Question about Sony Ericsson Walkman W810i Cellular Phone
Hi my sony ericsson walkman w580i screen not working but buttons light up hasnt got wet, what can i do
Need nck code for sony ericson W580i phone
You can get the NCK code for your Sony Ericsson W580i from your service provider or from any online sites!! I would recommendt mobileunlocksolutions.com , they provide perfect codes at reasonable price!!!
Jul 19, 2012 | Sony Ericsson Walkman® W880i Cellular...
Tip
How to Put a DVD movie On Your Sony Ericsson w580i on Mac OS X
I just purchased the Sony Ericsson w580i; I want to convert a few DVDs so I can watch them on my phone. The problem is that I don't know the first thing about doing it. What format will I need to convert the DVD?
-- from U.K Pinky
The Sony Ericsson w580i is one of Sony Ericsson's lines of Walkman-branded handsets. These music focused phones are popular globally, but few of them have made it to the United States. The W580i is one of the few that has, carried by AT&T. And it's a good pick for the carrier.
The sound quality through the included stereo earbud headphones is superb and if you turn on the MegaBass boost feature in the Walkman player, the phone outputs full and powerful sound that booms. The W580i also has support for A2DP which allows the phone to play music via Bluetooth to stereo headphones. Like other Walkman phones, the W580i supports music files in the MP3/AAC/AAC+/e-AAC+) formats and you can rip music CDs using the included Disc2Phone software for Windows or using Sony Ericsson DVD Ripper for Mac.
Want to watch DVD Movie on Sony Ericsson w580i The Sony Ericsson W580i has a 2 QVGA display that's capable of displaying 262K colors. Pictures, videos and music visualizations look good and the screen is amazingly usable outdoors even in direct sunlight. Have you ever tried to upload DVD to Sony Ericsson w580i? The following tips will be your Sony Ericsson w580i's assistant to help you get more fun to watch DVD movies on your Sony Ericsson w580i for Mac user.
Before converting DVD to Sony Ericsson w580i, you should get to know about what kinds of formats are supported by our Sony Ericsson w580i phone. Here I list all the supported video /audio formats playable on Sony Ericsson w580i Smartphone.
Video/audio formats supported by Sony Ericsson w580i: * Video clips in MP4 (generally MP4 is preferable with better picture quality), 3GP
* Music/audio files in MP3, MP4, AAC, WMA, WAV, AMR act.
Below is the detailed tutorial about how to Convert DVD to Sony Ericsson w580i on Mac. Step1. Download and install DVD Ripping software Mac running it and then load the DVD movie from your Mac Step2. Select Output Setting Select "MPEG-4 Movie (*.mp4)" from the output format list in "Format" drop-down list. Step3. Convert DVD to Sony Ericsson w580i on Mac When the settings are done, click the "Start" button to start conversion. And then the program will automatically start to convert DVD to Sony Ericsson w580i. That's all. When the conversion is finished, you can click “Open” to locate the file in your hard drive.
Finally, just put the converted DVD to Sony Ericsson w580i, and now you can enjoy DVD movies on your Sony Ericsson w580i phones anytime and anyplace. You can also convert some part of the DVD to Sony Ericsson w580i or convert DVD to the other portable player compatible formats.
on Jun 02, 2010 | Cell Phones
Lcd light
More than likely you will need to replace the LCD screen. The backlight may have burned out making it blank.
A new LCD screen runs about 15 dollars shipped from ebay2.gif.
The W580i LCD screen is very easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony W580i LCD Screen Replacement
I hope that helps you out
Jul 24, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Sony ericsson W580 cell phone
More than likely you will need to replace the LCD screen. The backlight may have burned out making it blank or it the LCD connector may have come loose.
A new LCD screen runs about 15 dollars shipped from ebay.
The W580i LCD is easy, easy to replace. Probably one of the easiest I have ever done.
Jun 10, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson 580water drops are visible in the screen. the phone
Check out the following link for instructions on taking off tthe LCD display screen
Sony W580i Display Screen Removal
Jun 09, 2009 | Sony Ericsson Walkman W810i Cellular Phone
My w580i walkman was droped in the pool
Best thing to do right away is remove the battery and put it in a bowl of dry rice if you have any to start absorbing the water out. Not sure about the left front button coming out. Good luck.
Jan 31, 2009 | Sony Ericsson w580i Cellular Phone
W580i Return key stopped working and won't let me scroll up
go to sony ericsson service centre and tell to change bonzer flex
Nov 19, 2008 | Sony Ericsson w580i Cellular Phone
I hav a sonyericsson w580i and my right button, walkman, and applications button does not work -
The w580's sometimes get a short in a bend in the upper switch flex. It needs to be replaced. I'd bet that the lights on the right and left side of those outer buttons are different colors. Try applying light pressure just below the LCD screen and see if it brings those buttons back. If it does, that flex is bad and needs to be replaced.
Contact www.wirelessunlimitedinc.com, or www.myspace.com/wirelessunlimited. They can take care of that a lot cheaper than sony ericsson can. If you can find the part on line, you have to completely disassemble the phone from the back through the front to get to that flex. Switch Flex for Sony Ericsson w580i.
Jul 31, 2008 | Sony Ericsson Cell Phones
Sony ericsson w580i
Put your phone under a light bolt about one and a half feet away from the light. The heat of the light bulb or a lamb will make it dry internally. Do this for about one hour or two with the phone off. Take notice your phone might not work as well again. If you have insurance try to get a new phone.
Artgirl
Jul 18, 2008 | Sony Ericsson Walkman W810i Cellular Phone
My Screen for my W580i is black, but side lights are on
This is most probably a software/firmware issue with the phone. Try updating the software with the Sony Ericsson update service.
http://www.sonyericsson.com/cws/support/products/updateservice/w580i?cc=gb&lc=en
If this doesn't work you will need to have it flashed with proper equipment,
Mar 29, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
134 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
