Question about Xerox Office Equipment & Supplies
My copier will not feed paper through the auto feed and now a line is on every copy when i make a copy
  • 121 Answers
Sounds like you've got something jammed in the ADH. Have a good look under the cover on the side where there is a narrow glass strip..
The line is caused by a mark or spot on this narrow glass. As the original passes over it a small spot will be picked up as a continuous line.
Posted on Oct 09, 2009
Equally spaced lines across page only on color copies
If not in the direction of the paper feed then in the direction of the scan head. Dirt on the scan head or bad scan head or scan head connection. Send it back.
Nov 15, 2013 | Konica Minolta Bizhub C284 Color Copier /...
Copies nothing but solid black paper
Printing from system is OK? Do scan and check.not proper ? check CCD unit & cable..
Suspecting 80% CCD unit(Unit under flat bed glass moves while scan or copy with lamp)
20% cable(flat ribbon cable connected between CCD unit & Formatter) see the snap shot for easy recognition of CCD7_15_2012_3_12_34_am.jpg
Jul 13, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
Gestetner 6123 paper jaming feeding section copy printer
nrg 6123 copy printer after make stencil line on copy soulition
Jun 15, 2012 | Gestetner - AO40 Wide Format Copier Copier
When I copy using the auto feed, I get a line across my copies. The line can fade or be dark but has been present for a few months. Copies that are hand placed do not have the line. What can I do?
There is usually a little strip of glass to the left of the main glass bed where you would place paper by hand. This little strip is what the feeder passes the paper over to scan it while the scan head stays in place underneath it. Most likely there is some fuzz or dirt on this strip of glass or on the feeder where the paper passes.
Oct 18, 2010 | Ricoh Office Equipment & Supplies
Dear Sharp Al-2030 Experts: Paper Copies made from the cover-mounted auto-feed system are produced with a full copy-length thin double line separated by an approximately 1 13/16" wide distance. It is...
There is something on your scan glass. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on. Once the glass is clean your problem is solved!
May 20, 2010 | Office Equipment & Supplies
Black vertical lines on copies and scans from auto
This means the read area is dirty. Clean the glass with glass or lens cleaner at the area where you place the head of the paper if you wanted to lift the cover and scan a page without the autofeeder. There may be white out or toner stuck to the glass. This can be removed with a glass blade.
This answer assumes that prints from the computer are fine...
Apr 03, 2010 | HP Officejet 6500 Wireless All-in-One...
When I scan a document, a black line the length of the page is seen on my scanned copy. What is causing this? I have cleaned the print head.
When you are scanning with the auto paper feed, if the scanning window has a spec on it, you get a line the lenght of the paper.
Feb 17, 2010 | Brother MFC-685cw InkJet Printer
Our HP laserjet M1522n has a vertical line going through the paper when using the top feed. the line doesn't appear on copies made thru the computer or on the flatbed, only thru the self feed. any one??...
If you open your "self feed" cover, you should be able to see the scan glass that originals pass over to copy. Clean that glass thoroughly. There is some dirt or whiteout (liquid paper) on it which causes the shadow or line on copies. Let me know.
Oct 15, 2009 | HP LaserJet M1522n MultiFunction Printer
Officejet d135 Copier copies in 1/4
try to reinstall the driver of the printer, if nothing happen.
your problem in feed of the paper check the feed roller grears,
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet J5780 All-in-one Injet prints a grey line down the right side of the page when copying using the automatic document feeder. It does not show up when printing; and it does not show up when...
lift the feed area and look at the small glass plate where the auto feed paper is actually scanned. That needs a good cleaning. Since the paper runs across it even a tiny little obstruction such as paper left from a paper jam or a dot of ink from that pen you used to unstick that last paper jam (maybe its just me??). That one dot turns into a line when the paper rolls across it. Clean well and the line will dissappear.
Feb 27, 2009 | HP Officejet J5780 All-In-One InkJet...
48 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
