Question about Sony DVP-S725D DVD Player
Hi had my sony dvp s725d from new 1999 and loved it, the problem is it switched off during playback, i thought it was a blown fuse but umpteen fuses later i came to the conclusion that it hadn't blown at all, had a look inside no evidence of burning anywhere or smell , still no joy it won't turn on! is it likely to be the transformer or a faulty standby switch or other fault??
  • 4,234 Answers
The power supply is no longer available as a replacement part from Sony. This should be a straightforward repair for a shop. These units use a switch-mode supply. These supplies have very common failire types that are easily found and fixed by an experienced tech. Where are you located? Expect a parts cost in the $25 range for this repair.
Dan
Posted on Aug 14, 2010
Where will i get powersupply pcb for sonyDVP-S725D ? as orginal powersupply beyond repair ?
    Problem Solver:
  • 5 Answers
Hi if there`s no stby (red light at the powerbutton)
Chek E+5V CN203 on the psu board, if no 5V try
change C181 2,2nF 1000V on the psu board
Posted on Nov 04, 2009
  • 3,267 Answers
First check the power supply after it has reduced the voltage and DC supply. That circuit is at fault & change it if available.......................sodeep
Posted on Sep 24, 2009
3 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Sony DVP SMPS unit fault
You can get complete power supply as one part from Sony. You can't repair it on component level because components are not available.
Posted on Jul 26, 2008
SOURCE: SYSTEM NOT SWITCHING ON
i have same problem checked fuse was ok. Just went to turn on and system was dead. I would like to get some basic voltage values I could probe the power supply for.
Posted on Oct 14, 2008
How do I unlock my Sony DVP - NS330 player, bought
Codes for-
Sony DVP-NS300, Sony DVP-NS305, Sony DVP-NS400D, Sony DVP-NS700, Sony DVP-S330, Sony DVP-S335, Sony DVP-S360, Sony DVP-S336, Sony DVP-S525D, Sony DVP-S530D, Sony DVP-S535D, Sony DVP-S536D, Sony DVP-S725D, Sony DVP-S735D
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Yours is not listed but these may be worth a go.
or try http://www.haldigital.com/hp/dvd.htm
May 15, 2010 | Sony DVP-NS330 DVD Player
Tip
Sony DVP-NS725P Region free code.
This region free hack also works for the DVP-NS725P using the original remote control. If the first one fail try the second one, it works like a charm.
Thanks a lot....
SONY DVP-NS300, DVP-NS305, DVP-NS400D, DVP-NS700, DVP-S330, DVP-S335, DVP-S360, DVP-S336, DVP-S525D, DVP-S530D, DVP-S535D, DVP-S536D, DVP-S725D, DVP-S735D
Multi-Region:
Turn On the unit with the remote controller
Press Pause, 3, 1, 4, 1, 5, 9
The word "CODE" should appear in the display
Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on
Again, within 5 seconds, press Pause and Power
If the above fails to work then you may wish to try the following:
Put the player into Standby mode
Press 1 and Return on remote for region 1, 2 and Return for region 2, and so on. Use 0 and Return to return player to default region settings
Press P-Mode and Return to play DVD's with the selected region, auto-switching is Off
Press Audio and Return for auto-switching On
Press Angle and Return for MacroVision On
Press Subtitle and Return for MacroVision Off
on Mar 07, 2010 | Televison & Video
Instruction book required
Click HERE and check right side of that page to download required user manual of DVP-S725D
Thanks.
Apr 17, 2010 | Televison & Video
Problem with dvd playback
The problem may be on the len, laser focus ... take it to service or buy a new one.
Dec 18, 2009 | Sony DVP-FX820 DVD Player
Lines across the screen occur during playback on sony dvp-ns700h
make sure its set to progresive scan that will get rid of any lag
Jul 09, 2009 | Sony Televison & Video
No power to front panel but have power to main unit.
You Have constant power (yellow wire) but your Acc wire or switched power wire (RED WIRE) does not have power. Check the connection of this wire. You most likely have a blown fuse in your vehicles fuse panel.
May 19, 2009 | Sony Xplod CD Player w/MP3 Playback...
Sony Dax HDZ235 DVd player
the circuits might be fried. you may need to replace the player. sorry
wg
Feb 11, 2008 | Sony DVP-NS715P DVD Player
Shuts down intermittently while watching DVD's
you may open your dvd casing and check with the capacitor next to the fuse this is busted you may notice that it deformed, remove and replace with the same specifications
Dec 19, 2007 | Sony DVP-S725D DVD Player
Dec 14, 2007 | Sony DVP-NS50P DVD Player
Sony DVP-S725D DVD Player Logo
190 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
