Question about Kenmore Dryers
Dryer not working
Dryer does not turn on and spin but you can hear the timer clicking replaced the push to start switch
  • Kenmore Master
  • 7,482 Answers
Sounds like your drum belt is off the pulley or broken
Posted on Sep 25, 2009
Kenmore Elite Heavy Duty King size capacity Quiet Pak 1 dryer doesn't turn on
Check to see if the door switch is working. When you push and release it, it should click. If not, it will need to be replaced.
If the switch is good, then the only other component that would cause that problem is the thermal fuse. If you could post your model number I could direct you to the part you need.
Oct 15, 2012 | Kenmore Dryers
My Whirlpool just quit it just won't turn on was working just fine is this something i can fix myself?
When most Whrlpool dryers do not turn on at all. The most common cause of failure is the door switch and the door switch actuator.
Here is how you can test this.
1 Empty the dryer of clothes
2 Locate the door switch actuator. it will be over along the top edge of where the door closes, just inside the lip. There will be a little (3/8th inch wide) metal tab covered in plastic. The is the actuator the is mounted to the electrical door switch. The door switch is a valuable safety device that prevents children, pets and adults from loosing limbs and other things in a spinning dryer. DON'T BYPASS IT.
3 The tab may simply be broken off. If you can push the piece and hear a clicking sound, it means the switch is probably good but the tab is not.
4 To test this push the tab in or jam a ball point pen in there until it clicks, turn the dryer timer on and push the start button. It it comes on, that was the issue.
WARNING: NEVER, NEVER, NEVER PUT YOU ARM INTO A SPINNING OPEN DRYER DOOR.
JUST DON'T DO IT. IT CAN RUIN YOUR DAY.
5 If you push the tab and get no click but a sort of springy action. The switch is broken.
Usually the switch replacement kit has both the metal tab and the switch.
That is usually it.
If you can supply me with the model number of the dryer, I can help you locate the right part and give some instruction on how to do it.
Hope this helps,
Best Regards,
Mark
Jan 05, 2011 | Whirlpool GEX9868J Electric Dryer
Does not turn on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 31, 2010 | Kenmore Dryers
Dryer doesn't run
the motor is going bad..push in the door switch on the dryer,an it start an spin the drum ,it it works,replace dryer motor,or purchase a new open....turn start button,pusn in door switch,spin drum by hand...all at same time....hope this helps...dryer may run a couple of times...good luck...michael..doctor airr appl.repair...843-384-8474....
Mar 26, 2010 | Dryers
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
The dryer will not start, you can hear timer.
your problem could be : Door switch, Motor, Thermal Fuse, Timer.
I would start with Door switch and Thermal Fuse.
Jan 07, 2010 | Dryers
Wont start
Is the motor running but the tub not spinning? You can tell by feeling for air movement out the exhaust after you start it or by listening to the dryer (put your ear against it and listen for a humming sound).
If motor is running your belt is broken and will have to be replaced.
Sep 02, 2009 | Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Dryer will not run
ck thermal fuse located on blower housing at rear should be white object with 2 blue wires ..if cks ok ck door switch
Sep 26, 2008 | Kenmore 63012 Electric Dryer
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Dryers Logo
35 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
