Question about Sony VAIO VGN-SZ330P/B Notebook
I have a sony vaio vgnsz330p. I want to be able to get data.
I have a sony vaio vgnsz330p. I can't get it to boot up or anything. Only things that happens is it sounds like the power comes on but
I can not see anything or do anything else. Is there a way I can
get data that is on the hard drive.
  • 107 Answers
In Case the comp is in warranty, Call Sonny Support
Posted on Mar 26, 2010
    President:
  • 2,600 Answers
Take the hard drive out and go to the computer retailer and ask for a EIDE/SATA to usb adapter. You can then plug the hard drive into this adapter and then plug the usb cable into another computer...the computer will read the drive as an external and you can access all your files like any other drive.
Posted on Sep 24, 2009
My sony vaio comes up with "start windows
You will need a windows installation disc. Then you will need to put that in the computer and boot to the installation disc. From there you will want to perform a repair installation and that should fix your problem and your data will still be on the computer. Be careful and make sure not to perform a fresh install as you will lose all your data.
Thank you,
Lee
May 08, 2011 | Sony VAIO FRV25 Notebook
I need startup disck where i can purchuse my computer is not same I wont to reprogram so it will be same as fist day when i got. it is sony vaio sz330p
Go here http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNSZ330P
and check out what's available in the Notebook Control & Utilities section.
Good luck.
Feb 16, 2010 | Sony Computers & Internet
I have a Sony Vaio Laptop wit windows vista ultimate, does anybody knows how to recovery this laptop?
Most Sony Vaio systems will have a VAIO recovery wizard. Create a Recovery Media Kit using this wizard and you’ll be able to create a set of CDs that will enable you to do a system recovery on your Sony VAIO machine.
If your PC does not have this feature, you can always call Sony at 1-800-488-SONY to have them send you the disks.
Once you have either created or ordered and received the CDs necessary to restore your Sony VAIO computer, you’ll need to place the first CD in the drive and reboot the machine. The recovery process will immediately begin when the system boots. If it does not begin, you may have to enter the BIOS of the computer to change the boot sequence to the CD ROM instead of the hard drive. To enter the BIOS, tap the F2 key numerous times when booting.
REMEMBER... when you use the recoery system, it will restore your computer to it's ORIGINAL configuration from the factory. All data and programs you have installed will be GONE!
Sep 18, 2009 | Sony VAIO VGN-CR120E Notebook
SONY VAIO
Save Data if possible.
Use Restore System; Restore Computer to Factory "New" Condition.. Sont Vaios have a Key Prompt which you hold down while booting and the Replacement Software already on a Sector of the Hard Drive. Check THe Manuel for this OR CALL SONY CUSTOMER SERVICE AND JUST GIVE THEM THE MODEL NUMBER AND ASK THEM WHICH BUTTON YOU PUSH ETC TO RESTORE THE COMPUTER TO "FACTORY CONDITION"
Aug 19, 2009 | Sony VAIO VGN-CS118E/P NoteBook
My Sony Vaio laptop wouldn't start - it will not boot. it's stuck on restart again, not logo. nothing - I had the hard and soft drive checked and the memeroy boards, all sony parts. but it will not display...
Your operating system may be corrupt. Please try the following:
Try hitting the F8 key repetedly at boot to see if it goes into the preboot menu. If so, choose last known good config and try booting again. If not, you may want to grab your restore disk and perform a windows repair. Insert the CD in your drive and boot to it. Choose the option to repair your windows installation. This will fix windows without destroying your data
Jun 22, 2009 | Sony VAIO PCV-RX511 PC Desktop
Sony vaio pcv-rs510 fails to fully boot. Goes past initial windows screen then blanks out.... safe mode fails to boot as well... command lines just pile the screen.. need help plzz
reinstall os.bios should be preset to boot from cd/dvd but if not power on then press delete key or escape key till bios loads-in boot opt. select cd/dvd drive first boot.put os disk in drive and restart when asked to press key to boot from cd do so.follow inst. instructions.after insall detects previous version of xp select repair (r key) and follow inst. should solve startup problem without losing data.if not reinstall os but select leave files intact instead of format or you will lose all files.
May 31, 2009 | Sony VAIO PCV-RS510 PC Desktop
Error 116 on start up
Start--> run and write ( Msconfig )
go to start up tab and uncheck anything about Sony Vaio VGD.....
Mar 01, 2009 | Sony VAIO PCV-RX460 PC Desktop
Sony Vaio with Vista has stopped reading Data CDs
make sure windows media player is not starting on boot up if it is running in the back ground it can cause simialar problems.
Feb 11, 2009 | Sony VAIO VGN-FS640W Notebook
Sony Vaio VGC-RC024 will not boot up
Try when system is booting up, press F8 to come into boot choices.
Select last known good configuration.
select OS
if it still hangs try F8 again on boot and go into safe mode,
If neither way works the master boot record may be corrupt or viruses may be preventing boot up.
Mar 31, 2008 | Sony VAIO® VGC-RC310G PC Desktop
Sony VAIO VGN-SZ330P/B Notebook Logo
145 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
