Question about Vodavi 30-Button XTS Telephone
My Vodavi 30 button exec phone will not ring but is ringing through other stations. I am still able to pick-up the calls. How do I turn my ringer on?
pazman
  • 81 Answers
SOURCE: no ringer for incoming call
I have seen this issue before and panasonic knows about it. I would contact them directly.
Posted on Mar 30, 2008
SOURCE: phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
Posted on Oct 19, 2008
  • 149 Answers
SOURCE: when a call comes in the ringer doesn"t ring
you need to have the phone programmed to ring. ldtsnj.com can help
Posted on Jan 02, 2009
consultel1
  • 860 Answers
SOURCE: phone wont ring on incomming calls?
Could be two things, first is DND or do not disturb. Make sure that its turned off by either pressing the DND button or feature #85.The second is that the ringing wasn't turned on in programming.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
Posted on Mar 26, 2009
cnavarro
  • 2460 Answers
SOURCE: How do you get a Vodavi xts phone to ring for an outside line
You're probably looking in the EXTENSION USER'S GUIDE. The sytsem installation/programming manual has the proper FLASH codes and programming access to make it work.
As far as the random calling, try changing phones with another and see if the problem stays with the set or the location. If it's set, you have a bad one, if location, I'd be looking at a wiring error.
Carl
Posted on Oct 14, 2009
I can't get one of my phones to ring
THese are lovely questions because the phone either doesn't ring because the ringer is off/broken, or it's in a port not programmed to ring. The first is easy. Swap a different phone into the same location ad if it rings, you have a bad ringer.
The second issue, means that you have access to and know system programming to allow Station Ring Assignments. That's beyond the scope of a free forum. to even suggest how to program, but you mgiht start with the manual if that's your problem.
Carl
Oct 08, 2010 | Vodavi Starplus SP7314-08 Corded Phone
Our church has a vodavi starplus sts phone system. one of the phones does not ring, can someone please tell us how to fix the problem.
You must go into CO line programming and put that station into the ring assignments for each outside line you want to ring at that station. It's Flash 40, page A, button 10.
Sep 23, 2009 | Vodavi Starplus SP7314-08 Corded Phone
Be able to pick up incoming calls from all front office phone sta
Get a copy of the manual here
http://www.cactcom.com/Manuals/Vodavi/Vodavi%20DHS/Vodavi%20Starplus%20DHS%20Installation%20And%20Maint%201995.PDF
Looks like you can group the stations together and then any one of them can answer incoming calls. See page 45 or so.
Jan 22, 2009 | Vodavi Starplus SP7314-08 Corded Phone
Incoming calls bypass greeting - no way to dial extentions
If this hasn't been solved, I am Vodavi certified. Give me a ring
Nov 21, 2008 | Vodavi Starplus SP7314-08 Corded Phone
Would like to select different ring tones for 3 separate stations
If this hasn't been solved, I am a certified Vodavi tech. Give me a call
Sep 29, 2008 | Vodavi 30-Button XTS Telephone
Phone doesn't ring at station
Sounds like your station (phone) is set to not ring. You need to check your ring assignment.
Feat # *
Enter password (default is 000000)
Press the soft key under "show"
Press the soft key under "next" until 1. STATION appears in the display.
Press the soft key under "show" SHOW STA:_ appears.
Enter your station number and press the show soft key
Press the "next" soft key until RING ASSIGNMENT shows on the display.
Press the "show" soft key. You will see CO LINE 1 : followed by NONE or DAY or NITE or BOTH.
If it says NONE, your phone never rings for an incoming call. If DAY or NIGHT your phone rings depending on the time of day and the time definitions for DAY and NIGHT programmed into the KEY unit. If it says BOTH, your phone should ring all the time.
If you need to change the setting, press the "chg" soft key until the desired setting comes up.
When you're done with LINE 1, press the "next" soft key to move to the next line. Repeat the process for all your active lines. Obvisously changing settings on lines with no CO connection will have no affect.
While your in the mode, check your RECEIVE ASSIGNM as well to make sure your phone is configured to receive incoming call. It was the station feature just before the RING ASSIGNMENT feature.
Hope this helps.
Jun 04, 2008 | Vodavi Starplus SP7314-08 Corded Phone
Oncoming phone calls from internal ext go directly to speakerphone instead of ringing
If this is on just your extension, dial 640 without picking up the handset. The phone should beep twice. If not, hang up the phone and let me know. If this is helpful, please post as such.
Apr 29, 2008 | Vodavi 30-Button XTS Telephone
If this hasn't been solved, I am a certified Vodavi tech. Give me a ring
Apr 05, 2008 | Vodavi 30-Button XTS Telephone
Ringer off
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
Jan 17, 2008 | Vtech VT-9118 Cordless Phone
Vodavi 30-Button XTS Telephone Logo
263 people viewed this question
Top Vodavi Lands Phones Experts
Oloyede Monsuru
ray gallant
vince
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
