Question about Farmall Tractor C ,super Av, Complete Gasket Set
I have a mtd wont start ridding mower the air filter get flooded with gas
    Top Expert:
  • Farmall Master
  • 12,113 Answers
Either float stuck or a small piece of debris is stuck in carb remove carb and clean and check for proper float movement
Posted on Sep 24, 2009
Mower running on full choke?
I installed a fuel shut-off. To solve my problem.
Apr 09, 2014 | Mtd Garden
Manual
run with gas treatment like gumout and fuel stabilizer like seafoam to rid of ethanol and replace plug and air filter ..is it a briggs and stratton ?
Jul 27, 2013 | Mtd 22" Yard Machine Push Mower
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
My mower will start but not run. Oil and gas is leaking from exhuast and filter. What could be wrong?
if the filter is a sponge filter then it's suppose to have oil in it(helps trap dirt) and if your getting gas out of the muffler then the engine is flooding when you try to start it..good luck
Apr 05, 2010 | Mtd 22" Yard Machine Push Mower
Alright i have a riding mower yardman and i poured some gas down under the air intake cover down some black hole right next to the air filter..now it wont start and nuthin will turn.just a click.
the black hole is a crankcase vacume tube not a big deal there but i would check the battery connections and the battery. if you use gas directly in the carb to start it doesent take more than a tea spoon to do it you will flood the engine and drain you battery just trying to start it.
Jul 17, 2009 | Mtd Arnold Corp No. Mtr - 42 - Ec 42" Mwr...
My yard man mtd lawn mower.starts and stop runing it wont start inless i got the chok out and then it stops runing
i would check the linkage at the carb 1'st to make sure nothing is broken or disconnected.hope this helps
Jul 16, 2009 | Mtd Garden
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Yard Machine MTD push lawn mower won't start
Sounds like you need a complete tuneup. Start with the carb. then clean all coil contacts, air filter and this will start you in the right direction. Good luck.
Mar 24, 2009 | Mtd 22" Yard Machine Push Mower
Farmall Tractor C ,super Av, Complete Gasket Set Logo
145 people viewed this question
Top Farmall Garden Experts
Dennis Key
Dennis Key
john h
Colin Stickland
Colin Stickland
Are you a Farmall Garden Expert? Answer questions, earn points and help others
