Question about Sony PlayStation Portable (PSP) Console
How do i reboot my psp?
My psp was working perfect and i could get on the internet but since inserting a UMD video and stopping it halfway through, my psp hasn't worked since. no sound, a blank screen and the power wont stay on even though its fully charged. is it possible to reboot my psp?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 44 Answers
Have you tried turning on, but then hold the power switch down for around 10-15 seconds or until the power light simply turns off, no flashing. If not, then you should jump on the internet and look for a so-called Pandora Battery and Magic Memory Stick. They will actually install custom firmware on your PSP which you can remove later on, but if you use those, it should unbrick the PSP, so you can use it again.
Posted on Sep 24, 2009
My son psp beep when you put a game in and the umd does not come up can you help please
f you are experiencing issues when using a Universal Media Disc (UMD™) on the PSP system, try these troubleshooting options:
  • Issues with PlayStation®Store content Click here for help with content purchased from the PlayStation Store.
  • Restore Default Settings Restore Default settings will default the PSP system to its original settings. A setting change may be the reason the PSP system is having difficulties. Click here to learn how to restore default settings on the PSPgo / PSP system.
  • Confirm UMD is properly inserted
    Make sure the UMD is properly inserted with the label facing the back of the PSP system. Try removing the UMD and reinserting it.
    Please note, it is normal for the PSP system to make noises while it is reading from a UMD.
    For PSP-1001, slide the latch to open the UMD door. For the PSP-2001 and PSP-3001, simply lift the door open.
  • Try playing the UMD on a different PSP system If possible, try playing the UMD on a different PSP system. If the disc still does not function properly, it might need to be replaced. If the disc does function properly, the PSP system may need service, see PSP Service for details.
  • Try playing a different UMD on the PSP system If possible, try playing a different UMD on the PSP system. If another UMD plays, the original UMD may be the problem. If none of the UMD's play, the problem may be isolated to the PSP system.
  • Check for moisture Do not let the PSP system or any PSP® accessories come in contact with liquid. Also check for moisture condensation in the PSP system. If moisture condensation occurs, remove the disc from the PSP and do not use the PSP until the condensation has evaporated, which can take an hour or two. In general, if any part of the PSP gets wet, discontinue use until it is completely dry.
  • Check the regional code Check the regional code on the UMD™ Video. The only regional codes that the North American PSP® is tested to work properly with are "ALL" and "1.
Tried these steps and still need help?
If you have tried the troubleshooting information above, but continue to experience problems, please contact our Consumer Services department to have your PSP system serviced.
Jun 28, 2011 | Sony PlayStation Portable (PSP) Console
When I switch on my PSP, it directly goes onto load the UMD game and when I try to quit using HOME button, the buttons and consoles dont work. Then I need to use the hold button after which though the...
Hi. Since you're in UMD Autoload mode, you need to configure that in the PSP Settings. To do this, turn off your PSP and remove your UMD. Now, turn it back on and it won't autoload your UMD since it wasn't there anymore.
Now, go to "Settings" and scroll down to "System Settings" and press X. Scroll down again the selection until you see "UMD Auto-Start" and press X. At the right side will appear the options "ON" and "OFF". Select "OFF" and press O button several times to go back to main screen.
Insert your UMD. Now, try playing games from Memory Stick. You may have to turn off your PSP and turn it on again to finally play homebrew...
I hope this helps...
Jun 07, 2011 | Sony PlayStation Portable (PSP) Console
When I insert a new UMD i get the game could not be started. 80020148. The UMD is recognised and the thumbnail appears on the menu, but the game will not start. Please help.
Solution: 1) You must first backup ur data on your memory stick to your PC. Mainly the saved games data. ( directory is PSP\SAVEDATA) 2) Format the memory stick using the PSP format tool in system settings...not your PC. 3) In System Setting UNCHECK or UNSELECT "UMD Cache" this must be off!!!! 4) Connect your psp via USB cable 5) Copy your game saves / data back to your psp remember >> PSP\SAVEDATA . 6) Do a hard reboot of your psp ie hold the power switch for 3 seconds and it will reboot. 7) Your UMD games should now work with no probs.
Nov 25, 2010 | Video Game Consoles & Games
Psp doesnt read the umd
hi,
you may hack your PSP in order to run ISO's (UMD copies on your memory stick), if you dont know how, search on the internet, or contact me by email. a_n_s.modding@live.com
Sep 27, 2009 | Sony PlayStation Portable (PSP) Console
My sons psp game menu is not showing the umd option what is wrong with it cheers
If memory serves (I lost my PSP while moving) the UMD menu only appears when a UMD is inserted and recognized. If a UMD is inserted but the menu does not come up then either the UMD is bad or the laser is defective.
Jan 04, 2009 | Sony PlayStation Portable (PSP) Console
UMD on PSP Slim will not spin
No idea, if its not spinning u definitely need to buy a new Laser Assembly. Sry!
Nov 13, 2008 | Sony PlayStation Portable (PSP) Slim...
I recently updated to firmware 4.05 on my psp since then i have lost the umd icon on my psp
Go to
Systems>> Systems Setttings>> Restore Default Settings
after that the PSP will reboot...
Insert a UMD on the drive and check now... icon will be there...
Jul 25, 2008 | Video Game Consoles & Games
Sony psp
The PSP doesnt realy have any play options when u insert a UMD it will either start atomaticly or you can choose through system settings to turn on or off the UMD auto start which enables the PSP to automaticly start or you can disable the auto start or you can press x on the UMD icon and it will start.Now when it comes to movies you can bring up the movie mode options wich alow you to rewind FF pause all that good stuff. just insert a umd and when it begins to play press triangle. hope this was helpfull
Jun 04, 2008 | Sony PlayStation Portable (PSP) Console
PSP Problem
I dont know how technical savvy you are but there are several DIY guides on the internet to replace the UMD drive which often fails on the PSP.
Check out this website for a complete tutorial.
http://www.llamma.com/PSP/repair/PSP_UMD_Not_Reading_Discs.htm
you can find hte UMD parts on ebay usually as well
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=psp+umd+drive&category0=
If not type in google psp repair.. there are plenty of place that do repairs.
Apr 29, 2008 | Sony PlayStation Portable (PSP) Console
Psp
is it a scratching scrapping noise?
as some UMD cases, as in the plastic thing around the disc colapse or come apart this stops the disc spinning properly.
Check the plastic on the UMD... click any sides together that may be loose / or make sure the case isnt pushing on the disc.
Also open the PSP, hold it upside, gently shake it & blow into it.
Put the UMD back in & try again.
Oct 03, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
259 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
