Question about Western Digital (WD3200JS) 320 GB Hard Drive
Computer identifies attached drive but does not locate it in computer file folders
Western digital (wd3200js)320gb have failed in receiver taken out and run in 3.5 external enclosure using proper connecting cables but my computer is not recognizing there is a hard drive connected. I am using pvr explorer what to do for data recovery.
Posted on Dec 15, 2009
Does my Maxtor back up my iphotos?
Run a time machine backup. Then the easiest way would be to find a photo that you are willing to delete in iPhoto.
Jot down the name of the photo file, delete it. Then empty the trash.
Then go into time machine, try to search for that file, when you locate it, restore it. If you can then there is probably a good chance that you time machine backup is good.
To be on the safe side why not create a manual backup.
You'll find the iPhoto Library at:
/Users/username/Pictures
"username" will be your name that appears when you login to the computer.
  1. To get there, double-click the icon for your hard drive to open it, then double-click the Users folder. Double-click your Home folder, which is identified by a house icon and your username, and then double-click the Pictures folder to open it.
        1. Inside the Pictures folder you'll see a file called iPhoto Library. Copy the iPhoto Library file to a location other than your hard drive, such as your Maxtor external hard drive.
Feb 12, 2014 | Apple MacBook Pro Laptop Computer with...
Tip
Outlook: "Cannot create file"
Error message when you try to open or save an e-mail attachment in Outlook: "Cannot create file"
This issue may occur when the Temporary Internet Files folder is stored on a server on which you
do not have sufficient permissions
If you are using Outlook 2003 or 2007, follow these steps:
  • Click My Computer, and then double-click drive C.
  • On the File menu, click New, and then click Folder.
  • Name the folder temp0.
  • Click Start, click Run, type regedit, and then click OK.
  • Locate and then click the following registry key:
  • HKEY_CURRENT_USERSoftwareMicrosoftOffice .0OutlookSecurity
  • In the right pane, double-click OutlookSecureTempFolder.
  • In Value Data field, type C: emp0 and then click OK.
  • Exit Registry Editor.
  • Restart the computer.
on Feb 19, 2011 | Computers & Internet
How do I refresh my micro scan disk?
With the scandisk inserted in your computer, locate the drive where you inserted and the file folder with the data you want to erase and delete or empty the file folder. If you do not have an available drive to place the scandisk, connect the media device with the scandisk included and locate the data via drive/file folder. You can locate the drive/file folder by clicking start>computer>drivelocation>scandisk folder.
Apr 19, 2013 | SanDisk 2GB microSD Memory Card
Iomega 1tb drive have files hidden
You might not have the appropriate software installed on your computer to show / read the files
IE: adobe flash , directx , win zip , codec , word ......
Determine if access is denied by a sharing violation because the folder and its files are in use by someone else or the computer itself. Wait several minutes, and then attempt to access the folder again. Go to the location where the file or its folder are stored on your computer. Lock files are hidden files in Microsoft Windows. Select "Show hidden files." The lock files for Windows applications have a ~ symbol in front of the file name. For example, for test.txt, the lock file is named ~test.txt. In UNIX, the lock file may be identified by an extension of .lock or .swp within in the file name. Delete the lock file. The locked file or folder unlocks. Reboot your computer, and bring it up in Safe Mode. This prevents the startup of many of the system services and programs that could be locking the files or folders. Attempt to access the folder location and its contents. If the folder is available, save the folder or its contents in a directory to which you have access. Record the active processes running on the computer and the programs available in Safe Mode. Then, log into the computer after a normal boot up. Review the applications running in the background in normal setup. One of these applications may be preventing access to the file folder and its contents. If there are applications that run in normal mode that do not run in Safe Mode, turn off those applications. Then, try to access the file folder again. b> Are the Security Permissions for the Folder or Its Contents Preventing Access? b> Check the file folder permissions by right-clicking on the folder and selecting "Properties." In the "Properties" dialog box, select the "Security" tab. The "Name" list box includes the user and group permissions. If there is no "read," "read and execute," or "write" permissions in your user profile, you do not have permission to view the file folder or its contents. These security permissions are typically set by system administrators. System administrators may be trying to prevent end users from altering system files that are critical to the computer running smoothly. Contact your system administrator, and request local administrative rights to the computer. This allows you to gain access to the files and folders that are restricted to administrators. Edit the system policies using administrative tools via the gpedit.msc program. Users can add, read and modify permissions for folders and other objects via this program. Full control is the best system policy, because it includes read, write, execute and modify rights. However, access to the gpedit.msc program may be restricted, as well. Go to the command line (press on the "Windows" and the "R" keys on your keyboard at the same time), and enter the CACLS command for the folder name. Use the command format: C:\> cacls <foldername> /E /G <username>:F CALCS stands for Change the Access Control ListS. This command allows you to add your user name to the security settings to permit access to the protected system folder when the gpedit.msc program is not available. Hope this helps.
b>
Dec 10, 2012 | Iomega 1TB Prestige External USB 2.0 Hard...
Cant seem to be able to download music onto it off computer didnt get any instructions with it
Hi Oligan10,
Attached below are 10 easy steps to get you started in playing your favorite music using your PSP.
step 1 Take a USB 2.0 cable and connect the PSP to your computer step 2 Press the home button on the PSP step 3 Use the left and right buttons to find Settings ( select by pressing the X button ) step 4 Select USB Connection -Your computer will notify you that a new USB device has been connected This should show up as a new hard drive with a corresponding letter identifier step 5 On your computer, select the correct drive letter and open PSP file system step 6 Create a new folder and call it PSP step 7 Go inside this new PSP folder and create another folder. Name it MUSIC step 8 On your computer hard drive, Select the MP3 music files that you want to transfer and save it into the MUSIC folder that you have just created step 9 Disconnect the PSP from your computer by pressing the O button step 10 Unplug the USB cable.
