Question about Kenmore Dryers
1 year old Kenmore dryer tumbles but doesn't heat.
1 year old Kenmore electric dryer tumbles but doesn't heat. I've checked the circuit breakers, and cleaned lint trap and vent. It stopped abruptly, not gradually.
Thanks,
    President:
  • 1,185 Answers
If it is 1 year old, call Kenmore , they will probably fix it as a courtesy call.
If not quote that the machine is not fit for purpose as it should not have gone wrong so quick
Posted on Sep 24, 2009
Dryer has lost heat.
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Gas Dryer---
2. Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3. Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4. Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5. Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps...
Daniel
Dec 11, 2010 | Kenmore 700 6972 Dryer
I have a Kenmore Dryer model #110.66732500 that just quit heating. Everything else is working fine, tumbles but no heat. It is 4.5 years old. When it quit it tripped the circuit breaker, we reset the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
bn
Sep 28, 2010 | Kenmore Dryers
My kenmore dryer runs but not drying and no heat.plz let me know waht i should do?
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 25, 2010 | Kenmore 63942 Dryer
Kenmore 80 series dryer does not hest
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 25, 2010 | Kenmore Dryers
My dryer is working but not heating
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 20, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer stops while cloths are still damp
Hi
Electric Dryer---
Hope this helps...
Daniel
Sep 19, 2010 | Kenmore 64902 Electric Dryer
MY OLD GE ELECTRIC DRYER TURNS ON BUT WILL NOT HEAT
Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Thank you
Aug 02, 2010 | GE Profile Harmony DPGT750EC Electric...
My Kenmore electric dryer model# 64652400 is not heating.
Hi
If your dryer doesn't heat, check these:
Fuses Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Please revert for further assistance and Do rate the solution as FixYa if found useful.
Thanks
Rylee
Mar 16, 2009 | Kenmore 64652 Electric Dryer
My Roper Electric Dryer will not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Heating element
Thermal fuse
Wiring
Mar 07, 2008 | Roper REX3614KW Electric Dryer
Dryers Logo
155 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
