Question about Bose Companion II Computer Speakers
Computer speakers play CDs or iTuners, but no system sounds or online sounds. Computer does not recognize that speakers are attached, so I can't adjust volume. Everything worked normally several months ago.
  • 3,267 Answers
The integrated sound of your MB has konked out. Thus it plays CD/DVD since its output must be connected directly to that port. Best will be to get a sound card(compatible with your OS) and insert it on any PCI slot and take all sound output from the sockets provided on the sound card...............sodeep
Posted on Sep 24, 2009
    Scholar:
  • 78 Answers
This is an issue with your soundcard. the easiest thing for you to do would be to go and pick up a cheap internal soundcard ($10 - $200) and just use it instead.
Testimonial: "Thank you, but then why does it still play CDs and iTunes with no trouble?"
Cant get speaker to work hear only static
First try to attach the speaker to another device, DV Player, Amp, Audio Receiver, etc. See if the set works on any other device and if they do; the problem is with the computer sound in or software that allows the speakers to generate sound-out. Check also that you have the computer set to play sound! Look at the speaker symbol at the lower right of the screen and it should indicate it is active. Right click and it should tell you if it 100%. Open the Volume Mixer and see if your speakers are recognized and set the Volume. Always make certain the speakers are attached to the proper GREEN in port on the sound section on the back-side of the computer. If you have more than one colored plugs, be certain to insert according to the color.
Dec 19, 2013 | Audio Players & Recorders
While playing MP3 and movies in the system . The sound automatically brakes .i have also reinstalled the audio software . while playing MP3 from the internet also there is a sound brake up. plz send me why...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Mar 02, 2011 | Computers & Internet
Speakers make no sound and not recognized
shut down the computer then unplug the speaker.then wait a little and restart it. as soon as it is ready,plug in the speaker. It should recognize and search for drivers. and the it should work fine. .
Jan 06, 2010 | Kinyo PS-107 Computer Speakers
Itunes downloads jump is it a problem of computer
What you're describing sounds like it would be a problem with your media player, which in this case would be iTunes. Try playing music through another media player ( Like Windows Media Player ) and see if music still jumps. If it still does, then it's a computer issue, if it doesn't, it's just iTunes. The music jumping shouldn't have anything to do with your speakers.
Jul 06, 2009 | Bose Companion 5 Multimedia Speaker System...
How to play mp3 audio cds in 5.1 channel speakers
I HAVE PHILIPS DVD(5.1)CHANNEL...IT HAS THE FACILITY TO PLAY ALL KIUND OF CDS, DVD..ETC..JUST TRY OR WHAT'S YOUR PROBLEM...GIVE A BRIEF ABOUT IT
Jun 29, 2009 | Creative Labs Inspire 5300 Computer...
Dell Inspiron 5150 not playing sound
Your speakers are frying, hence the crackling sound, as this is a frequent problem owing to the location of the speaker assemblies and the sound output in an area of the system where the ambient heat exhaust vents are located.
I am a bit confused, though, as to why you get no better sound through headphones or external speakers, since this is not usually the case in this frequently cited problem.
One possibility is that not only are the speakers, but the entire sound output assembly.
Warrantee work if available, if not try a shop where they also sell used Dell computers as they will have pulls that could cut your losses.
Mar 29, 2009 | Dell Inspiron 5150 Notebook
No sound from system
my speakers will not work if im on the internet they work if i go on my ituns. How can I get the sound to work ? I went into my computer and in the sound. Im just not sure what area to change ? Can you Help ? Thank you, Sharon
Mar 07, 2009 | Logitech X-530 Computer Speakers
Speakers no longer working
Unplug teh speakers, restart the computer, plug in the speaks, the system should pickup the speakers.
Dec 04, 2008 | Dell Inspiron 6000 Notebook
Usb speakers
You need to install the sound card drivers for your PC, check the cds / software that cvame with your PC, or go online to PC manufacturer's site to download drivers for your system.
Apr 27, 2008 | Audio Players & Recorders
Lacie d2 DVD RW external importing music CDs into iTunes
Apple late Thursday posted iTunes Repair Tool for Vista 1.0, a software update that fixes iTunes issues reported by new Windows Vista users. According to widespread reports, music purchased from the iTunes Store could not be played in iTunes on the new Microsoft operating system released this week. Users reported that they received a message saying their computer was not authorized to play the purchased tracks. “The iTunes Repair Tool for Vista 1.0 will repair permissions for important files required by iTunes to play your iTunes Store purchases,” Apple states in the brief release notes.
Feb 17, 2008 | Computers & Internet
Bose Companion  II Computer Speakers Logo
98 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
