Question about Garden
The front tires on my yard bug riding mower that I got from a friend of mine slant out. this makes it hard to stear and also puts a fear in me that one day they will brake off while im mowing. Is this normal and what part would I need to buy to fix it?
  • 11 Answers
SOURCE: riding mower won't pull uphill
your drive belt is stretched out it gets hot and slips the most torqe is on hills
Posted on Apr 03, 2009
  • 4 Answers
SOURCE: deck drive belt comes off when disengaging mower
Need to adjust the tension on the belt.
Posted on May 18, 2009
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
SOURCE: Murray Riding Mower will not move forward or back
my murray Riding Mower will not move forward or backward
Posted on Sep 03, 2009
  • 61 Answers
SOURCE: Yard Machine 18.5 HP riding mower,drive belt keeps
ck belt for wear ck between deck and frame
for so thing around clutch shaft or shaft out place.
Posted on Sep 07, 2009
The front tires of my tractor do no appear to be installed properly. When making a turn, the outside tire turns further than the inside tire to the point where it gets "caught" because it has turned too...
yhere shulb be a bar linking both wheels together to keep alighnment correct.is there 1 on yours and is it wore out or broke.good luck hope this helps
Oct 29, 2013 | Cub Cadet Garden
Change tire on dyt4000
the cover just pulls off there is a clip under there that holds the wheel on and a lot of time the wheel gets stuck to the axle and then i change them right on the mower
Apr 22, 2012 | Garden
I own a Sears Yard Machine riding mower and the rear tires are flat and I'm trying to remove the tire and take it to tire dealer to check for leaks and plug. My problem is HOW TO REMOVE THE REAR...
there is a cap over the end of the axle, it snaps off. with the rear end jacked in the air remove the C-clip which you find under the cap. the wheels will then pull off. make sure you put them back on correctly, there is an inside and an outside. If you reverse it, you will rub a groove in the tire and it will go flat and have to be replaced and they cost more than car tires. And do not pull the wheel off in the lawn or in a gravel driveway. when the wheel comes off a small key will fall to the ground. you will need to re-install this key when you put it back together or the wheels will not move. if you lose the key into the grass or gravel you will have to go to a real hardware store or small engine repair shop to buy another.
May 24, 2011 | Yard Machines Garden
While making a hard left turn the front left tire jammed against the mower body and I had to put it into reverse to straighten it out. Now the mower will not turn to the right. I can turn the tires by...
Nothing is broken,just bent.Go to the front of the mower.Get low.In between the front wheels you will see a bar,or rod.It looks like a tie rod on a car.That bar should be bent slightly but when you hit something with the front tier it gets bent too much.One end of the bar screws in and the other nd is on a clip or pin.Remove one side,which ever is easiest for you.Then just bend the bar back to almost straight.You may have to do this several times to get the turning radius back to normal.
May 23, 2011 | Yard Machines Garden
Mtd yard bug model - 198707 riding lawn mower blade belt size?
Aug 23, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Drive belt broke murray riding mower how do i put one in?
yes the drive belt is the bottom one it looks hard but is really simple the main thing is you have to look rite above the left back tire and remove two 5/16 bolts with an 1/2 in wrench to in stall drive belt the you install other belts
Aug 08, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
I have a yard bug with the 618-0351a transaxle
I just took my transaxle apart, (not a hard job once you have it removed from the mower) mine had only reverse, no forward . I found 2 small bolts had come out of the spring retainer for one of the bevel gears. One of the bolts had lodged between the shift collar & the gear resulting in the lock up you mention. Replacing the bolts, only this time using Locktite threadlocker on the threads has the little mower now happily going both directions . It would be a good idea to check the bolts in both bevel gears while you are in there. I found them loose on the other gear as well . wrenchbender1
Apr 03, 2009 | Mtd Garden
Garden Logo
268 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