To View and Play the downloaded music on your PSP :
- Use the left and right buttons and select MUSIC - Select Memory Stick by pressing the X button You should see all the music files you have just transfered to the PSP.
I have attached a link to the PSP Manual, should you need more information about your PSP. http://www.fixya.com/support/p201358-sony_playstation_portable_psp_console/manual-16250
All the best to you my fellow PSP enthusiast.
Jan 26, 2011 | Sony PlayStation Portable (PSP) Slim...
Hi, I just purchased the nexxtech 2gb to cop my photos. I am 65 of age. Just starting into this. Iput it into the back of my computer and nothing happened
When you say "put it into the back of my computer", I assume you mean you connected it with a USB cable? It is perfectly normal for "nothing" to happen. This doesn't mean it isn't connected or ready for use. Open the START/WINDOWS menu in the bottom left corner of your desktop and from the resulting pop-up menu, click on "Computer" in the right-hand column. You should then get a list of devices/drives connected to your PC.
Depending on what else is connected, The Nexxtech 2GB should be listed under the heading "Removable Storage" as either USB Mass Storage (D:) or possibly Nexxtech (D:).
(D:) Simply denotes a drive path but it could also be listed as (E:), (F:), or (G:) depending on how many other devices are already attached. Once you have identified the drive in this list, you can double-click on it with the left mouse button to open it and it will function like any other folder on your PC. You can copy files or folders to it, create new folders and delete files and folders.
If you have opened the list of drives as detailed as above and cannot identify your nexxtech drive in the list, please post back with details of which drives DO appear in the list and I will try to assist you further.
Regards,
BElectric
Nov 25, 2010 | Computers & Internet
Mini attache usb2.0 How do I transfer pictures in their folder from computer to mini attache
Plug the USB drive into the computer, it should install and then give you the option to explore the drive.
Go to the folder with the files you want on the USB drive.
You can either copy and paste the files to the USB drive or just drag and drop them into the USB drive
Aug 05, 2010 | Computers & Internet
How do I delete or repair the threat to my Laptop system that has
HOW TO REMOVE RAILA ODINGA VIRUS IN 2 MINUTES
How to remove raila odinga virus is a very easy process. Firstly, Raila odinga is a worm that attacks Microsoft word files, but it looks like a JPG file and mostly found on the desktop.
Raila odinga has some common characteristics
1. If you delete the picture file it will delete and return to where it was.
2. It runs from the driver folder in system 32 folder
3. it auto runs at system startup
4. It makes the computer boot slowly
5. It makes your computer to hang.
6. It creates new folder.exe folders in your computer
How to remove raila odinga virus, open my computer, double click drive C: open WINDOWS folder, double click on system 32 folder, open driver folder,
locate the word file in the folder, note the name. Right click on the task bar, open task manager, click on the process tab locate the name of the word file you saw in the drive folder, right click on the name of the file, click end process, to terminate the running process
Open the driver folder of system 32 where the file is, delete all the ms word files on that folder, then close the folder locate the raila odinga picture file usually on the desktop or somewhere in your computer, delete the picture file. Please do not double click on the picture file only delete it, finally empty your recycle bin and restart your computer. That way odinga is off your machine.
Mar 25, 2010 | Computers & Internet
HOW DO I COPY DATA FROM MY COMPUTER TO MY SIMPLETECH DRIVE?
Attach the simple tech using the USB cable, wait for the computer to read the new hardware and install the driver, the new drive will appear in the "My Computer" folder which shows all the attached hardware. The computer will issue the new external drive a drive letter, that identifies it to the computer. Double click on this external drive to open it. The right click on any file you want to copy over to the new drive and click on copy, then go over to the external drive folder and right click and hit paste.
Jan 13, 2010 | Computers & Internet
How do i transfer photos from my hp photosmart m537 camera to sandisk cruzer micro usb 2.0 flash drive 2gb.
Connect the HP camera to your windows pc using the usb cable provided. Open My Computer to ensure that the camera is being properly enumerated (given a hard disk letter). make note of the drive letter assigned.
If you have more than one USB port, insert your cruzer micro 2.0 stick into another USB port. Look in my computer again to determine what drive letter was assigned to the flash stick. Open a windows explorer window for each of the locations. One for the camera, the other for the flash stick. Its likely that the picture files are in a subfolder of a folder called DCIM.
Once you locate the files you want to transfer, you can highlight them using the mouse (click/drag a box around the files you want) and drag them to the other open window (flash stick folder)
If you don't have another available USB slot on the compter, you'll need to copy the files from the camera to a temporary location on your computer and then move them to the flash drive. In this case, make a new folder on the desktop and name it temporaryfiles. open that folder. open the drive letter assigned to the camera and copy whatever files you want from the camera to 'temporaryfiles'...
Then power off the camera and remove the usb cord from the computer. attach the flash disk to the newly free'd up usb port and open a windows explorer window to it. drag whatever files you want from 'temporaryfiles' folder into the folder for the flash stick.
I hope this helps!
-Ray
Mar 02, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Western Digital (WD3200JS) 320 GB Hard Drive Logo
232 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
