Question about Garden
How to remove blades from lawnmower - Garden
There is usually a bolt that holds the blade under the deck. lift the mower to where you can see the blade and in the middle there is a bolt usually a 5/8 socket or wrench will work to losen it.
Posted on Sep 24, 2009
How do you replace the piece that the belt an blade are attached to on a mountfield RV 150
you talking about the self propelled model
Repairing Lawnmowers For Profit Part 55 Replace Mountfield Lawnmower Drive...
the blade is a one piece ..you take that off
take off the belt cover
if really stuck .. use a puller for the pully/blade boss
remove the back plate to get to the idler tension pully
there was a tension device or ider pully and spring
for the belt tension
Jul 03, 2016 | Garden
How to change the belt on a craftsman rear wheel drive lawnmower
open drive cover take plug out roll belt off pully by pulling it to the side and hand turnig the blade after comes off drive remove blade and take off belt to reinstall do reverse
Aug 28, 2014 | Craftsman Garden
Honda lawnmower blade broken at shaft
How To Remove Lawnmower Blade Adapter
If it's the blade that is broken, remove the two bolts that hold the blade onto the blade adapter. If the blade adapter is broken, it needs to be taken off the engine shaft. The Link shows a video on how to remove a blade adapter. Hope this helps......
May 01, 2014 | Garden
Flymo tines
What are you referring to as tines, it sounds like you are working on a roto-tiller. I will need more info as well. Model# Unit type-ie. lawnmower. Are talking about the blades? If so the there is a large nut that bolts the blade to the lawnmower. Remove bolt by holding blade with gloved hand and long breaker bar. You can strike the breaker bar with a three pound hand sledge to break it loose. Replace or sharpen blade as necessary. Apply grease or never-seize ti threads on crankshaft, spin on the bolt and tighten with long breaker bar. Good luck!!!!! If this is a tiller, then let us know, ok?
Mar 26, 2014 | Garden
Removing lawnmower blades
check the belt that goes from each blade there is a timing mark on them
Aug 28, 2012 | Mtd Cub Cadet 33 In 344 CC Wide Area Cut...
I have a Brute by Briggs Stratton 21hp driveable lawnmower. How do you change the blades?
JUST RAISE THE MOWER TO HIGHEST POSITON TO ALLOW YOU ACCESS TO BLADES
REMOVE BOLT AND BLADE AND INSTALL NEW OR SHARPENED BLADE
ENSURE IGNITION SWITCH IS OF
Sep 02, 2011 | Briggs & Stratton Garden
I Have a push mower and hit a rock and finished the lawn hearing the lawnmower blade hit underneath a couple of times. When the mower went down slope the blade started really hitting the side. The next...
hi there nchernuka
have you checked that the engine to chassis bolts are still tight and the mounts are ok,
have you checked that you havn't bent the pto shaft ( this will be evident if you remove the blade carrier and blades, then the plug and pull the gine over - check wobble ), check that blade carrier is in good condition and the pto woodruff key is ok and the carrier centre pto bolt is tight
check that anything that is under the mower body is still tightly attached and is not getting swung into the path off the blades - ie catcher tounge - metal body brackets etc
i would also suggest you check the feather timming key in the flywheel too especially if it kicks back when you try to start it
cheers have a look
hope it helps pauly46
May 27, 2011 | Garden
42 deck craftsman riding mower. how do you get blades off? md 91721880.
On most riding lawnmowers, you can remove the blades reaching underneath the deck while the deck is set to its highest position. This may not be possible on lawnmowers with three blades; however, most 42 inch mowers have two blades.
The blades are usually held on with either one or two bolts (on each blade). Oftentimes, too, there is a lock washer underneath the bolt.
If you have auto ramps, it might help to push the front end of the mower up on the ramps. This can give you more room to access the blade bolts.
If the blades have not been removed before, those bolts can be on really tight. You might need to use some kind of breaker bar on your wrench to give you more leverage.
Oct 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Replacing lawnmower blades on 38 inch yardman
Need to plug spark plug [for safty]. Install 2x4 blocking between blade and chassy,use clamps.Coat threaded area with wd 40 and torque in clockwise position,not counterclockwise to remove old blade and install new turning bolt counterclockwise or [unscrewing direction].
Please rate. Thanks jj505
Mar 28, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
145 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
