Question about Dometic Refrigerators
Dometic 3 way fridge
Works on 12v and gas but not on 240v
5 Suggested Answers
  • 159 Answers
SOURCE: maintenance
there are nothing to service on this type of fride but is almost the best type
Posted on May 16, 2009
  • 68 Answers
SOURCE: fridge wont get cold with gas
This is worth a try. Disconect the gas and power make sure the pilot light is out. Turn the fidge unside down overnight then unright again. Try it on gas agian. This worth a couple of goes before giving up.
Posted on Aug 30, 2009
SOURCE: My 3-way Dometic fridge works on gas but stopped
With the 240V element diconnected, test it with an ohm meter to find it was open circuit. No heat! The 12v element still had resistance.
At the moment gas is still keeping my cool while I wait for a new element to arrive. ..... cheers
Posted on Sep 02, 2009
  • 21840 Answers
SOURCE: my fridge freezer works on 12v and mains it lights
it needs regassing ,any fridge repair shop should be able to do this for you ,unless its been unused for any length of time in which case turn it upside down and levae 24 hrs this often works
Posted on Sep 19, 2010
SOURCE: We have just bought a
look on the back and you should see a switch like alight switch it well have a.c or d.c on it
Posted on Apr 16, 2011
0 characters
1 Points
Dometic 3 way fridge won, t work on 12v
read the manual .is all I can suggest
Feb 14, 2015 | Dometic Refrigerators
I have acquired a finch b533g 3 way fridge but without instructions. Can anyone help with simple steps for 240v and 12v . The gas is covered by factory stickers. Thanks in advance
as this product is rather ancient, manual is difficult to obtain, i can suggest enquire in sports stores which still sell this product, manufacturer is obscure, but fridge itself is one of teh best and cheapest on the market! new one is sold for anything between $500 and $800. it was first manufactured over 25years ago... have friend which is still using it...
have short preview for it:
and i think this will be best manual for it:,d.dGc
hope this will help you - do not forget to vote...
Feb 10, 2015 | Refrigerators
How to convert 110v to 240v dometic 2652 fridge ?
Simple solution would be to step down the 240V to 110 V with a transformer .
Jul 01, 2014 | Dometic RM2652 Refrigerator
Chescold rc1180 users manual
It appears that your brand branches off to many first name brand's like=> Chescold RC1180, 50 litre, 3 way, (12v,Gas,240v)
Here is the user manual=>
Combi Box 3 Way Fridge & Freezer RC1180
sea_breeze_111.jpg Caravan's Plus
RC 1180 EGP Fact is I could see so many different versions I am leaving you with a few extra divisions of Dometic. Should you need more answers please let me know, Thanks, Sea Breeze Please rate this solution. Sea Breeze
Mar 13, 2011 | Dometic Refrigerators
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Jan 23, 2011 | Dometic Refrigerators
Electrolux 3 way fridge will not work on 12v or 240,switch lights up, ok on gas. can i repaire?or have i got to replace? i think the model No is rm4200 or rm4230
Hi My three way fridge has the same problem. Have solved the 12v problem as it was not wired to the 12v invertor. Do you have an on board battery supply? the 12v is usless and runs a battery flat in no time. Better off to use gas. Hope to have the electrician here next week to check 240v so will let you know if we find a problem. Graham.
Jul 07, 2010 | Electrolux Refrigerators
RM6270 in a touring caravan, over 5 yrs old. Worked fine until mid-Sept, when it ceased on 240V, 12V & gas still good. Any other sources of the problem possible, other than the 240V element (e.g. power...
Some of the Dometics have what was called the 'Dinosaur Board' which is a circuit card which controls the unit.
Not sure if it applies to your exact model, but if there is a company who just makes replacement control boards for Dometic fridges, that is a big fat clue, in my book. Cheers.
Oct 21, 2009 | Dometic RM2652 Refrigerator
My 3-way Dometic fridge works on gas but stopped working on 240V! ....Why?
Sep 01, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
104 people viewed this question
Top Dometic Refrigerators Experts
Mike Butler
Mike Butler
John Tripp
John Tripp
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
