Question about Tomtom ONE 3rd Edition GPS
Battery charged up and TOM TOM does not power on
Also what type of screw driver head to remove back cover from the sat vav Tom Tom 1
  • 3,153 Answers
Its a TORX screwdriver T-8 i think
Posted on Sep 24, 2009
My tom tom started with the screen going dull and then volume went lower and it started to shut down then same thig happened a battery symbol of a rectangle shape with a little red section then sat n
can you connect it to your usb port on your computer? if so try to connect and use it. dont worry about charging it just use it to see if its working ok. i dont know why they put a battery that is not replaceable in those. you must send it back to them to replace, I keep mine on power all the time. check this out first and see if its a malfunction or works ok.
Jan 31, 2015 | Navitech TomTom / Tom Tom GPS / SatNav...
Tom tom go 710 will not switch on
I guess that you have already made sure the battery is charged enough to power the Sat Nav.... In the back of the Tom Tom where the cradle attaches, there is a tiny hole at the top where you can insert a small object such as a sewing needle in order to press the reset button; However, you may find that like mine the hole doesn't line-up with the button and therefore you can't reset the unit unless you remove the casing. if this is the case it's best to search You Tube and watch the short video as to what exactly to do! (it's really not hard)
Hope this helps
Aug 12, 2012 | Tomtom GO 710 Car GPS Receiver
No charge on tom tom 1 sat nav. if i wiggle it it will charge but i cannot hold it all day
the battery is wekend you need to change it try buyng a new battery anf format it to hold more
Feb 24, 2011 | Sony Televison & Video
I have a Tom Tom XL 4et03. I am fairly certain that the battery has collapsed. It will not charge either by the car charger or the computer USB. It doe not have screws holding it together and I cannot...
There are two small screws under the label on the bottom of the unit.(peel back each end of label to see). You then carefully pry the unit open via the bezel on front. Remove three srews securing the micro processor board to expose the battery and replace. Hardest part is finding the tiny torx driver necessary to remove screws.
Jan 17, 2011 | GPS
Replace battery on my om tom go 300
original battery ICR18650-24 sometimes marked Type VF5 or similar. Battery
  • Remove the front screen surround -- just gently prying does the trick. (Img 1)
  • Undo four T8 screws holding internal works to outside body. (Img 2)
  • Remove internal works from body. There is a cover/clip for the bottom panel (where the car mount connects) that just falls out once the insides come out -- pay attention to how it fits in, so that it can be replaced on reassembly.
  • At the base you will see silver foil covering (Img 5), the foil needs to be peeled back in places, but I left as much of it on as possible (unlike the images I'm referencing).
  • Peel back the foil around the speaker, and remove the two T8 screws, being careful not to disconnect the speaker -- it only needs to be moved aside. (Img 6)
  • Continue peeling back the foil down to the circuit board, but leave the board itself covered. You will need to manipulate, but not remove, the thin metal "cage" that is shown removed and behind the unit in Img 11.
  • On the still-covered circuit board there are four T6 screws that need to be removed. These screws can be seen in Image 11 -- one on either edge at the bottom, and one on either side of the car mount in the middle top.
  • With the foil loosened and the screws removed, manipulate the metal "cage" to expose the two T6 screws securing the black plastic battery holder (plainly visible in Img 11). Be very careful not to accidentally disconnect any of the wires/cables.
  • Remove the battery holder, unclip the old battery, replace with new one, and reassemble. (Img 16)
  • The unit should be able to power up as soon as the new battery is connected, so I tested it a few times as I reassembled, just to be sure I hadn't jostled anything loose as I went along.
Sep 17, 2009 | Tomtom GO 300 GPS Receiver
Tom tom 910
Stip down your tom tom unit, google for instructions and there is a set with pictures, But if not,
1, take the front screen surround off first, be gentle and prise it of with a flat screw driver, then unsrew the chassis from the plastic cover (4 x torx screws under the rubber feet)
2, unscrew the motherboards (torx again) and unclip the cable for the battery, and remore the eject mechanisum for the unit.
3 you may hadve to unscrew the harddrive and front screen if memory serves me well, but not to hard to do at all and my skills are basic but backed up by curiosity :o).
Jul 03, 2009 | Tomtom GO 910
Tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Nov 17, 2008 | Tomtom ONE GPS Receiver
Tom tom one battery change
I too dropped my tom tom go 300. It appears the battery was disloged as it will only work if attached to another power source; AC Adapter or cigarette plug. Does anyone know how to open the case to check on the battery?
Feb 28, 2008 | Tomtom GO 300 GPS Receiver
How to replace internal battery
Remove the Front facia surround Undo four screws holding internal works to outside body You will need a T6 star screwdriver for this. Remove internal works from body at the base you will see silver foil covering feel over this you will find 4 T5 star screws securing this remove these and also remove speaker by two locating T8 star screws. Gently remove the electronic board keep all locating cables intact You will then see two T4 star screws holding battery holder remove these and the plastic holder .Unclip battery and disconnect from Pcb Board fit new battery and reassemble. .
Jan 07, 2008 | Tomtom GO 300 GPS Receiver
Battery
need new batteries.
Jul 24, 2007 | Tomtom GO 300 GPS Receiver
Tomtom ONE 3rd Edition GPS Logo
152 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
