524 Side by Side...
Heating & Cooling Logo
611 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
