Question about Sharp AL 1631 Copier
My Sharp 1631 sounds like it is working fine but blank copies are now coming out
  • 143 Answers
Make sure thee scanner lock isn't locked and after you clean the scanner rail, use only 3n1 oil on it.
Posted on Sep 25, 2009
Its a Sharp AL-1631. It'll copy from the auto feed
Check under the scanner, there is a scanner lock that you may have hit removing copies. Its most likely in the locked position and stopping scan.
Jun 03, 2011 | Sharp AL 1631 Copier
Tip
All sharp 1631 and 1642 models have scan unit problem.
When scan unit doesn`t move you have (L1-from left to right)and (L3-from right to left)code or blank copy (white).first must check scan uniy lock under the scan unit-then service 2 plates that scan moves on it.
on Jun 01, 2010 | Sharp AL 1631 Copier
My al-1631 gives blank copies. just replaced toner. no warning lights of any kind. no message lights. it just prints out blank paper. could it be the drum? can't find instruction manual. purchased...
Was the copier working fine before you changed the cartridge? If so I think your cartridge is the problem. If it started making blank copies right after you changed it. If this is not the case the first thing I would say is it is not the drum. Try opening and closing the right side door. There are contacts in the door that will cause blank copies. I have had several customers do this and it fixed the problem. You can also try pulling out the toner and then pull the drum unit partially out and re-seat it. Then re-install the toner.
Good Luck
Jan 05, 2010 | Sharp AL 1631 Copier
Sharp Al1631 unit won't copy; just spits out blank papers
check for empty toner... and if the laser lamp is dim or out... the laser lamp is the lamp that comes on when you copy from the glass table or through the document feeder
Dec 09, 2009 | Sharp AL 1631 Copier
Top load copies are blank
I tried changing the the size to a reduction. It took the sheet from the top and copied it at a reduced size with no problem. Then I switched back to normal size and it worked just fine. I would have never thought to try a different size without your suggestion. Thanks for the help
Randy
Jul 17, 2009 | Sharp Office Equipment & Supplies
AL-1531 blank copies at 100%
I believe the document feeder is just hesitating some, try pushing the original as soon as it starts trying to feed. It won't fix it, but you'll know where your trouble is.
good luck
Bob
Apr 22, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 ---- Getting blank copies
Hi, you can stop a copy half way to see if it image is on the on the drum if not check and make sure toner unit is turning. if not main charge. thanks dale.
Jan 22, 2009 | Sharp AL 1631 Copier
Al 1631
Simple you get a PM, new developer.. call an authorized Sharp Tech...
Oct 21, 2008 | Sharp AL 1631 Copier
Won't copy anything now.
the "screen" is actually called a grid, it is supposed to be on a unnit called the "primary" which sits on top of the drum (long silver unit) it may have a screw holding it. It must have been serviced or someone touched it, does not come off by-itself, anyway, it distributes the charge of the primary to the drum.
So look for a unit that sits directly on top of the drum unit and is the same lenght as the drum
Hope this helps (please rate. TNX)
Oct 02, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
69 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
