Question about Samsung Omnia Pro B7320 Smartphone
GPS does not run... I think that was not included the program.
How can I start using this?
1. Mount GPS in the vehicle using included hardware
2. Connect GPS to the vehicle's power source using included hardware (cigarette lighter)
3. Power on the GPS and Program personal preferences into the GPS unit
4. Demonstrate GPS functionality including how to find a point of interest, get directions, set-up a home location and save a destination
5. chose a suitable spot on the windscreen and Vacuum work area
to affix.
The basic GPS skills I suggest you first learn are:
1) how to set a waypoint of your current location;
2) how to enter the coordinates of a different location from a map or other reference source;
3) how to determine directions from your current location to another waypoint;
4) how to use the built in compass and altimeter;
Mar 27, 2016 | GPS
C-map sd card invisibile
Ok apparently the problem is due to the way you copied the program as the SD card and if the gps that you used is the same .
if you use the same gps sd card then you must find in the internet some program that will help you copy the files in the new card that the gps can run in the right way . you use the same gps sd card then you must find in the internet some program that will help you copy the alchivos in the new card in a way that the gps can run in the right way .
Jan 13, 2014 | Simrad NX45 Navstation
I want to know where the red,yellow,blue, green,,white,and black wires go?
red and black are power and ground, blue and white are gps output signal connect those to 9 pin connector pins 2 and 5 and get a 9 pin(serial) cable to usb adapter for input to a laptop, charting or mapping program and you are good to go. just make sure if you are using xp to wait until the mapping program is running and searching for gps signal before you connect the serial or usb because windows thinks the signal is from a mouse and the cursor will turn into a raging crackhead jumping all over the screen and randomly clicking on whatever it touches.
Jun 17, 2010 | Furuno GP31 GPS Receiver
I think I deleted the actual program on my tom tom ONE 130! It will only give me an orange screen with a red X and a flashing disk in the bottom left hand corner now. What can I do to fix this?! ?!
If you wisely made a backup of your device using 'Tom Tom Home', use the 'RESTORE' option!
Otherwise try 'Tom Tom Home' while connected to the Internet and select 'Update' my One: it should re-load and update all missing components (including the MAP) that your machine is allowed to have.
Dec 25, 2009 | Tomtom ONE 130 GPS Receiver
Charge garmin 750
My 760 was like this, I think I'd let the battery run totally flat. I was able to get it to power up, then charge, using a mains charger, thankfully I'd bought one, they aren't included as standard.
Jan 01, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Program another country
Your Garmin 330 came with the North American map installed on it. Canada is included.
Aug 16, 2008 | Garmin StreetPilot C330 GPS Receiver
Attempting to install GPS USA
i think the probleme is with ur gps usa package.Either It may be a corrupted one or there is certain installation probleme.
So 1st uninstall it and then reinstall it.
If ur probleme is not solved after reinstalling,then downlod another copy of gps usa from the below link
http://www.mininova.org/get/1118820
Oct 16, 2007 | National Geographic GPS USA (PC/MAC) GPS...
Ipaq Quick GPS connection file downloads
You may need to use the hard reset to make the quick gps connection working. but you will lost all ur program or data, including smart nav or tom tom. if you ready want to use the hard reset, remember to download smart nav or tomtom program. or you will end out no map in your system. good luck
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
Samsung Omnia Pro B7320 Smartphone Logo
156 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
