Question about PC Chips M938 (M938ALU3.1/CNR) Motherboard
Have no sound on line - PC Chips M938 (M938ALU3.1/CNR) Motherboard
I heard a loud pop from car and then i couldn't steer it. When i got out fluid was running from it really fast
It sounds like you have blow a power steering line it sounds like the Pressure line as it would make a loud pop. There are two lines your pressure line and your return line. Check the pump so see if one of the lines is broken there if not it will have popped off at the steering rack. It could simply have a leak but that would not make the pop sound. The lines are relatively inexpensive and not really that hard to change. Hope that helps..
Aug 05, 2011 | Ford Escape Cars & Trucks
My 1999 alero srevving up high shen stalling and it is makeing a wisling sound i just had the throdel body cleande
whistling sound is a vacumn line off somewhere on the throttle body or a split line- look carefully- line might be just barely on- walk around car with hood up and engine running-listen for sound change- louder side will help locate line....
Jul 30, 2011 | Oldsmobile Alero Cars & Trucks
Solid white horizontal line
Horizontal line WITH SOUND is only vertical output stage problem.horizontal line without sound is osc problem.So kindly verfy that.If h line with sound then
check vertical ic and ver supply voltage.
Aug 02, 2010 | Sansui DTV2700 27" TV
My tv quit with no picture or sound and only a white line
It's more than likely that the white line is from left to right, is that the case?
Apr 16, 2010 | Proton MM2701VT 27" TV
Feels like no power or pick-up. vibration and trouble starting
This definatly sounds like a vacum problem. Start your vehical with the hood open and listen for any whining noises or anything that sounds like it is making a vacum sound.Also check for and pluged hoses,or lines EXP,radiator lines,radiator to transmission lines,and fuel line on top of engine.
Mar 29, 2010 | 1983 Chevrolet Silverado
How to hook up audio output and line in
The sound cards have unified color codes; green jack is sound out, and the blue jack is line in.Mic in is pink.
Feb 05, 2010 | Creative Labs Sound Blaster Live! 5.1...
Sounds
Two possibilities:
1. Do you have DSL service on one of the lines? This can cause line noise.
2. You may have crosstalk between the lines OR between the lines and an AC power line. The phone lines need to be run with Category 5 wiring, which is twisted and shielded to prevent lne noise leakage.
May 07, 2009 | RCA ViSYS 2-Line Speakerphone
Sound problem
if ur usung win xp OS U shold restore OS (pgm-accessories-system tool.restore )to back date while it in workinfg fine
Jul 19, 2008 | Edirol UA-4FX External Sound System
Rane Mixer ttm 54
in sound system you have different sound level start with phono level up to line level up to speaker level.-you will switch to phono when you connect phonograph and you will switch to line when you connect another audio source like dvd and video sound.
Sep 01, 2007 | Rane PE 17 Home Equalizer
Computers & Internet Logo
16 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Steven Burn
Steven Burn
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
