The set is dead only blinking red light is on. no sound no pix
  • Brunotheques Sep 24, 2009
    it is a 37" LCD (possible inverter?)
    President:
  • 1,015 Answers
Is the televison a DLP TV? If it is it may be that the light bulb is bad and needs replacement. The bulbs on the DLP televisions are fairly easy to replace and cost between $130 to $200. There will be a compartment at the back of the tv where the bulb can be removed. They usually post the part number on the cover. I have a Samsung DLP TV and when my bulb went out the red power light was blinking and it would not do anything else...it was the lamp. If that is not the case does it blink a certain amount of times in a row? Sometimes the light will blink in a specific sequence to form an error code. This code can sometimes direct you to the problem. I hope I was able to help.
Posted on Sep 24, 2009
  • muebe Sep 24, 2009
    Yes it could be an inverter problem. Sorry but you had this listed under projection televisions so I assumed it might be a DLP television. It could also be the transformer on the power supply. I would test the tansformer with a fluke meter and verify that it is giving the proper voltage for the rating on the supply.
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
HITACHI TV 50XU53K DEAD SHUTDOWN RED PROTECT LT BLINKS
Do any of the green led lights in the set come on?---red one should be on all the time--blinking would indicate a problem in the power supply at the primary side (INPUT).
May 21, 2012 | Hitachi Televison & Video
Was watching TV, heard a slight "pop" noise then TV went dead - no picture or sound. When I hit the power "on" button on remote, the green light blinks for quite a while (around 40...
Count the number of blinks. Now, Google your make and model with the words blink codes added to the end. This will show you links to sites that will tell you what the blink code means and the problem with your set. The blink code is the sets way of telling the service man what is wrong. From the sound of it, you have a bad capacitor.
Sep 11, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Panasonic TCP58S1 has no pic. or sound. Red light blinks 9 times.
It's dead. 9 Blinks means the display adaptor is dead. If it's still under warranty, you're covered.
Jan 22, 2010 | Panasonic Viera TC-P58S1 58 in. Plasma...
Flashing green light on Mitsubishi WD- 62527 TV
how time dose the light blinking was your pix
dark if so you need a lamp@powersupply for lamp. hope this help you out,
Aug 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a large projection toshiba tv. When I turn it on the red light indicator blinks but tv screen does not go on. Please help and let me know what I am doing wrong. Thank you.
one thing you may try first is disconecting the tv from ac outlet and plug back in ater 20-30 seconds, try to power back on. If nothing happens you're not doing anything wrong it might be that the tv needs circuit repair, the light blinks and you get sound indicateds a possible deflection board problem either horiz out transistor or surrounding circuit if you only get the blinking light no pix or sound could be also indicator of defl circuit failure or switching mode power supply acting up.hope this helps please let this site know if your question was answered.
Aug 22, 2009 | Toshiba Televison & Video
Philips 42pf9956/37
when the light goes red it should be blinking a two digit code and repeat itself continuosly. slow blinks are the first digit and fast blinks are the second digit
Sep 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Red light blinking
If the tv is a dead set with only as you say the red light blinking, then your tv has a defected power supply or related circuit.if the screen light up with no sound then the tv is having a problem in the IF circuit or also the power supply.in either case you will have to call a tech to look on your set to repair it.good luck
Apr 24, 2007 | Konka K2786U 27" TV
Sound, but no picture
Locate vertical output IC = solder all pins = two off-set rows,
then try again................part location IC301 , or 401 ?
2) possible bad CRT = turn up screen voltage slightly = did pix pop back on ?..................................T.
Please rate this solution.........................
Feb 09, 2007 | Sony KV-27V22 TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
